Cannot boot into Manjaro need to load kernel first (encrypted disk)
Upon boot I get the error:
error: file '/boot/vmlinuz-5.10-x86_64' not found
error: you need to load the kernel first
Press any key to continue...
Pressing another key does nothing to help the situation. My computer froze during an upgrade. Is there anything I can do to salvage it? I can go to grub or run memtest86+
please help. This is an encrypted drive as well, although the decryption works fine, wouldnt this make using a live usb impossible to help the situation? I think I need some help from someone who knows grub
This won’t ever help with anything in Linux that I’m aware of.
Yup. Chroot in and finish the upgrade.
can you be more specific, like give me specific steps? Sorry I never used chroot before. Does it matter that my drive is encrypted?
I apologize, that’s as simple as i can make it for you. We’ll have to wait for someone willing to go more in depth than i have time for.
I would suggest checking out the Manjaro wiki and even just googling how to chroot Manjaro. You’ll find it’s a pretty covered topic.
Do you have a live usb with a recent version of Manjaro? You need to boot with the live usb and then try and use chroot into your system to finish the upgrade if you can. There’s a few tutorials on how to use it
I can make a new Manjaro live USB no problem.
The issue that I’m concerned with is that since my hard drive is encrypted, wouldnt I not be able to read my hard drive from the LiveUSB? Obviously I know the password to decrypt it, but I have no idea how to access an encrypted drive via a liveusb setting
Have to be honest I don’t know much about chroot with encryption but I did find this in the archived forum
I’m going to try and follow that in a few minutes.
I do have some good news though, with my manjaro liveusb, I was able to decrypt my hard drive and recover my files at the very least.
One thing I did was, look into the path ‘/boot/vmlinuz-5.10-x86_64’
The file absolutely exists. It is also not an empty file. I don’t understand why it wouldnt just work?
I am trying to follow the guide with “How to chroot into an encrypted root partition”
The only issue is that there are a few little differences between his filesystem and mine. Understanding boot partitions and such is something I never really totally understood in linux and I am wondering if someone can look at my lsblk output and perhaps close the gap? Which of these is my boot partition?
NAME                                          MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
loop0                                           7:0    0    26M  1 loop  /run/miso/sfs/livefs
loop1                                           7:1    0 389.9M  1 loop  /run/miso/sfs/mhwdfs
loop2                                           7:2    0   1.1G  1 loop  /run/miso/sfs/desktopfs
loop3                                           7:3    0 731.7M  1 loop  /run/miso/sfs/rootfs
sda                                             8:0    0 119.2G  0 disk
├─sda1                                          8:1    0 110.4G  0 part
│ └─luks-c518f431-5efe-4155-b66a-e9c0cae948a6 254:0    0 110.4G  0 crypt /run/media/manjaro/cadacf71-28d3-44d1-902d-80c3deb74fb8
└─sda2                                          8:2    0   8.8G  0 part
  └─luks-acc2bc57-fc20-4090-a07f-27b854ca61ce 254:1    0   8.8G  0 crypt
sdb                                             8:16   1  57.3G  0 disk  /run/miso/bootmnt
├─sdb1                                          8:17   1   2.3G  0 part
└─sdb2                                          8:18   1     4M  0 part
sr0                                            11:0    1  1024M  0 rom
Ok… Not trying to be spammy here. Sorry if I come off that way. However I have figured out how to chroot into my encrypted drive using df. It was mounted at /dev/dm-0
the only issue I’m running into now is… when I chroot into my drive, I do
sudo pacman -Syu
and it says there is nothing to do. That means the upgrade went through. What else could it be?
I got it.
The solution is a combination of things posted here.
It doesnt matter if the drive is encrypted or not. Just mount it as normal, I just used Dolphin (from KDE), I clicked it, and it asked for a password. This mounted it in two locations. One which was sda1 (I think) was the encrypted version
then I did df to get the device location for the unencrypted version (which was something like/dev/dm-0), and mounted it to /mnt
then I used manjaro-chroot
manjaro-chroot /mnt
then I found some command that honestly made me a little worried because I never saw a pacman command look this complicated, but it did work, and all it did was reinstall the current kernel
  • From the # prompt, type this to reinstall your kernels:
sudo pacman -Syu $(pacman -Qq | grep -i "^linux[0-9]")`
(all this does is query your current packages, and finds the one that matches the kernel package name and installs it)
then I booted. I then typed the wrong password to decrypt my harddrive, and thought I messed something up lol. But once I tried it again, it worked.
Great news you got it fixed :+1: :grinning:
