Cannot boot after recover from crypto_keyfile.bin
Hi,
First of all, I’m sorry, I’m a KDE Neon user, not a Manjaro Linux user. A lot of Google search results pointed me to this forum. I read and learned a lot here the last 3 days! I’m 99% sure my problem is applicable to Manjaro Linux or any Linux distribution. I hope somebody can help me.
I’m sorry again, but seems I cannot have permission. I try to explain the best I can.
After a fresh installation of KDE neon with the default installer (calamares), with a full disk encryption I made a mistake: I removed the slot of crypto_keyfile.bin in luks.
Partition setup on calamares:
After install, the system ask me for the passphrase at boot:
All works well:
I can boot and log in.
Here the initial dump of my disk at this point:
# dump after fresh install:
# cryptsetup luksDump /dev/sda1
LUKS header information for /dev/sda1
Version:        1
Cipher name:    aes
Cipher mode:    xts-plain64
Hash spec:      sha256
Payload offset: 4096
MK bits:        512
MK digest:      6d 3c 68 a4 da 55 1e 26 78 be 2b 8b d1 72 94 a5 b6 94 be 8f
MK salt:        58 19 79 77 e7 3a 81 0e fb 6a a7 c0 d8 ae 62 44
                79 4f 7f aa 59 70 ca 29 e9 b9 23 89 88 af 29 a0
MK iterations:  55258
UUID:           c13ff99a-57b7-4da0-bc1d-15aecce10660
Key Slot 0: ENABLED
        Iterations:             1008246
        Salt:                   a3 28 10 f5 49 38 3b bd 74 29 48 28 6c bd 2e 5e
                                42 e5 41 c2 31 ad f8 30 36 04 49 6f 31 9e ad 43
        Key material offset:    8
        AF stripes:             4000
Key Slot 1: ENABLED
        Iterations:             881156
        Salt:                   3b d3 2b a0 c4 93 75 4e fd 54 ca f8 12 23 15 3f
                                cf ce 99 1f a8 1e ab 6c d8 81 86 33 70 51 16 9c
        Key material offset:    512
        AF stripes:             4000
Key Slot 2: DISABLED
Key Slot 3: DISABLED
Key Slot 4: DISABLED
Key Slot 5: DISABLED
Key Slot 6: DISABLED
Key Slot 7: DISABLED
some relavant info:
# cat /etc/crypttab
# /etc/crypttab: mappings for encrypted partitions.
# <name>               <device>                         <password> <options>
luks-c13ff99a-57b7-4da0-bc1d-15aecce10660 UUID=c13ff99a-57b7-4da0-bc1d-15aecce10660     /crypto_keyfile.bin luks,discard
# cat /etc/cryptsetup-initramfs/conf-hook
KEYFILE_PATTERN=/crypto_keyfile.bin
# grub.cfg
menuentry 'Neon GNU/Linux' --class neon --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-db38bf32-cd67-433b-8098-0720751466dd' {
        recordfail
        load_video
        gfxmode $linux_gfx_mode
        insmod gzio
        if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
        insmod part_msdos
        insmod cryptodisk
        insmod luks
        insmod gcry_rijndael
        insmod gcry_sha256
        insmod ext2
        cryptomount -u c13ff99a57b74da0bc1d15aecce10660
        set root='cryptouuid/c13ff99a57b74da0bc1d15aecce10660'
        if [ x$feature_platform_search_hint = xy ]; then
          search --no-floppy --fs-uuid --set=root --hint='cryptouuid/c13ff99a57b74da0bc1d15aecce10660'  db38bf32-cd67-433b-8098-0720751466dd
        else
          search --no-floppy --fs-uuid --set=root db38bf32-cd67-433b-8098-0720751466dd
        fi
        linux   /boot/vmlinuz-5.15.0-58-generic root=UUID=db38bf32-cd67-433b-8098-0720751466dd ro  quiet splash $vt_handoff
        initrd  /boot/initrd.img-5.15.0-58-generic
and now, my mistake: I tried to change the key of slot 1 instead of slot 0 (I want to change iter-time).
# cryptsetup luksChangeKey /dev/sda1 -S 1 -i 30
Enter passphrase to be changed:
No key available with this passphrase.
# cryptsetup luksKillSlot /dev/sda1 1
Enter any remaining passphrase:
# cryptsetup luksAddKey /dev/sda1 -S 1 -i 30
Enter any existing passphrase:
Enter new passphrase for key slot: # nothing entered, just enter
Verify passphrase: # nothing entered, just enter
dumps during last steps …
# dump after kill slot 1
Version:        1
Cipher name:    aes
Hash spec:      sha256
MK bits:        512
Key Slot 0: ENABLED
        Iterations:             1008246
        AF stripes:             4000
Key Slot 1: DISABLED
# dump after add key
Version:        1
Cipher name:    aes
Hash spec:      sha256
MK bits:        512
Key Slot 0: ENABLED
        Iterations:             1008246
        AF stripes:             4000
Key Slot 1: ENABLED
        Iterations:             16115
        Salt:                   98 d6 c6 d2 c0 59 41 6b 64 cf d8 c4 d6 93 ef 85
                                f5 97 f7 29 f2 4f f7 03 c0 7c 16 d9 a5 54 27 99
        AF stripes:             4000
After reboot, I can see this error:
Now I’m on busybox and I try to restore in this way:
cryptsetup luksOpen /dev/sda1 try1
mount /dev/mapper/try1 /try1
cryptsetup luksChangeKey /dev/sda1 --key-slot 1 /try/crypto_file.bin
A new luksDump:
After reboot, the system not boots (cannot edit entries, boot, nothing):
What I’m missing? Where I’m misundertood? Where is my error.
Thank’s in adavance!
What is the keyfile needed for?
What does it decrypt?
How did you get these outputs?
From a live system?
With real complete full disk encryption, Grub does the decryption.
The password you give to it must be one that matches / can open any one of the keyslots.
from what I see:
you changed the passphrase for slot 1 - which supposedly is the slot the keyfile opened
Now it just has got a password - or no password. Can’t see that from your post.
Then you killed slot 1 completely
and set it up again and added a password to it.
I guess we need to know the disk layout
lsblk -f
and
/etc/fstab
I don’t even know whether KDE Neon is similar to Arch/Manjaro.
… what is the key file’s function?
I just checked the website - KDE Neon is based upon Ubuntu LTS.
Perhaps it is better to ask for support in Ubuntu fora.
But I’ll try as long as the thread stays open here.
… I guess /etc/crypttab could be also interesting, to see which partitions are decrypted by keyfile. ATTENTION: if you post /etc/cryttab make sure to mask passwords if there were any saved in it.
In my setup / can be open by passphrase through grub and /home gets decrypted via keyfile through /etc/crypttab. Perhaps @mserra setup looks the same. :slightly_smiling_face:
it’s there - but this is Ubuntu LTS (KDE Neon is packages on top of it)
The structure of what does what and what is where is a bit different in Ubuntu.
Oha … dammit I overseen it. :stuck_out_tongue_winking_eye:
Thank’s to all for your replies.
I’m not sure. I’m a novice in a LUKS world. Perhaps this topic on this forum can help? /t/why-does-the-installer-add-a-paswordless-key-to-luks-encrypted-partition/76551/21 (is one of more topic I was read the last days)
I get these inputs from busybox, before try luksChangeKey. After luksChangeKey the system becomes unsusable, unbootable.
Now I booted from a live USB to give you the lsblk and fstab information.
I’m agree. For that I can’t uderstand whats happening.
Here is where I’m getting lost
here you got the disk layout (really simple):
# lsblk -f
sda
└─sda1
     crypto 1                    c13ff99a-57b7-4da0-bc1d-15aecce10660
# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
/dev/mapper/luks-c13ff99a-57b7-4da0-bc1d-15aecce10660 /              ext4    defaults,noatime 0 1
I’m not sure.
If I can upload images or links I can make the question more consistent :sweat_smile:
You seem to be trying to unlock an encrypted partition using a keyfile that exists inside said locked partition. Obviously that won’t work.
I’d say:
the keyfile isn’t even needed. red herring, so to say …
you just need to have a password set to be able to open the container
use an easy one - one that you can type on an english layout keyboard
no z or y or any other non english characters
Yes, yes, I can open the disk from a Live System (Desktop folder is on my encrypted and unbootable disk)…
# mkdir /try1
# cryptsetup -v luksOpen /dev/sda1 try1
Enter passphrase for /dev/sda1:
Key slot 0 unlocked.
Command successful.
# mount /dev/mapper/try1 /try1/
# ls /try1/home/marc/
Desktop
My password is really easy (4 numbers). I’m just testing/learning. I’m 100% is not a password error.
# cryptsetup -v luksDump /dev/sda1
Version:        1
Cipher name:    aes
Hash spec:      sha256
MK bits:        512
Key Slot 0: ENABLED
        Iterations:             1008246
        AF stripes:             4000
Key Slot 1: ENABLED
        Iterations:             1010188
        Salt:                   93 9d 71 1d ad fd 9b 75 6b 69 24 66 7d 69 ce fc
                                8e dc 39 66 25 42 63 76 71 93 68 91 81 c8 ba b0
        AF stripes:             4000
Command successful.
I’m not sure about that. But if I clear the slot 1 (with luksKillSlot) and only have slot 0 with a correct password, the behavior is the same: cannot boot
Because you’ve configured it to use the keyfile. The crypttab configuration is wrong.
I think this should do it, but I’m not sure, it’s been a while since I messed with this stuff and all my encrypted partitions use a keyfile.
luks-c13ff99a-57b7-4da0-bc1d-15aecce10660 UUID=c13ff99a-57b7-4da0-bc1d-15aecce10660 - luks,discard
or better yet
# crypttab
root UUID=c13ff99a-57b7-4da0-bc1d-15aecce10660 - luks,discard
# fstab
/dev/mapper/root / ext4 defaults,noatime 0 1
https://wiki.archlinux.org/title/Dm-crypt/System_configuration#crypttab
Thank’s for answer, but no luck! the system crashes again.
Here fstab and crypttab …
Try providing us with some information.
Did you get a password prompt?
Was there an error message?
What was the error message?
cat /etc/default/grub
You may need to update-grub.
I just installed KDE Neon in a VM
encrypted - as yours
I intentionally chose a password that would be producing the wrong output if not typed on an english keyboard.
I have german layout - and the password was: qwertz
but when I type that at the grub prompt, it gets rejected
… because the z and the y characters are interchanged
I have t o type: qwerty
to have grub to see: qwertz
anyway - I have it now installed - and can kind of see what you might see - and perhaps assist you that way …
You wanted to change … what?
the amount of iterations in the decryption process (I guess)
to make Grub decrypting and opening the container faster - and thus improving boot time.
correct?
… but thereby weakening the security - but you know that …
the Grub boot loader only knows the english keyboard layout
you will struggle when you have another - to type the password that you chose
No.
No error message displayed. Simple stucks on grub menu.
# cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Oh, great! Danke!
correct?
Yes, exactly!
Yes, I understand. No problem on that. Just testing/learning.
No problem, I’m using spanish keyboard (I’m from Barcelona) and the password is only numbers (1234 by now!), and I’m sure it’s ok.
Give me a few minutes and I record a video of all process after a fresh install on a virtual machine.
here you can find the video (8 minutes)
before I invest the time to watch what you did:
I’m quite sure, but please confirm:
you wanted to lower the strength of the encryption - so that the encryption through Grub would be faster
right?
as far as I can see now:
the key file is indeed irrelevant
there is just one encrypted container, containing the / filesystem and swap
but this is Ubuntu - and the swap is not in your /etc/fstab
not sure what actually happens here
Yes, and I know how to that correctly now.
But I want to understand how to recover the system in the case of my mistake.
