I really need some assistance here. I tried to install the lighdm with the theme glorious on my manjaro installation. This failed, but I could still access my system when logging in by choosing the default login.
I the stupidly perhaps, removed the lightdm launcher from the add/remove software interface. What now happens is that I cannot access any interface, only the tty terminal. Is there a way to access the GUI again through the tty terminal, or perhaps start the default launcher or install a new one?
I would like to post a picture of the output, but I do not seem to be able to do it.
I’ve tried removing and installing new graphics drivers after looking around for solutions, but this has not helped.
Any help with this would be really appreciated as I’d rater not re-install.
That is, as far as I know, not a needed part of the standars installation - perhaps it is part of an AUR package that you installed to get the theme that you wanted.
Make sure you completely reverse whatever you did - remove any AUR package related to lightdm, for instance.
Then, after a reboot, check the status of the service systemctl status lightdm.service
and, if needed, start and enable it
Yes, ok. I re-installed light-dm and now I can log in using that one. It looks a bit off graphically, as if there is something wrong with the graaphics driver perhaps but it works.
