Hello, I can’t send files to my Android. I get the following message: impossible to start the service “org.bluez.obex”: the name is not activable.
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.11 Distro: Manjaro Linux
Type: Laptop System: Dell product: Latitude E5450 v: N/A
serial: <superuser required>
Mobo: Dell model: N/A serial: <superuser required> UEFI: Dell v: A13
date: 05/17/2016
ID-1: BAT0 charge: 39.7 Wh (100.0%) condition: 39.7/51.7 Wh (76.8%)
Info: dual core model: Intel Core i5-5300U bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 966 min/max: 500/2900 cores: 1: 799 2: 798 3: 1341
4: 928
Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
Device-2: Silicon Motion - Taiwan (formerly Feiya ) 300k Pixel Camera
driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.12 driver: X: loaded: modesetting
dri: iris gpu: i915 s-res: 1366x768 resolution: 1366x768
API: EGL v: 1.5 drivers: iris,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
API: Vulkan v: 1.3.279 drivers: intel surfaces: xcb,xlib
Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 17.0 status: active
Device-1: Intel Ethernet I218-LM driver: e1000e
Device-2: Intel Wireless 7265 driver: iwlwifi
Device-1: Intel Bluetooth wireless interface driver: btusb type: USB
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
Local Storage: total: 465.76 GiB used: 200.73 GiB (43.1%)
ID-1: /dev/sda vendor: Seagate model: ST500LM000-1EJ162 size: 465.76 GiB
ID-1: / size: 448.41 GiB used: 200.73 GiB (44.8%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 580 KiB (0.2%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 448.41 GiB used: 200.73 GiB (44.8%) fs: btrfs
dev: /dev/sda2
ID-4: /var/log size: 448.41 GiB used: 200.73 GiB (44.8%) fs: btrfs
dev: /dev/sda2
ID-1: swap-1 type: partition size: 17.06 GiB used: 780 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 53.0 C mobo: 47.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 2488
Memory: total: 16 GiB available: 15.5 GiB used: 8.63 GiB (55.7%)
Processes: 221 Uptime: 3h 4m Shell: Zsh inxi: 3.3.33
Thank you in advance for your answers
