Hi,
my printer is setup in cups visible in the network and printing works fine from Macs, Linux PCs and even Windows.
iPad an iPhones can see the printer but printing always fails - it tries to connect but get caught in a loop in trying to to connect …
Same when I configure the printer manually in Avahi Service and the automatic detection - but as it works flawlessly on the Mac bonjour is working fine …
Any ideas?
nuisgenug:
Any ideas?
a 10 pund sledgehammer?
Jokes aside - print directly to the printer instead of through Manjaro.
IPP usually works
Besides that - this is the Manjaro fouem - not iOS troubleshooting.
unfortunately not possible, its connected via USB so the manjaro PC acts as printserver
thats alsi why I’m posting here
Olli
11 September 2023 15:18
11
please post the mandatory output of
that we can see what graphical ui etc… you’re using. use the option of preformatted text (the </>) and paste the output inside this.
Kernel: 6.1.51-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=XX rw quiet splash apparmor=1
security=apparmor resume=UUID=XX
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel, plank
wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Apple product: Macmini4,1 v: 1.0
serial: <superuser required> Chassis: type: 16 v: Mac-F2208EC8
Mobo: Apple model: Mac-F2208EC8 serial: <superuser required> UEFI: Apple
v: 76.0.0.0.0 date: 06/13/2019
Device-1: hid-28:37:37:2e:cb:e3-battery model: Zorks Trackpad serial: N/A
charge: N/A status: discharging
Device-2: hid-7c:6d:62:40:72:33-battery model: Zorks Keyboard serial: N/A
System RAM: total: 16 GiB note: est. available: 15.37 GiB
used: 2.1 GiB (13.6%)
Info: model: Intel Core2 Duo P8800 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1594 high: 1596 min/max: 1596/2660 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1593 2: 1596
bogomips: 10623
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA MCP89 [GeForce 320M] vendor: Apple driver: nouveau v: kernel
non-free: series: 340.xx status: legacy (EOL) last: release: 340.108
kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-13 ports:
active: DP-1,HDMI-A-1 empty: none bus-ID: 05:00.0 chip-ID: 10de:08a4
class-ID: 0300 temp: 63.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84") monitors: <missing: xrandr>
Monitor-1: DP-1 model: LG (GoldStar) HDR WQHD serial: <filter> built: 2021
res: 3440x1440 dpi: 107 gamma: 1.2 size: 820x346mm (32.28x13.62")
diag: 888mm (34.9") modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-1 model: LG (GoldStar) HDR WQHD serial: <filter>
built: 2021 res: 3440x1440 dpi: 107 gamma: 1.2 size: 820x346mm (32.28x13.62")
diag: 888mm (34.9") modes: max: 1920x1080 min: 640x480
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA MCP89 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 00:08.0 chip-ID: 10de:0d94 class-ID: 0403
API: ALSA v: k6.1.51-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.79 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Broadcom BCM43224 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4353 class-ID: 0280
Device-2: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp4s0f0 state: down mac: <filter>
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-6.3:6 chip-ID: 05ac:8218
class-ID: fe01
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1
lmp-v: 4 status: discoverable: yes pairing: yes class-ID: 7c0104
Local Storage: total: 447.13 GiB used: 13.77 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: SSD serial: <filter> fw-rev: R022 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRW GA32N rev: KC08
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 429.92 GiB size: 422.11 GiB (98.18%) used: 13.77 GiB (3.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: XX
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: XX
ID-1: swap-1 type: partition size: 16.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: XX
Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 6 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-4: 4-0:1 info: full speed or root hub ports: 6 rev: 1.1
Device-1: 4-5:2 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
Hub-5: 4-6:3 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 4-6.3:6 info: Apple Bluetooth Host Controller type: bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 05ac:8218 class-ID: fe01
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nouveau temp: 63.0 C
Fan Speeds (rpm): N/A
Processes: 169 Uptime: 7m wakeups: 2 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1189
pm: pacman pkgs: 1182 libs: 370 tools: pamac pm: flatpak pkgs: 7 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.29
