Hello @megavolt! thank you for your reply!
Regarding what you’ve requested here are the results:
System Information:
Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f31b7457-f296-4af4-9409-112ba07a77c0 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 modesetting=1
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: HP product: OMEN Laptop 15-en1xxx v: N/A
Mobo: HP model: 88D2 v: 75.53 serial: <superuser required> UEFI: AMI
v: F.10 date: 07/28/2021
ID-1: BAT0 charge: 66.5 Wh (94.2%) condition: 70.6/70.6 Wh (100.0%)
volts: 13.2 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: Charging cycles: 31
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1207 high: 1318 min/max: 1200/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1250 2: 1318
3: 1197 4: 1197 5: 1197 6: 1197 7: 1197 8: 1197 9: 1197 10: 1197 11: 1197
12: 1198 13: 1197 14: 1197 15: 1197 16: 1197 bogomips: 102251
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:249d
class-ID: 0300
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
type: USB driver: uvcvideo bus-ID: 1-3:3 chip-ID: 05c8:03df class-ID: 0e02
Display: x11 server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau failed: ati
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
Device-1: NVIDIA GA104 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1.2.1:5 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp6s0f3u1u2u1 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
Local Storage: total: 953.87 GiB used: 9.46 GiB (1.0%)
model: PC SN730 SDBPNTY-1T00-1006 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: HPS2 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 464.51 GiB size: 456.14 GiB (98.20%) used: 9.43 GiB (2.1%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27.4 MiB (28.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 425 Uptime: 4m wakeups: 1 Memory: 15.04 GiB
used: 2.22 GiB (14.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1136 lib: 304 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.10
Xorg
cat: '/var/log/Xorg*.log': No such file or directory
---/var/log/Xorg*.log---
cat: '/home/ricardof/.local/share/xorg/Xorg*.log': No such file or directory
---/home/ricardof/.local/share/xorg/Xorg*.log---
-- Journal begins at Wed 2021-12-15 00:26:07 WET, ends at Fri 2021-12-17 01:46:00 WET. --
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (++) from command line, (!!) notice, (II) informational,
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) The directory "/usr/share/fonts/misc" does not exist.
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) The server relies on udev to provide the list of input devices.
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Module ABI versions:
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) xfree86: Adding drm device (/dev/dri/card0)
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "glx"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Module glx: vendor="X.Org Foundation"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Applying OutputClass "nvidia" to /dev/dri/card0
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "nvidia"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Module nvidia: vendor="NVIDIA Corporation"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "nouveau"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Module nouveau: vendor="X.Org Foundation"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "nv"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) Warning, couldn't open module nv
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (EE) Failed to load module "nv" (module does not exist, 0)
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "ati"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Module ati: vendor="X.Org Foundation"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "radeon"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Module radeon: vendor="X.Org Foundation"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "modesetting"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) Module modesetting: vendor="X.Org Foundation"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "fbdev"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) Warning, couldn't open module fbdev
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (EE) Failed to load module "fbdev" (module does not exist, 0)
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) LoadModule: "vesa"
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (WW) Warning, couldn't open module vesa
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (EE) Failed to load module "vesa" (module does not exist, 0)
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) NVIDIA dlloader X Driver 495.44 Fri Oct 22 06:11:21 UTC 2021
dez 17 01:40:09 omen-ricardof /usr/lib/gdm-x-session[727]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Driver
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:249d) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-prime 2021.11.04 false PCI
video-hybrid-amd-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:06:00.0 (0300:1002:1638) Display controller ATI Technologies Inc:
> Installed PCI configs:
Kernel Messages
journalctl --grep=“amdgpu”
-- Journal begins at Wed 2021-12-15 00:26:07 WET, ends at Fri 2021-12-17 01:53:16 WET. --
dez 15 00:26:09 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 15 00:26:09 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 15 00:26:09 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 15 00:26:09 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 15 00:26:09 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 15 00:26:09 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 15 00:26:09 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 15 00:26:09 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 15 00:26:10 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 15 00:26:10 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 15 00:26:10 omen-ricardof kernel: amdgpu: SRAT table not found
dez 15 00:26:10 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 15 00:26:10 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 15 00:26:10 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 15 00:26:10 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 15 00:26:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 15 00:26:10 omen-ricardof kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:06:00.0 on minor 1
dez 15 00:26:10 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 00:26:10 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 00:26:10 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Boot e9ec09c5a11e4fe6944003b847c6da02 --
dez 15 00:27:39 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 15 00:27:39 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 15 00:27:39 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 15 00:27:39 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 15 00:27:39 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 15 00:27:39 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 15 00:27:39 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 15 00:27:39 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 15 00:27:40 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 15 00:27:40 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 15 00:27:40 omen-ricardof kernel: amdgpu: SRAT table not found
dez 15 00:27:40 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 15 00:27:40 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 15 00:27:40 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 15 00:27:40 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 15 00:27:40 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 15 00:27:40 omen-ricardof kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:06:00.0 on minor 1
dez 15 00:27:40 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 00:27:40 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 00:27:40 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: loading driver: amdgpu
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) Matched amdgpu as autoconfigured driver 0
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) LoadModule: "amdgpu"
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) Module amdgpu: vendor="X.Org Foundation"
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU: Driver for AMD Radeon:
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: All GPUs supported by the amdgpu kernel driver
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Creating default Display subsection in Screen section
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): Default visual is TrueColor
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): RGB weight 888
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
dez 15 00:27:40 omen-ricardof /usr/lib/gdm-x-session[1109]: (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1638)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.42.0, 5.15.6-2-MANJARO, LLVM 13.0.0)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): glamor detected, initialising EGL layer.
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): TearFree property default: auto
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): VariableRefresh: disabled
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): KMS Pageflipping: enabled
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Output eDP has no monitor section
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): EDID for output eDP
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Manufacturer: LGD Model: 5fe Serial#: 0
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Year: 2018 Week: 0
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): EDID Version: 1.4
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Digital Display Input
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 8 bits per channel
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Digital interface is DisplayPort
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Gamma: 2.20
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): First detailed timing is preferred mode
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.305 greenY: 0.605
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): blueX: 0.150 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Manufacturer's mask: 0
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Supported detailed timing:
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): clock: 346.5 MHz Image Size: 344 x 194 mm
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1157 v_border: 0
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): clock: 144.4 MHz Image Size: 344 x 194 mm
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Unknown vendor-specific block 2
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): EDID (in hex):
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 00ffffffffffff0030e4fe0500000000
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 001c0104a5221378eae085a3544e9b26
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 0e505400000001010101010101010101
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 0101010101015e8780a070384d403020
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 350058c21000001b683880a070384d40
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 3020350058c21000001b000000000000
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 00000000000000000000000000000002
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): 000c30f20f3c962e12309e0000000083
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Printing probed modes for output eDP
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1920x1080"x144.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1920x1080"x60.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1680x1050"x144.0 346.54 1680 1968 2000 2080 1050 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1280x1024"x144.0 346.54 1280 1968 2000 2080 1024 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1440x900"x144.0 346.54 1440 1968 2000 2080 900 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1280x800"x144.0 346.54 1280 1968 2000 2080 800 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1280x720"x144.0 346.54 1280 1968 2000 2080 720 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1024x768"x144.0 346.54 1024 1968 2000 2080 768 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "800x600"x144.0 346.54 800 1968 2000 2080 600 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "640x480"x144.0 346.54 640 1968 2000 2080 480 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Output eDP connected
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Using exact sizes for initial modes
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): mem size init: gart size :bf6ca000 vram size: s:1df2d000 visible:1df2d000
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): DPI set to (96, 96)
dez 15 00:27:41 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): [DRI2] Setup complete
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Front buffer pitch: 7680 bytes
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): SYNC extension fences enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Present extension enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): DRI3 enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): Backing store enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Direct rendering enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Use GLAMOR acceleration.
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Acceleration enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): DPMS enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (==) AMDGPU(0): Silken mouse enabled
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Set up textured video (glamor)
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Setting screen physical size to 508 x 285
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (EE) AMDGPU(0): Failed to make import prime FD as pixmap: 22
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Allocate new frame buffer 4480x1440
dez 15 00:27:42 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): => pitch 17920 bytes
dez 15 00:27:43 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:27:43 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:27:43 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:27:43 omen-ricardof /usr/lib/gdm-x-session[1109]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[1109]: (EE) AMDGPU(0): failed to set mode: Permission denied
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: loading driver: amdgpu
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) Matched amdgpu as autoconfigured driver 0
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) LoadModule: "amdgpu"
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) Module amdgpu: vendor="X.Org Foundation"
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU: Driver for AMD Radeon:
dez 15 00:27:55 omen-ricardof /usr/lib/gdm-x-session[2055]: All GPUs supported by the amdgpu kernel driver
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Creating default Display subsection in Screen section
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): Default visual is TrueColor
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): RGB weight 888
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1638)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.42.0, 5.15.6-2-MANJARO, LLVM 13.0.0)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): glamor detected, initialising EGL layer.
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): TearFree property default: auto
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): VariableRefresh: disabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): KMS Pageflipping: enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Output eDP has no monitor section
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID for output eDP
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Manufacturer: LGD Model: 5fe Serial#: 0
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Year: 2018 Week: 0
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID Version: 1.4
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Digital Display Input
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 8 bits per channel
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Digital interface is DisplayPort
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Gamma: 2.20
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): First detailed timing is preferred mode
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.305 greenY: 0.605
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): blueX: 0.150 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Manufacturer's mask: 0
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Supported detailed timing:
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): clock: 346.5 MHz Image Size: 344 x 194 mm
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1157 v_border: 0
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): clock: 144.4 MHz Image Size: 344 x 194 mm
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Unknown vendor-specific block 2
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID (in hex):
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 00ffffffffffff0030e4fe0500000000
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 001c0104a5221378eae085a3544e9b26
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 0e505400000001010101010101010101
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 0101010101015e8780a070384d403020
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 350058c21000001b683880a070384d40
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 3020350058c21000001b000000000000
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 00000000000000000000000000000002
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): 000c30f20f3c962e12309e0000000083
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing probed modes for output eDP
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x144.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x60.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1680x1050"x144.0 346.54 1680 1968 2000 2080 1050 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1280x1024"x144.0 346.54 1280 1968 2000 2080 1024 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1440x900"x144.0 346.54 1440 1968 2000 2080 900 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1280x800"x144.0 346.54 1280 1968 2000 2080 800 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1280x720"x144.0 346.54 1280 1968 2000 2080 720 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1024x768"x144.0 346.54 1024 1968 2000 2080 768 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "800x600"x144.0 346.54 800 1968 2000 2080 600 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "640x480"x144.0 346.54 640 1968 2000 2080 480 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Output eDP connected
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Using exact sizes for initial modes
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): mem size init: gart size :bf6ca000 vram size: s:1df2d000 visible:1df2d000
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): DPI set to (96, 96)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): [DRI2] Setup complete
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Front buffer pitch: 7680 bytes
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): SYNC extension fences enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Present extension enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): DRI3 enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): Backing store enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Direct rendering enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Use GLAMOR acceleration.
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Acceleration enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): DPMS enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (==) AMDGPU(0): Silken mouse enabled
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Set up textured video (glamor)
dez 15 00:27:56 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Setting screen physical size to 508 x 285
dez 15 00:27:57 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:27:57 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:27:57 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:27:57 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:27:57 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Allocate new frame buffer 4480x1440
dez 15 00:27:57 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): => pitch 17920 bytes
dez 15 00:27:58 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:27:58 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:27:58 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:27:58 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:27:59 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:27:59 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:27:59 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:27:59 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:28:03 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:28:03 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:28:03 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:28:03 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:28:06 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:28:06 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:28:06 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:28:06 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:28:26 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:28:26 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:28:26 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:28:26 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:28:31 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:28:31 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:28:31 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:28:31 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:30:21 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 00:30:21 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 00:30:21 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 00:30:21 omen-ricardof /usr/lib/gdm-x-session[2055]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 00:31:24 omen-ricardof gnome-shell[3850]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:31:46 omen-ricardof gnome-shell[3850]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:45:44 omen-ricardof gnome-shell[3883]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:46:14 omen-ricardof gnome-shell[3883]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:46:44 omen-ricardof gnome-shell[3883]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:46:45 omen-ricardof gnome-shell[3883]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:47:36 omen-ricardof gnome-shell[3850]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:51:09 omen-ricardof gnome-shell[3355]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:51:17 omen-ricardof gnome-shell[3355]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:51:34 omen-ricardof gnome-shell[3355]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 00:52:11 omen-ricardof gnome-shell[3355]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 01:02:32 omen-ricardof systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 01:02:32 omen-ricardof systemd[1]: systemd-backlight@backlight:amdgpu_bl1.service: Deactivated successfully.
dez 15 01:02:32 omen-ricardof systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 01:02:32 omen-ricardof audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Boot 5febdeb3051c449db9105ef509520b56 --
dez 15 01:02:54 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 15 01:02:54 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 15 01:02:54 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 15 01:02:54 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 15 01:02:54 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 15 01:02:54 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 15 01:02:54 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 15 01:02:54 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 15 01:02:55 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 15 01:02:55 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 15 01:02:55 omen-ricardof kernel: amdgpu: SRAT table not found
dez 15 01:02:55 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 15 01:02:55 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 15 01:02:55 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 15 01:02:55 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 15 01:02:55 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 15 01:02:55 omen-ricardof kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:06:00.0 on minor 1
dez 15 01:02:55 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 01:02:55 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 01:02:55 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Boot 5507c924ef1d4df2910a9cbaf41b2e17 --
dez 15 01:04:06 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 15 01:04:06 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 15 01:04:06 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 15 01:04:06 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 15 01:04:06 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 15 01:04:06 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 15 01:04:06 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 15 01:04:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 15 01:04:07 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 15 01:04:07 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 15 01:04:07 omen-ricardof kernel: amdgpu: SRAT table not found
dez 15 01:04:07 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 15 01:04:07 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 15 01:04:07 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 15 01:04:07 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 15 01:04:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 15 01:04:07 omen-ricardof kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:06:00.0 on minor 1
dez 15 01:04:07 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 01:04:07 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 01:04:07 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: loading driver: amdgpu
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) Matched amdgpu as autoconfigured driver 0
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) LoadModule: "amdgpu"
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) Module amdgpu: vendor="X.Org Foundation"
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU: Driver for AMD Radeon:
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: All GPUs supported by the amdgpu kernel driver
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Creating default Display subsection in Screen section
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): Default visual is TrueColor
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): RGB weight 888
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
dez 15 01:04:07 omen-ricardof /usr/lib/gdm-x-session[1110]: (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1638)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.42.0, 5.15.6-2-MANJARO, LLVM 13.0.0)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): glamor detected, initialising EGL layer.
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): TearFree property default: auto
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): VariableRefresh: disabled
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): KMS Pageflipping: enabled
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Output eDP has no monitor section
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): EDID for output eDP
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Manufacturer: LGD Model: 5fe Serial#: 0
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Year: 2018 Week: 0
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): EDID Version: 1.4
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Digital Display Input
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 8 bits per channel
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Digital interface is DisplayPort
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Gamma: 2.20
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): First detailed timing is preferred mode
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.305 greenY: 0.605
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): blueX: 0.150 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Manufacturer's mask: 0
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Supported detailed timing:
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): clock: 346.5 MHz Image Size: 344 x 194 mm
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1157 v_border: 0
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): clock: 144.4 MHz Image Size: 344 x 194 mm
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Unknown vendor-specific block 2
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): EDID (in hex):
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 00ffffffffffff0030e4fe0500000000
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 001c0104a5221378eae085a3544e9b26
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 0e505400000001010101010101010101
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 0101010101015e8780a070384d403020
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 350058c21000001b683880a070384d40
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 3020350058c21000001b000000000000
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 00000000000000000000000000000002
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): 000c30f20f3c962e12309e0000000083
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Printing probed modes for output eDP
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1920x1080"x144.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1920x1080"x60.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1680x1050"x144.0 346.54 1680 1968 2000 2080 1050 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1280x1024"x144.0 346.54 1280 1968 2000 2080 1024 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1440x900"x144.0 346.54 1440 1968 2000 2080 900 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1280x800"x144.0 346.54 1280 1968 2000 2080 800 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1280x720"x144.0 346.54 1280 1968 2000 2080 720 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1024x768"x144.0 346.54 1024 1968 2000 2080 768 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "800x600"x144.0 346.54 800 1968 2000 2080 600 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "640x480"x144.0 346.54 640 1968 2000 2080 480 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Output eDP connected
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Using exact sizes for initial modes
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): mem size init: gart size :bf6ca000 vram size: s:1df2d000 visible:1df2d000
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): DPI set to (96, 96)
dez 15 01:04:08 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): [DRI2] Setup complete
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Front buffer pitch: 7680 bytes
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): SYNC extension fences enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Present extension enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): DRI3 enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): Backing store enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Direct rendering enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Use GLAMOR acceleration.
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Acceleration enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): DPMS enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (==) AMDGPU(0): Silken mouse enabled
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Set up textured video (glamor)
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Setting screen physical size to 508 x 285
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (EE) AMDGPU(0): Failed to make import prime FD as pixmap: 22
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Allocate new frame buffer 4480x1440
dez 15 01:04:09 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): => pitch 17920 bytes
dez 15 01:04:10 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 01:04:10 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 01:04:10 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:10 omen-ricardof /usr/lib/gdm-x-session[1110]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: loading driver: amdgpu
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) Matched amdgpu as autoconfigured driver 0
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) LoadModule: "amdgpu"
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) Module amdgpu: vendor="X.Org Foundation"
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[1110]: (EE) AMDGPU(0): failed to set mode: Permission denied
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU: Driver for AMD Radeon:
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: All GPUs supported by the amdgpu kernel driver
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Creating default Display subsection in Screen section
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): Default visual is TrueColor
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): RGB weight 888
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1638)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.42.0, 5.15.6-2-MANJARO, LLVM 13.0.0)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): glamor detected, initialising EGL layer.
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): TearFree property default: auto
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): VariableRefresh: disabled
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): KMS Pageflipping: enabled
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Output eDP has no monitor section
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): EDID for output eDP
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Manufacturer: LGD Model: 5fe Serial#: 0
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Year: 2018 Week: 0
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): EDID Version: 1.4
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Digital Display Input
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 8 bits per channel
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Digital interface is DisplayPort
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Gamma: 2.20
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): First detailed timing is preferred mode
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.305 greenY: 0.605
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): blueX: 0.150 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Manufacturer's mask: 0
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Supported detailed timing:
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): clock: 346.5 MHz Image Size: 344 x 194 mm
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1157 v_border: 0
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): clock: 144.4 MHz Image Size: 344 x 194 mm
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Unknown vendor-specific block 2
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): EDID (in hex):
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 00ffffffffffff0030e4fe0500000000
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 001c0104a5221378eae085a3544e9b26
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 0e505400000001010101010101010101
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 0101010101015e8780a070384d403020
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 350058c21000001b683880a070384d40
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 3020350058c21000001b000000000000
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 00000000000000000000000000000002
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): 000c30f20f3c962e12309e0000000083
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Printing probed modes for output eDP
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x144.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x60.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1680x1050"x144.0 346.54 1680 1968 2000 2080 1050 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1280x1024"x144.0 346.54 1280 1968 2000 2080 1024 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1440x900"x144.0 346.54 1440 1968 2000 2080 900 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1280x800"x144.0 346.54 1280 1968 2000 2080 800 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1280x720"x144.0 346.54 1280 1968 2000 2080 720 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1024x768"x144.0 346.54 1024 1968 2000 2080 768 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "800x600"x144.0 346.54 800 1968 2000 2080 600 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "640x480"x144.0 346.54 640 1968 2000 2080 480 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Output eDP connected
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Using exact sizes for initial modes
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): mem size init: gart size :bf6ca000 vram size: s:1df2d000 visible:1df2d000
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): DPI set to (96, 96)
dez 15 01:04:25 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): [DRI2] Setup complete
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Front buffer pitch: 7680 bytes
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): SYNC extension fences enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Present extension enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): DRI3 enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): Backing store enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Direct rendering enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Use GLAMOR acceleration.
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Acceleration enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): DPMS enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (==) AMDGPU(0): Silken mouse enabled
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Set up textured video (glamor)
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Setting screen physical size to 508 x 285
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:26 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:04:27 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Allocate new frame buffer 4480x1440
dez 15 01:04:27 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): => pitch 17920 bytes
dez 15 01:04:28 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 01:04:28 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 01:04:28 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:28 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:04:33 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 01:04:33 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 01:04:33 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:33 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:04:36 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 15 01:04:36 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 15 01:04:36 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 15 01:04:36 omen-ricardof /usr/lib/gdm-x-session[2044]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 15 01:08:01 omen-ricardof gnome-shell[4597]: mesa: for the --amdgpu-atomic-optimizations option: may only occur zero or one times!
dez 15 01:12:08 omen-ricardof systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 01:12:08 omen-ricardof systemd[1]: systemd-backlight@backlight:amdgpu_bl1.service: Deactivated successfully.
dez 15 01:12:08 omen-ricardof systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 01:12:08 omen-ricardof audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Boot dce1060574e94dd0bae7be4ed296e0a1 --
dez 15 01:12:37 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 15 01:12:37 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 15 01:12:37 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 15 01:12:37 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 15 01:12:37 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PCIE atomic ops is not supported
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 15 01:12:37 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 15 01:12:37 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 15 01:12:37 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 15 01:12:38 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 15 01:12:38 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 15 01:12:38 omen-ricardof kernel: amdgpu: SRAT table not found
dez 15 01:12:38 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 15 01:12:38 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 15 01:12:38 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 15 01:12:38 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 15 01:12:38 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 15 01:12:38 omen-ricardof kernel: [drm] Initialized amdgpu 3.44.0 20150101 for 0000:06:00.0 on minor 1
dez 15 01:12:38 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 01:12:38 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 01:12:38 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Boot 628e36a2c14a41319d1575fbbfb26fcd --
dez 15 01:14:06 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 15 01:14:06 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 15 01:14:06 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 15 01:14:06 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 15 01:14:06 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PCIE atomic ops is not supported
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 15 01:14:06 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 15 01:14:06 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 15 01:14:06 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 15 01:14:07 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 15 01:14:07 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 15 01:14:07 omen-ricardof kernel: amdgpu: SRAT table not found
dez 15 01:14:07 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 15 01:14:07 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 15 01:14:07 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 15 01:14:07 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 15 01:14:07 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 15 01:14:07 omen-ricardof kernel: [drm] Initialized amdgpu 3.44.0 20150101 for 0000:06:00.0 on minor 1
dez 15 01:14:07 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 15 01:14:07 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 15 01:14:07 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Boot c2dc3d2c8036488faad33660bb9d0504 --
dez 17 01:38:50 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 17 01:38:50 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 17 01:38:50 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 17 01:38:50 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 17 01:38:50 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PCIE atomic ops is not supported
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 17 01:38:50 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 17 01:38:50 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 17 01:38:50 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 17 01:38:51 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 17 01:38:51 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 17 01:38:51 omen-ricardof kernel: amdgpu: SRAT table not found
dez 17 01:38:51 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 17 01:38:51 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 17 01:38:51 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 17 01:38:51 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 17 01:38:51 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 17 01:38:51 omen-ricardof kernel: [drm] Initialized amdgpu 3.44.0 20150101 for 0000:06:00.0 on minor 1
dez 17 01:38:51 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 17 01:38:51 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 17 01:38:51 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Boot a47c46386ec447ef84ee7f7cab775068 --
dez 17 01:40:10 omen-ricardof kernel: [drm] amdgpu kernel modesetting enabled.
dez 17 01:40:10 omen-ricardof kernel: amdgpu: Virtual CRAT table created for CPU
dez 17 01:40:10 omen-ricardof kernel: amdgpu: Topology: Add CPU node
dez 17 01:40:10 omen-ricardof kernel: fb0: switching to amdgpu from EFI VGA
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
dez 17 01:40:10 omen-ricardof kernel: amdgpu: ATOM BIOS: 113-CEZANNE-018
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
dez 17 01:40:10 omen-ricardof kernel: [drm] amdgpu: 512M of VRAM memory ready
dez 17 01:40:10 omen-ricardof kernel: [drm] amdgpu: 3072M of GTT memory ready.
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: PSP runtime database doesn't exist
dez 17 01:40:10 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
dez 17 01:40:11 omen-ricardof kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
dez 17 01:40:11 omen-ricardof kernel: amdgpu: HMM registered 512MB device memory
dez 17 01:40:11 omen-ricardof kernel: amdgpu: SRAT table not found
dez 17 01:40:11 omen-ricardof kernel: amdgpu: Virtual CRAT table created for GPU
dez 17 01:40:11 omen-ricardof kernel: amdgpu: Topology: Add dGPU node [0x1638:0x1002]
dez 17 01:40:11 omen-ricardof kernel: kfd kfd: amdgpu: added device 1002:1638
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
dez 17 01:40:11 omen-ricardof kernel: fbcon: amdgpu (fb0) is primary device
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpu frame buffer device
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
dez 17 01:40:11 omen-ricardof kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
dez 17 01:40:11 omen-ricardof kernel: [drm] Initialized amdgpu 3.42.0 20150101 for 0000:06:00.0 on minor 1
dez 17 01:40:11 omen-ricardof systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
dez 17 01:40:11 omen-ricardof systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
dez 17 01:40:11 omen-ricardof audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: loading driver: amdgpu
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) Matched amdgpu as autoconfigured driver 0
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) LoadModule: "amdgpu"
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) Module amdgpu: vendor="X.Org Foundation"
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU: Driver for AMD Radeon:
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: All GPUs supported by the amdgpu kernel driver
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Creating default Display subsection in Screen section
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): Default visual is TrueColor
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): RGB weight 888
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
dez 17 01:40:11 omen-ricardof /usr/lib/gdm-x-session[1440]: (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1638)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.42.0, 5.15.6-2-MANJARO, LLVM 13.0.0)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): glamor detected, initialising EGL layer.
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): TearFree property default: auto
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): VariableRefresh: disabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): KMS Pageflipping: enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Output eDP has no monitor section
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): EDID for output eDP
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Manufacturer: LGD Model: 5fe Serial#: 0
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Year: 2018 Week: 0
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): EDID Version: 1.4
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Digital Display Input
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 8 bits per channel
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Digital interface is DisplayPort
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Gamma: 2.20
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): First detailed timing is preferred mode
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.305 greenY: 0.605
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): blueX: 0.150 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Manufacturer's mask: 0
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Supported detailed timing:
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): clock: 346.5 MHz Image Size: 344 x 194 mm
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1157 v_border: 0
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): clock: 144.4 MHz Image Size: 344 x 194 mm
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Unknown vendor-specific block 2
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): EDID (in hex):
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 00ffffffffffff0030e4fe0500000000
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 001c0104a5221378eae085a3544e9b26
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 0e505400000001010101010101010101
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 0101010101015e8780a070384d403020
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 350058c21000001b683880a070384d40
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 3020350058c21000001b000000000000
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 00000000000000000000000000000002
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): 000c30f20f3c962e12309e0000000083
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Printing probed modes for output eDP
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1920x1080"x144.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1920x1080"x60.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1680x1050"x144.0 346.54 1680 1968 2000 2080 1050 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1280x1024"x144.0 346.54 1280 1968 2000 2080 1024 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1440x900"x144.0 346.54 1440 1968 2000 2080 900 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1280x800"x144.0 346.54 1280 1968 2000 2080 800 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1280x720"x144.0 346.54 1280 1968 2000 2080 720 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1024x768"x144.0 346.54 1024 1968 2000 2080 768 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "800x600"x144.0 346.54 800 1968 2000 2080 600 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "640x480"x144.0 346.54 640 1968 2000 2080 480 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Output eDP connected
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Using exact sizes for initial modes
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): mem size init: gart size :bf6ca000 vram size: s:1df2d000 visible:1df2d000
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): DPI set to (96, 96)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): [DRI2] Setup complete
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Front buffer pitch: 7680 bytes
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): SYNC extension fences enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Present extension enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): DRI3 enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): Backing store enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Direct rendering enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Use GLAMOR acceleration.
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Acceleration enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): DPMS enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (==) AMDGPU(0): Silken mouse enabled
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Set up textured video (glamor)
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Setting screen physical size to 508 x 285
dez 17 01:40:13 omen-ricardof /usr/lib/gdm-x-session[1440]: (EE) AMDGPU(0): Failed to make import prime FD as pixmap: 22
dez 17 01:40:14 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 17 01:40:14 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 17 01:40:14 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 17 01:40:14 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 17 01:40:14 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Allocate new frame buffer 4480x1440
dez 17 01:40:14 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): => pitch 17920 bytes
dez 17 01:40:15 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 17 01:40:15 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 17 01:40:15 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 17 01:40:15 omen-ricardof /usr/lib/gdm-x-session[1440]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: loading driver: amdgpu
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) Matched amdgpu as autoconfigured driver 0
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) LoadModule: "amdgpu"
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) Module amdgpu: vendor="X.Org Foundation"
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[1440]: (EE) AMDGPU(0): failed to set mode: Permission denied
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU: Driver for AMD Radeon:
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: All GPUs supported by the amdgpu kernel driver
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Creating default Display subsection in Screen section
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): Default visual is TrueColor
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): RGB weight 888
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1638)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.42.0, 5.15.6-2-MANJARO, LLVM 13.0.0)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): glamor detected, initialising EGL layer.
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): TearFree property default: auto
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): VariableRefresh: disabled
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): KMS Pageflipping: enabled
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Output eDP has no monitor section
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): EDID for output eDP
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Manufacturer: LGD Model: 5fe Serial#: 0
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Year: 2018 Week: 0
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): EDID Version: 1.4
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Digital Display Input
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 8 bits per channel
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Digital interface is DisplayPort
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Gamma: 2.20
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): First detailed timing is preferred mode
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.305 greenY: 0.605
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): blueX: 0.150 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Manufacturer's mask: 0
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Supported detailed timing:
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): clock: 346.5 MHz Image Size: 344 x 194 mm
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1157 v_border: 0
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): clock: 144.4 MHz Image Size: 344 x 194 mm
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Unknown vendor-specific block 2
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): EDID (in hex):
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 00ffffffffffff0030e4fe0500000000
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 001c0104a5221378eae085a3544e9b26
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 0e505400000001010101010101010101
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 0101010101015e8780a070384d403020
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 350058c21000001b683880a070384d40
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 3020350058c21000001b000000000000
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 00000000000000000000000000000002
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): 000c30f20f3c962e12309e0000000083
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Printing probed modes for output eDP
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1920x1080"x144.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1920x1080"x60.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1680x1050"x144.0 346.54 1680 1968 2000 2080 1050 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1280x1024"x144.0 346.54 1280 1968 2000 2080 1024 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1440x900"x144.0 346.54 1440 1968 2000 2080 900 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1280x800"x144.0 346.54 1280 1968 2000 2080 800 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1280x720"x144.0 346.54 1280 1968 2000 2080 720 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1024x768"x144.0 346.54 1024 1968 2000 2080 768 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "800x600"x144.0 346.54 800 1968 2000 2080 600 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "640x480"x144.0 346.54 640 1968 2000 2080 480 1083 1088 1157 +hsync -vsync (166.6 kHz e)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Output eDP connected
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Using exact sizes for initial modes
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): mem size init: gart size :bf6ca000 vram size: s:1df2d000 visible:1df2d000
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): DPI set to (96, 96)
dez 17 01:40:22 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): [DRI2] Setup complete
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Front buffer pitch: 7680 bytes
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): SYNC extension fences enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Present extension enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): DRI3 enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): Backing store enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Direct rendering enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Use GLAMOR acceleration.
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Acceleration enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): DPMS enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (==) AMDGPU(0): Silken mouse enabled
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Set up textured video (glamor)
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Setting screen physical size to 508 x 285
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Allocate new frame buffer 4480x1440
dez 17 01:40:23 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): => pitch 17920 bytes
dez 17 01:40:25 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): EDID vendor "LGD", prod id 1534
dez 17 01:40:25 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Printing DDC gathered Modelines:
dez 17 01:40:25 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 346.54 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (166.6 kHz eP)
dez 17 01:40:25 omen-ricardof /usr/lib/gdm-x-session[2510]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 144.40 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync (69.4 kHz e)
journalctl --grep="nvidia"
> Skipping already installed config 'video-hybrid-amd-nvidia-prime' for device: 0000:01:00.0 (0300:10de:249d) Display controller nVidia Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q]
> Skipping already installed config 'video-hybrid-amd-nvidia-prime' for device: 0000:06:00.0 (0300:1002:1638) Display controller ATI Technologies Inc Cezanne
I tried to do the last things you mentioned, the only thing they did was to improve the manjaro loading message on boot with a loading bar with points
