Hello, extremely new to Linux and Manjaro. Tried to install Manjaro on my laptop (not dual booting, it’s the only OS) and I can’t connect to wifi, all I get is “No available connections”
I’ve tried using my phone’s hotspot and tethering but neither have worked. I’m not really sure where to go from here.
Applogies for poor inxi output, had to take pic on phone then copy & paste text, so my phone may have misread somethings.
inxi output:
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
Desktop: KDE Plasma V: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Microsoft product: Surface Laptop
V: 124000000000000000000000D:F B:OC850289 F: U C:09 P:C1 S:01
serial: <superuser required> Chassis: type: 9
serial:
«superuser required>
Mobo: Microsoft model: Surface Laptop serial:
UEFI: Microsoft v: 138.3732.768 date: 04.20.2021
ID-1: BAT1 charge: 17.8 Wh (44.3%) condition: 40.2/45.2 Wh (88.9%)
volts: 7.5 min: 7.6 model: DYN M1005922 type: Li-ion serial: ‹filter>
status: discharging cycles: 188
RAM: total: 7.68 GiB used: 1.45 GiB (18.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: dual core model: Intel Core i5-7200U bits: 64 type: MT MCP
smt: enabled arch: Amber/Kaby Lake note: check rev: 9 cache: L1: 128 KiB
L2: 512 KiB 13. 3 MiR
Speed (MHz): avg: 1000 min/max: 400/3100 cores: 1: 1000 2: 1000 3: 1000
4: 1000 bogomips: 21607
therm dts epb ept ept_ad erms est f16c flexpriority flush_\1d fma fpu
intel_pt invpcid invpcid_single lahf_m m mca mce m_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pcimulqdq pacm
pdpe1gb pebs pge pin pi popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sabg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc deadline timer vme vmx vnmi
vpid x2apic ×getbv1 save xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel HD Graphics 620 vendor: Microsoft driver: 1915 v: kernel
arch: Gen-9.5 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Display: x11 server: X.0rg V: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev, vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63" )
s-diag: 716mm (28.19" )
Monitor-1: eDP-1 model: Panasonic WVX14T092N00 serial: «filter>
res: 2256x1504 hz: 60 dpi: 198 size: 290x190mm (11.42x7.48" )
diag: 343mm (13.5" ) modes: 2256x1504
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit driver: ipu3-imgu bus-ID: 00:05.0 chip-ID: 8086:1919 class-ID: 0480
Device-2: Intel CSI-2 Host driver: ipu3-cio2 bus-ID: 00:14.3
chip-ID: 8086: 9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00: 1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Marvell 88W8897 [AVATAR] 802.11ac Wireless driver: mwifiex pcie
v: 1.0 pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 11ab:2b38
class-ID: 0200
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 352.21 GiB used: 8.57 GiB (2.4%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 119.24 GiB
speed: 15.8 Gb/s lanes: 2 type: SSD serial: ‹filter> rev: OAMS0102
temp: 34.9 C scheme: GPT
ID-2: /dev/sda type: USB vendor: SanDisk model: USB 3.2Gen1
size: 232.97 GiB type: N/A serial: «filter> rev: 1.00 scheme: MBR
ID-1: / size: 116.52 GiB used: 8.57 GiB (7.4%) fs: ext4 dev: /dev/nvme0n1p2
label: N/A uuid: c982f334-99a6-499f-b293-ac3a5aa9cf52
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: NO_LABEL uuid: 9E9C-5C67
ID-1: /dev/sda1 size: 3.32 GiB fs: is09660
ID-2: /dev/sda2 size: 4 MiB fs: vfat label: MISO_EFI uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip-ID: 1d6b: 0003 class-ID: 0900
Device-1: 2-1:2 info: SanDisk Ultra type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5581 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42.0 C pch: 32.5 C mobo: N/A
Processes: 169 Uptime: 13m wakeups: 6 Init: systemd v: 251
default: graphical Compilers: gec: 12.1.1 clang: 14.0.6 Packages:
pacman: 1171 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
