Can someone help me with my audio?
I have an OMEN 30L Desktop GT13-1xxx PC and an NVIDIA 3060 Ti.
My question is the following:
Why is it that every time I start Manjaro, the volume sounds very low? Even if I turn it up, it doesn’t fix it. It only gets fixed when I put the PC to sleep and wake it up again — but doing that sometimes affects my video drivers. I discovered that unplugging and reconnecting the DisplayPort fixes the video issue.
In conclusion, the audio problem is only solved by putting the PC to sleep and waking it up.
Is there any way to make my Manjaro Linux work normally? Like Windows, for example?
Please provide your system information according to forum guidelines, as described (below).
I’m sure someone will help when they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – instead, please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
If running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
Try restoring ALSA settings:
sudo alsactl restore
If that is not effective, check ALSA mixer controls for the onboard audio
sudo alsamixer --card=PCH
Or to show mixer settings in text format
amixer --card=PCH scontents
Probe #2a05d09b63 of HP 886C Desktop Computer (OMEN 30L Desktop GT13-1xxx): amixer
