Can not resume from suspend, screen black with backlight
Hi.
I’m facing the problem that when trying to resume from suspend, the screen keeps black(but with backlight), I was trying to make suspend work normally on my laptop.
Based on the reason for the black with backlight, I guess the cause may be related to my graphics card driver, but I can’t be sure.
Here is part of my inxi -Fxz output:
  Kernel: 5.17.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    Desktop: GNOME 41.4 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: MECHREVO product: WUJIE16 Pro v: N/A
    serial: <superuser required>
  Mobo: MECHREVO model: WUJIE16 Pro serial: <superuser required>
    UEFI: American Megatrends v: Q3ANWJ.05 date: 03/02/2022
  ID-1: BAT0 charge: 70.0 Wh (98.9%) condition: 70.8/70.0 Wh (101.1%)
    volts: 13.2 min: 11.6 model: Ganfeng Smart-BAT status: Charging
  Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H
    bits: 64 type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.2 MiB
    L2: 11.5 MiB L3: 24 MiB
  Speed (MHz): avg: 693 high: 1102 min/max: 400/2300:1700 cores:
    1: 728 2: 1054 3: 705 4: 1102 5: 627 6: 621 7: 400 8: 679 9: 700
    10: 976 11: 675 12: 669 13: 801 14: 637 15: 428 16: 655 17: 596
    18: 620 19: 522 20: 669 bogomips: 107560
  Device-1: Intel Alder Lake-P Integrated Graphics driver: i915
    v: kernel bus-ID: 00:02.0
  Device-2: ELMCU RS 6088Cam type: USB driver: uvcvideo bus-ID: 3-5:2
  Display: wayland server: X.Org v: 1.22.1 with: Xwayland v: 22.1.0
    compositor: gnome-shell driver: gpu: i915 resolution: 2560x1600~120Hz
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 21.3.7
    direct render: Yes
Part of my journalctl output:3月 15 09:45:10 YUKI-N dbus-daemon[597]: [system] Activation via systemd failed f - Pastebin.com
3月 15 09:45:10 YUKI-N dbus-daemon[597]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
3月 15 09:45:10 YUKI-N gdm-password][4613]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
3月 15 09:45:12 YUKI-N systemd[1]: systemd-timedated.service: Deactivated successfully.
3月 15 09:45:12 YUKI-N audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:12 YUKI-N kernel: audit: type=1131 audit(1647308712.625:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:12 YUKI-N audit: BPF prog-id=0 op=UNLOAD
3月 15 09:45:12 YUKI-N kernel: audit: type=1334 audit(1647308712.651:152): prog-id=0 op=UNLOAD
3月 15 09:45:12 YUKI-N kernel: audit: type=1334 audit(1647308712.651:153): prog-id=0 op=UNLOAD
3月 15 09:45:12 YUKI-N kernel: audit: type=1334 audit(1647308712.651:154): prog-id=0 op=UNLOAD
3月 15 09:45:13 YUKI-N systemd[1]: fprintd.service: Deactivated successfully.
3月 15 09:45:13 YUKI-N audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:13 YUKI-N kernel: audit: type=1131 audit(1647308713.382:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:13 YUKI-N audit: BPF prog-id=0 op=UNLOAD
3月 15 09:45:13 YUKI-N kernel: audit: type=1334 audit(1647308713.402:156): prog-id=0 op=UNLOAD
3月 15 09:45:13 YUKI-N touchegg.desktop[1678]: Error connecting to Touchégg daemon: Could not connect: Connection refused
3月 15 09:45:13 YUKI-N touchegg.desktop[1678]: Reconnecting in 5 seconds...
3月 15 09:45:14 YUKI-N systemd-logind[601]: Power key pressed short.
3月 15 09:45:14 YUKI-N NetworkManager[598]: <info>  [1647308714.7414] manager: sleep: sleep requested (sleeping: no  enabled: yes)
3月 15 09:45:14 YUKI-N ModemManager[658]: <info>  [sleep-monitor] system is about to suspend
3月 15 09:45:14 YUKI-N NetworkManager[598]: <info>  [1647308714.7416] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:14 YUKI-N NetworkManager[598]: <info>  [1647308714.7420] device (74:0A:E1:19:7B:6F): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:14 YUKI-N NetworkManager[598]: <info>  [1647308714.7424] manager: NetworkManager state is now ASLEEP
3月 15 09:45:14 YUKI-N NetworkManager[598]: <info>  [1647308714.7426] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:14 YUKI-N gnome-shell[1337]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:14 YUKI-N gnome-shell[2964]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:14 YUKI-N gnome-shell[2961]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:14 YUKI-N gnome-shell[3548]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:14 YUKI-N gnome-shell[2960]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:14 YUKI-N dbus-daemon[597]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=598 comm="/usr/bin/NetworkManager --no-daemon ")
3月 15 09:45:14 YUKI-N systemd[1]: Starting Network Manager Script Dispatcher Service...
3月 15 09:45:14 YUKI-N dbus-daemon[597]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
3月 15 09:45:14 YUKI-N systemd[1]: Started Network Manager Script Dispatcher Service.
3月 15 09:45:14 YUKI-N audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:14 YUKI-N kernel: audit: type=1130 audit(1647308714.812:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:14 YUKI-N kernel: wlo1: deauthenticating from b2:95:e3:f0:60:67 by local choice (Reason: 3=DEAUTH_LEAVING)
3月 15 09:45:14 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-DISCONNECTED bssid=b2:95:e3:f0:60:67 reason=3 locally_generated=1
3月 15 09:45:14 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
3月 15 09:45:14 YUKI-N NetworkManager[598]: <info>  [1647308714.9933] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:15 YUKI-N NetworkManager[598]: <info>  [1647308715.0181] dhcp4 (wlo1): canceled DHCP transaction
3月 15 09:45:15 YUKI-N NetworkManager[598]: <info>  [1647308715.0182] dhcp4 (wlo1): state changed bound -> terminated
3月 15 09:45:15 YUKI-N NetworkManager[598]: <info>  [1647308715.0231] device (wlo1): set-hw-addr: set MAC address to A2:59:9B:49:FD:15 (scanning)
3月 15 09:45:15 YUKI-N gnome-shell[2964]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:15 YUKI-N gnome-shell[1337]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:15 YUKI-N gnome-shell[3548]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:15 YUKI-N NetworkManager[598]: <info>  [1647308715.0325] device (wlo1): supplicant interface state: completed -> disconnected
3月 15 09:45:15 YUKI-N gnome-shell[2960]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:15 YUKI-N NetworkManager[598]: <info>  [1647308715.0327] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:15 YUKI-N gnome-shell[2961]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:15 YUKI-N NetworkManager[598]: <info>  [1647308715.0366] device (wlo1): set-hw-addr: reset MAC address to 44:E5:17:F9:6E:47 (unmanage)
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=120 pid=3194 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2915]: dbus-daemon[2915]: [session uid=120 pid=2915] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=4307 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2909]: dbus-daemon[2909]: [session uid=120 pid=2909] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=4114 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2912]: dbus-daemon[2912]: [session uid=120 pid=2912] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=120 pid=3366 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2922]: dbus-daemon[2922]: [session uid=120 pid=2922] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=3547 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2912]: dbus-daemon[2912]: [session uid=120 pid=2912] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2915]: dbus-daemon[2915]: [session uid=120 pid=2915] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N gsd-sharing[3194]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N gsd-sharing[3366]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2909]: dbus-daemon[2909]: [session uid=120 pid=2909] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N gsd-sharing[4307]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N /usr/lib/gdm-wayland-session[2922]: dbus-daemon[2922]: [session uid=120 pid=2922] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N gsd-sharing[4114]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N gsd-sharing[3547]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:15 YUKI-N systemd[1]: Reached target Sleep.
3月 15 09:45:15 YUKI-N systemd[1]: Starting System Suspend...
3月 15 09:45:15 YUKI-N wpa_supplicant[903]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
3月 15 09:45:15 YUKI-N wpa_supplicant[903]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
3月 15 09:45:15 YUKI-N systemd-sleep[4643]: Entering sleep state 'suspend'...
3月 15 09:45:15 YUKI-N kernel: PM: suspend entry (deep)
3月 15 09:45:15 YUKI-N kernel: Filesystems sync: 0.012 seconds
3月 15 09:45:15 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
3月 15 09:45:15 YUKI-N wpa_supplicant[903]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
3月 15 09:45:22 YUKI-N kernel: Freezing user space processes ... (elapsed 0.353 seconds) done.
3月 15 09:45:22 YUKI-N kernel: OOM killer disabled.
3月 15 09:45:22 YUKI-N kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
3月 15 09:45:22 YUKI-N kernel: printk: Suspending console(s) (use no_console_suspend to debug)
3月 15 09:45:22 YUKI-N kernel: ------------[ cut here ]------------
3月 15 09:45:22 YUKI-N kernel: i915 0000:00:02.0: i915 raw-wakerefs=1 wakelocks=1 on cleanup
3月 15 09:45:22 YUKI-N kernel: WARNING: CPU: 4 PID: 2634 at drivers/gpu/drm/i915/intel_runtime_pm.c:629 intel_runtime_pm_driver_release+0x57/0x70 [i915]
3月 15 09:45:22 YUKI-N kernel: Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg bnep btusb btrtl btbcm btintel btmtk bluetooth ecdh_generic snd_soc_skl_hda_dsp snd_soc_intel_hda_dsp_common snd_soc_hdac_hdmi joydev snd_soc_dmic mousedev iTCO_wdt ee1004 intel_pmc_bxt iTCO_vendor_support hid_multitouch mei_hdcp intel_rapl_msr wmi_bmof intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel usbhid soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm
3月 15 09:45:22 YUKI-N kernel:  snd_hda_codec snd_hda_core intel_spi_pci snd_hwdep intel_spi mac80211 snd_pcm squashfs spi_nor i2c_i801 libarc4 iwlwifi mtd snd_timer loop i2c_smbus qrtr snd intel_lpss_pci soundcore intel_lpss mei_me mei cfg80211 idma64 rfkill pmt_telemetry vfat pmt_class fat processor_thermal_device_pci processor_thermal_device processor_thermal_rfim processor_thermal_mbox processor_thermal_rapl intel_rapl_common int340x_thermal_zone igen6_edac wmi i2c_hid_acpi i2c_hid tpm_crb tpm_tis tpm_tis_core tpm rng_core intel_hid int3400_thermal sparse_keymap acpi_thermal_rel acpi_tad acpi_pad mac_hid acpi_call(OE) ipmi_devintf ipmi_msghandler sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 crc32c_intel xhci_pci xhci_pci_renesas i8042 serio i915 intel_gtt video ttm
3月 15 09:45:22 YUKI-N kernel: CPU: 4 PID: 2634 Comm: kworker/u40:26 Tainted: G     U  W  OE     5.17.0-1-MANJARO #1 4f77b0a89bee9a649532a573ef03ea6bcc62098c
3月 15 09:45:22 YUKI-N kernel: Hardware name: MECHREVO WUJIE16 Pro/WUJIE16 Pro, BIOS Q3ANWJ.05 03/02/2022
3月 15 09:45:22 YUKI-N kernel: Workqueue: events_unbound async_run_entry_fn
3月 15 09:45:22 YUKI-N kernel: RIP: 0010:intel_runtime_pm_driver_release+0x57/0x70 [i915]
3月 15 09:45:22 YUKI-N kernel: Code: 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 d1 9e d2 e3 41 89 d8 44 89 e1 4c 89 ea 48 89 c6 48 c7 c7 78 a4 24 c0 e8 90 0c 13 e4 <0f> 0b 5b 41 5c 41 5d 31 c0 89 c2 89 c1 89 c6 89 c7 41 89 c0 c3 0f
3月 15 09:45:22 YUKI-N kernel: RSP: 0018:ffffb8dbc494fdb0 EFLAGS: 00010246
3月 15 09:45:22 YUKI-N kernel: RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000000
3月 15 09:45:22 YUKI-N kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
3月 15 09:45:22 YUKI-N kernel: RBP: ffffa01a02d80000 R08: 0000000000000000 R09: 0000000000000000
3月 15 09:45:22 YUKI-N kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001
3月 15 09:45:22 YUKI-N kernel: R13: ffffa01a02df1ce0 R14: ffffa01a0ddc6978 R15: ffffa01a00125605
3月 15 09:45:22 YUKI-N kernel: FS:  0000000000000000(0000) GS:ffffa01d9f700000(0000) knlGS:0000000000000000
3月 15 09:45:22 YUKI-N kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
3月 15 09:45:22 YUKI-N kernel: CR2: 00007fc044d2c0e8 CR3: 0000000316810005 CR4: 0000000000770ee0
3月 15 09:45:22 YUKI-N kernel: PKRU: 55555554
3月 15 09:45:22 YUKI-N kernel: Call Trace:
3月 15 09:45:22 YUKI-N kernel:  <TASK>
3月 15 09:45:22 YUKI-N kernel:  i915_drm_suspend_late+0xe2/0x100 [i915 cbb56bd175d1b3aa5fefa97fc60761e39bd635b3]
3月 15 09:45:22 YUKI-N kernel:  ? pci_pm_poweroff_late+0x40/0x40
3月 15 09:45:22 YUKI-N kernel:  dpm_run_callback+0x47/0x160
3月 15 09:45:22 YUKI-N kernel:  __device_suspend_late+0xc6/0x250
3月 15 09:45:22 YUKI-N kernel:  async_suspend_late+0x1b/0x90
3月 15 09:45:22 YUKI-N kernel:  async_run_entry_fn+0x2d/0x130
3月 15 09:45:22 YUKI-N kernel:  process_one_work+0x1e2/0x3b0
3月 15 09:45:22 YUKI-N kernel:  worker_thread+0x50/0x3a0
3月 15 09:45:22 YUKI-N kernel:  ? rescuer_thread+0x3a0/0x3a0
3月 15 09:45:22 YUKI-N kernel:  kthread+0xd6/0x100
3月 15 09:45:22 YUKI-N kernel:  ? kthread_complete_and_exit+0x20/0x20
3月 15 09:45:22 YUKI-N kernel:  ret_from_fork+0x1f/0x30
3月 15 09:45:22 YUKI-N kernel:  </TASK>
3月 15 09:45:22 YUKI-N kernel: ---[ end trace 0000000000000000 ]---
3月 15 09:45:22 YUKI-N kernel: ACPI: EC: interrupt blocked
3月 15 09:45:22 YUKI-N kernel: ACPI: PM: Preparing to enter system sleep state S3
3月 15 09:45:22 YUKI-N kernel: ACPI: EC: event blocked
3月 15 09:45:22 YUKI-N kernel: ACPI: EC: EC stopped
3月 15 09:45:22 YUKI-N kernel: ACPI: PM: Saving platform NVS memory
3月 15 09:45:22 YUKI-N kernel: Disabling non-boot CPUs ...
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 1 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 2 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 3 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 4 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 5 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 6 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 7 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 8 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 9 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 10 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 11 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 12 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 13 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 14 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 15 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 16 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 17 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 18 is now offline
3月 15 09:45:22 YUKI-N kernel: smpboot: CPU 19 is now offline
3月 15 09:45:22 YUKI-N kernel: ACPI: PM: Low-level resume complete
3月 15 09:45:22 YUKI-N kernel: ACPI: EC: EC started
3月 15 09:45:22 YUKI-N kernel: ACPI: PM: Restoring platform NVS memory
3月 15 09:45:22 YUKI-N kernel: Enabling non-boot CPUs ...
3月 15 09:45:22 YUKI-N kernel: x86: Booting SMP configuration:
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
3月 15 09:45:22 YUKI-N kernel: CPU1 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 2 APIC 0x8
3月 15 09:45:22 YUKI-N kernel: CPU2 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 3 APIC 0x9
3月 15 09:45:22 YUKI-N kernel: CPU3 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 4 APIC 0x10
3月 15 09:45:22 YUKI-N kernel: CPU4 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 5 APIC 0x11
3月 15 09:45:22 YUKI-N kernel: CPU5 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 6 APIC 0x18
3月 15 09:45:22 YUKI-N kernel: CPU6 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 7 APIC 0x19
3月 15 09:45:22 YUKI-N kernel: CPU7 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 8 APIC 0x20
3月 15 09:45:22 YUKI-N kernel: CPU8 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 9 APIC 0x21
3月 15 09:45:22 YUKI-N kernel: CPU9 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 10 APIC 0x28
3月 15 09:45:22 YUKI-N kernel: CPU10 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 11 APIC 0x29
3月 15 09:45:22 YUKI-N kernel: CPU11 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 12 APIC 0x30
3月 15 09:45:22 YUKI-N kernel: core: cpu_atom PMU driver: PEBS-via-PT
3月 15 09:45:22 YUKI-N kernel: ... version:                5
3月 15 09:45:22 YUKI-N kernel: ... bit width:              48
3月 15 09:45:22 YUKI-N kernel: ... generic registers:      6
3月 15 09:45:22 YUKI-N kernel: ... value mask:             0000ffffffffffff
3月 15 09:45:22 YUKI-N kernel: ... max period:             00007fffffffffff
3月 15 09:45:22 YUKI-N kernel: ... fixed-purpose events:   3
3月 15 09:45:22 YUKI-N kernel: ... event mask:             000000070000003f
3月 15 09:45:22 YUKI-N kernel: CPU12 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 13 APIC 0x32
3月 15 09:45:22 YUKI-N kernel: CPU13 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 14 APIC 0x34
3月 15 09:45:22 YUKI-N kernel: CPU14 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 15 APIC 0x36
3月 15 09:45:22 YUKI-N kernel: CPU15 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 16 APIC 0x38
3月 15 09:45:22 YUKI-N kernel: CPU16 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 17 APIC 0x3a
3月 15 09:45:22 YUKI-N kernel: CPU17 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 18 APIC 0x3c
3月 15 09:45:22 YUKI-N kernel: CPU18 is up
3月 15 09:45:22 YUKI-N kernel: smpboot: Booting Node 0 Processor 19 APIC 0x3e
3月 15 09:45:22 YUKI-N kernel: CPU19 is up
3月 15 09:45:22 YUKI-N kernel: ACPI: PM: Waking up from system sleep state S3
3月 15 09:45:22 YUKI-N kernel: ACPI: EC: interrupt unblocked
3月 15 09:45:22 YUKI-N kernel: ACPI: EC: event unblocked
3月 15 09:45:22 YUKI-N kernel: iwlwifi 0000:00:14.3: RF_KILL bit toggled to enable radio.
3月 15 09:45:22 YUKI-N kernel: iwlwifi 0000:00:14.3: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
3月 15 09:45:22 YUKI-N kernel: iwlwifi 0000:00:14.3: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
3月 15 09:45:22 YUKI-N kernel: iwlwifi 0000:00:14.3: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
3月 15 09:45:22 YUKI-N kernel: i915 0000:00:02.0: [drm] GuC firmware i915/adlp_guc_62.0.3.bin version 62.0 submission:enabled
3月 15 09:45:22 YUKI-N kernel: i915 0000:00:02.0: [drm] GuC SLPC: enabled
3月 15 09:45:22 YUKI-N kernel: i915 0000:00:02.0: [drm] HuC firmware i915/tgl_huc_7.9.3.bin version 7.9 authenticated:yes
3月 15 09:45:22 YUKI-N kernel: nvme nvme0: 16/0/0 default/read/poll queues
3月 15 09:45:22 YUKI-N kernel: i915 0000:00:02.0: [drm] GuC RC: enabled
3月 15 09:45:22 YUKI-N kernel: nvme nvme1: 8/0/0 default/read/poll queues
3月 15 09:45:22 YUKI-N kernel: xhci_hcd 0000:00:0d.0: xHC error in resume, USBSTS 0x401, Reinit
3月 15 09:45:22 YUKI-N kernel: usb usb1: root hub lost power or was reset
3月 15 09:45:22 YUKI-N kernel: usb usb2: root hub lost power or was reset
3月 15 09:45:22 YUKI-N kernel: usb 3-10: reset full-speed USB device number 3 using xhci_hcd
3月 15 09:45:22 YUKI-N kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Device revision is 2
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Secure boot is enabled
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: OTP lock is enabled
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: API lock is enabled
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Debug lock is disabled
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0040-4150.sfi
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Boot Address: 0x100800
3月 15 09:45:22 YUKI-N kernel: Bluetooth: hci0: Firmware Version: 190-51.21
3月 15 09:45:22 YUKI-N kernel: OOM killer enabled.
3月 15 09:45:22 YUKI-N kernel: Restarting tasks ... done.
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/ldac_hq
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/ldac_sq
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/ldac_mq
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSink/aptx_hd
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/aptx_hd
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc_xq_453
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc_xq_453
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc_xq_512
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc_xq_512
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc_xq_552
3月 15 09:45:22 YUKI-N bluetoothd[1264]: Endpoint unregistered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc_xq_552
3月 15 09:45:22 YUKI-N gnome-shell[2965]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:22 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Activating service name='org.freedesktop.secrets' requested by ':1.3' (uid=120 pid=2961 comm="/usr/bin/gnome-shell ")
3月 15 09:45:22 YUKI-N gnome-keyring-daemon[4690]: couldn't access control socket: /run/user/120/keyring/control: 没有那个文件或目录
3月 15 09:45:22 YUKI-N gnome-keyring-d[4690]: couldn't access control socket: /run/user/120/keyring/control: 没有那个文件或目录
3月 15 09:45:22 YUKI-N systemd[1289]: Stopped target Bluetooth.
3月 15 09:45:22 YUKI-N systemd[1]: Stopped target Bluetooth Support.
3月 15 09:45:22 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Successfully activated service 'org.freedesktop.secrets'
3月 15 09:45:22 YUKI-N systemd[2882]: Reached target Bluetooth.
3月 15 09:45:22 YUKI-N systemd[1289]: Reached target Bluetooth.
3月 15 09:45:22 YUKI-N systemd[1]: Reached target Bluetooth Support.
3月 15 09:45:22 YUKI-N systemd-sleep[4643]: System returned from sleep state.
3月 15 09:45:22 YUKI-N kernel: PM: suspend exit
3月 15 09:45:22 YUKI-N clash.desktop[1691]: time="2022-03-15T09:45:22+08:00" level=warning msg="[TCP] dial Ⓜ️ 微软服务 (match DomainSuffix/live.net) to apis.live.net:443 error: node-cn-xu.suvip.xyz:10000 connect error: dial tcp4 58.218.198.16:10000: connect: network is unreachable"
3月 15 09:45:22 YUKI-N clash.desktop[1691]: time="2022-03-15T09:45:22+08:00" level=warning msg="[TCP] dial Ⓜ️ 微软服务 (match DomainSuffix/live.com) to login.live.com:443 error: node-cn-xu.suvip.xyz:10000 connect error: dial tcp4 58.218.198.16:10000: connect: network is unreachable"
3月 15 09:45:22 YUKI-N systemd[1]: systemd-suspend.service: Deactivated successfully.
3月 15 09:45:22 YUKI-N systemd[1]: Finished System Suspend.
3月 15 09:45:22 YUKI-N audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:22 YUKI-N audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:22 YUKI-N systemd[1]: Stopped target Sleep.
3月 15 09:45:22 YUKI-N systemd[1]: Reached target Suspend.
3月 15 09:45:22 YUKI-N systemd[1]: Stopped target Suspend.
3月 15 09:45:22 YUKI-N systemd-logind[601]: Operation 'sleep' finished.
3月 15 09:45:22 YUKI-N kernel: audit: type=1130 audit(1647308722.850:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:22 YUKI-N kernel: audit: type=1131 audit(1647308722.850:159): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:22 YUKI-N ModemManager[658]: <info>  [sleep-monitor] system is resuming
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.8582] manager: sleep: wake requested (sleeping: yes  enabled: yes)
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.8583] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.8597] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.8603] manager: NetworkManager state is now DISCONNECTED
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.9010] device (wlo1): supplicant interface state: internal-starting -> disconnected
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.9010] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.9016] Wi-Fi P2P device controlled by interface wlo1 created
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.9019] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/6)
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.9022] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.9029] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
3月 15 09:45:22 YUKI-N NetworkManager[598]: <info>  [1647308722.9036] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:22 YUKI-N gnome-shell[3548]: Removing a network device that was not added
3月 15 09:45:22 YUKI-N gnome-shell[2965]: Removing a network device that was not added
3月 15 09:45:22 YUKI-N gnome-shell[2961]: Removing a network device that was not added
3月 15 09:45:22 YUKI-N gnome-shell[2964]: Removing a network device that was not added
3月 15 09:45:22 YUKI-N gnome-shell[1337]: Removing a network device that was not added
3月 15 09:45:22 YUKI-N gnome-shell[2960]: Removing a network device that was not added
3月 15 09:45:23 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read DPCD register 0x60
3月 15 09:45:23 YUKI-N clash.desktop[1691]: time="2022-03-15T09:45:23+08:00" level=warning msg="[TCP] dial Ⓜ️ 微软服务 (match DomainSuffix/live.net) to apis.live.net:443 error: node-cn-xu.suvip.xyz:10000 connect error: dial tcp4 58.218.198.16:10000: connect: network is unreachable"
3月 15 09:45:23 YUKI-N clash.desktop[1691]: time="2022-03-15T09:45:23+08:00" level=warning msg="[TCP] dial Ⓜ️ 微软服务 (match DomainSuffix/live.com) to login.live.com:443 error: node-cn-xu.suvip.xyz:10000 connect error: dial tcp4 58.218.198.16:10000: connect: network is unreachable"
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: Waiting for firmware download to complete
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: Firmware loaded in 1462843 usecs
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: unexpected event 0xff length: 5 > 0
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: Waiting for device to boot
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: Device booted in 17595 usecs
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: unexpected event 0xff length: 7 > 0
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-4150.ddc
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
3月 15 09:45:24 YUKI-N kernel: Bluetooth: hci0: Firmware timestamp 2021.51 buildtype 1 build 36030
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/ldac_hq
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/ldac_sq
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/ldac_mq
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSink/aptx_hd
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/aptx_hd
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc_xq_453
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc_xq_453
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc_xq_512
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc_xq_512
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSink/sbc_xq_552
3月 15 09:45:24 YUKI-N bluetoothd[1264]: Endpoint registered: sender=:1.91 path=/MediaEndpoint/A2DPSource/sbc_xq_552
3月 15 09:45:24 YUKI-N NetworkManager[598]: <info>  [1647308724.1885] manager: (74:0A:E1:19:7B:6F): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/7)
3月 15 09:45:24 YUKI-N NetworkManager[598]: <info>  [1647308724.1888] device (74:0A:E1:19:7B:6F): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
3月 15 09:45:24 YUKI-N NetworkManager[598]: <info>  [1647308724.1894] device (74:0A:E1:19:7B:6F): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:24 YUKI-N touchegg.desktop[1678]: Error connecting to Touchégg daemon: Could not connect: Connection refused
3月 15 09:45:24 YUKI-N touchegg.desktop[1678]: Reconnecting in 5 seconds...
3月 15 09:45:24 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read DPCD register 0x92
3月 15 09:45:25 YUKI-N ModemManager[658]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
3月 15 09:45:26 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to write source OUI
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DB
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6835] policy: auto-activating connection 'HONOR X10' (236de879-c033-4d5d-8ec7-23e5e95e537e)
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6839] device (wlo1): Activation: starting connection 'HONOR X10' (236de879-c033-4d5d-8ec7-23e5e95e537e)
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6839] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6841] manager: NetworkManager state is now CONNECTING
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6843] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6845] device (wlo1): Activation: (wifi) access point 'HONOR X10' has security, but secrets are required.
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6846] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6854] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6856] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6858] device (wlo1): Activation: (wifi) connection 'HONOR X10' has security, and secrets exist.  No new secrets needed.
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6858] Config: added 'ssid' value 'HONOR X10'
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6858] Config: added 'scan_ssid' value '1'
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6858] Config: added 'bgscan' value 'simple:30:-70:86400'
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6858] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.6859] Config: added 'psk' value '<hidden>'
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: SME: Trying to authenticate with b2:95:e3:f0:60:67 (SSID='HONOR X10' freq=2462 MHz)
3月 15 09:45:26 YUKI-N kernel: wlo1: authenticate with b2:95:e3:f0:60:67
3月 15 09:45:26 YUKI-N kernel: wlo1: 80 MHz not supported, disabling VHT
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.7300] device (wlo1): supplicant interface state: disconnected -> authenticating
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.7301] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> authenticating
3月 15 09:45:26 YUKI-N kernel: wlo1: send auth to b2:95:e3:f0:60:67 (try 1/3)
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: Trying to associate with b2:95:e3:f0:60:67 (SSID='HONOR X10' freq=2462 MHz)
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.7626] device (wlo1): supplicant interface state: authenticating -> associating
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.7627] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
3月 15 09:45:26 YUKI-N kernel: wlo1: authenticated
3月 15 09:45:26 YUKI-N kernel: wlo1: associate with b2:95:e3:f0:60:67 (try 1/3)
3月 15 09:45:26 YUKI-N kernel: wlo1: RX AssocResp from b2:95:e3:f0:60:67 (capab=0x631 status=0 aid=5)
3月 15 09:45:26 YUKI-N kernel: wlo1: associated
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: Associated with b2:95:e3:f0:60:67
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.8151] device (wlo1): supplicant interface state: associating -> 4way_handshake
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.8151] device (p2p-dev-wlo1): supplicant management interface state: associating -> 4way_handshake
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: WPA: Key negotiation completed with b2:95:e3:f0:60:67 [PTK=CCMP GTK=CCMP]
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-CONNECTED - Connection to b2:95:e3:f0:60:67 completed [id=0 id_str=]
3月 15 09:45:26 YUKI-N kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9359] device (wlo1): supplicant interface state: 4way_handshake -> completed
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9359] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "HONOR X10"
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9359] device (p2p-dev-wlo1): supplicant management interface state: 4way_handshake -> completed
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9361] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-28 noise=9999 txrate=26000
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9364] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9603] dhcp4 (wlo1): state changed unknown -> bound, address=192.168.43.138
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9622] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9631] policy: set 'HONOR X10' (wlo1) as default for IPv4 routing and DNS
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2922]: dbus-daemon[2922]: [session uid=120 pid=2922] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=3547 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2912]: dbus-daemon[2912]: [session uid=120 pid=2912] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=120 pid=3366 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2915]: dbus-daemon[2915]: [session uid=120 pid=2915] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=4307 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2909]: dbus-daemon[2909]: [session uid=120 pid=2909] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=4114 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=120 pid=3194 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9718] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2912]: dbus-daemon[2912]: [session uid=120 pid=2912] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2922]: dbus-daemon[2922]: [session uid=120 pid=2922] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9720] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2915]: dbus-daemon[2915]: [session uid=120 pid=2915] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N /usr/lib/gdm-wayland-session[2909]: dbus-daemon[2909]: [session uid=120 pid=2909] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N gsd-sharing[3366]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N gsd-sharing[3194]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N gsd-sharing[4307]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N gsd-sharing[3547]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N gsd-sharing[4114]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9724] manager: NetworkManager state is now CONNECTED_SITE
3月 15 09:45:26 YUKI-N NetworkManager[598]: <info>  [1647308726.9733] device (wlo1): Activation: successful, device activated.
3月 15 09:45:27 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-28 noise=9999 txrate=26000
3月 15 09:45:27 YUKI-N NetworkManager[598]: <info>  [1647308727.4246] manager: NetworkManager state is now CONNECTED_GLOBAL
3月 15 09:45:28 YUKI-N systemd-logind[601]: Lid closed.
3月 15 09:45:28 YUKI-N NetworkManager[598]: <info>  [1647308728.3313] policy: set 'HONOR X10' (wlo1) as default for IPv6 routing and DNS
3月 15 09:45:29 YUKI-N touchegg.desktop[1678]: Error connecting to Touchégg daemon: Could not connect: Connection refused
3月 15 09:45:29 YUKI-N touchegg.desktop[1678]: Reconnecting in 5 seconds...
3月 15 09:45:30 YUKI-N systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
3月 15 09:45:30 YUKI-N audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:30 YUKI-N kernel: audit: type=1131 audit(1647308730.311:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:31 YUKI-N systemd-logind[601]: Lid opened.
3月 15 09:45:32 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* [ENCODER:235:DDI A/PHY A][DPRX] Failed to enable link training
3月 15 09:45:33 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read DPCD register 0x60
3月 15 09:45:34 YUKI-N touchegg.desktop[1678]: Error connecting to Touchégg daemon: Could not connect: Connection refused
3月 15 09:45:34 YUKI-N touchegg.desktop[1678]: Reconnecting in 5 seconds...
3月 15 09:45:34 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read DPCD register 0x92
3月 15 09:45:35 YUKI-N clash.desktop[1691]: time="2022-03-15T09:45:35+08:00" level=warning msg="[TCP] dial Ⓜ️ 微软服务 (match DomainSuffix/live.net) to apis.live.net:443 error: node-cn-xu.suvip.xyz:10000 connect error: dial tcp4 58.218.198.16:10000: i/o timeout"
3月 15 09:45:36 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read DPCD register 0x60
3月 15 09:45:38 YUKI-N kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read DPCD register 0x92
3月 15 09:45:39 YUKI-N touchegg.desktop[1678]: Error connecting to Touchégg daemon: Could not connect: Connection refused
3月 15 09:45:39 YUKI-N touchegg.desktop[1678]: Reconnecting in 5 seconds...
3月 15 09:45:40 YUKI-N clash.desktop[1691]: time="2022-03-15T09:45:40+08:00" level=warning msg="[TCP] dial Ⓜ️ 微软服务 (match DomainSuffix/live.com) to login.live.com:443 error: node-cn-xu.suvip.xyz:10000 connect error: dial tcp4 58.218.198.16:10000: i/o timeout"
3月 15 09:45:42 YUKI-N systemd-logind[601]: Power key pressed short.
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.2664] manager: sleep: sleep requested (sleeping: no  enabled: yes)
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.2665] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.2670] device (74:0A:E1:19:7B:6F): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:42 YUKI-N ModemManager[658]: <info>  [sleep-monitor] system is about to suspend
3月 15 09:45:42 YUKI-N gnome-shell[2961]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.2673] manager: NetworkManager state is now ASLEEP
3月 15 09:45:42 YUKI-N gnome-shell[3548]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:42 YUKI-N gnome-shell[2960]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.2674] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:42 YUKI-N gnome-shell[2964]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:42 YUKI-N gnome-shell[1337]: Failed to enter power saving mode: drmModeAtomicCommit: 权限不够
3月 15 09:45:42 YUKI-N dbus-daemon[597]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=598 comm="/usr/bin/NetworkManager --no-daemon ")
3月 15 09:45:42 YUKI-N systemd[1]: Starting Network Manager Script Dispatcher Service...
3月 15 09:45:42 YUKI-N dbus-daemon[597]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
3月 15 09:45:42 YUKI-N systemd[1]: Started Network Manager Script Dispatcher Service.
3月 15 09:45:42 YUKI-N audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:42 YUKI-N kernel: audit: type=1130 audit(1647308742.319:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
3月 15 09:45:42 YUKI-N kernel: wlo1: deauthenticating from b2:95:e3:f0:60:67 by local choice (Reason: 3=DEAUTH_LEAVING)
3月 15 09:45:42 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-DISCONNECTED bssid=b2:95:e3:f0:60:67 reason=3 locally_generated=1
3月 15 09:45:42 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
3月 15 09:45:42 YUKI-N wpa_supplicant[903]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-9999 noise=9999 txrate=0
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.4647] device (wlo1): supplicant interface state: completed -> disconnected
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.4648] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.4963] dhcp4 (wlo1): canceled DHCP transaction
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.4963] dhcp4 (wlo1): state changed bound -> terminated
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.4990] device (wlo1): set-hw-addr: set MAC address to 66:F7:DB:49:25:C4 (scanning)
3月 15 09:45:42 YUKI-N gnome-shell[2960]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:42 YUKI-N gnome-shell[2964]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:42 YUKI-N gnome-shell[2961]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:42 YUKI-N gnome-shell[1337]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:42 YUKI-N gnome-shell[3548]: An active wireless connection, in infrastructure mode, involves no access point?
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.5035] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
3月 15 09:45:42 YUKI-N NetworkManager[598]: <info>  [1647308742.5058] device (wlo1): set-hw-addr: reset MAC address to 44:E5:17:F9:6E:47 (unmanage)
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=120 pid=3194 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2922]: dbus-daemon[2922]: [session uid=120 pid=2922] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=3547 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2909]: dbus-daemon[2909]: [session uid=120 pid=2909] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=4114 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2912]: dbus-daemon[2912]: [session uid=120 pid=2912] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=120 pid=3366 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2915]: dbus-daemon[2915]: [session uid=120 pid=2915] Activating service name='org.freedesktop.systemd1' requested by ':1.12' (uid=120 pid=4307 comm="/usr/lib/gsd-sharing ")
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2911]: dbus-daemon[2911]: [session uid=120 pid=2911] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2909]: dbus-daemon[2909]: [session uid=120 pid=2909] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2912]: dbus-daemon[2912]: [session uid=120 pid=2912] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2922]: dbus-daemon[2922]: [session uid=120 pid=2922] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N gsd-sharing[4114]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N /usr/lib/gdm-wayland-session[2915]: dbus-daemon[2915]: [session uid=120 pid=2915] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N gsd-sharing[3194]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N gsd-sharing[3366]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N gsd-sharing[4307]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N gsd-sharing[3547]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
3月 15 09:45:42 YUKI-N systemd[1]: Reached target Sleep.
3月 15 09:45:42 YUKI-N systemd[1]: Starting System Suspend...
3月 15 09:45:42 YUKI-N wpa_supplicant[903]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
3月 15 09:45:42 YUKI-N wpa_supplicant[903]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
3月 15 09:45:42 YUKI-N systemd-sleep[4887]: Entering sleep state 'suspend'...
3月 15 09:45:42 YUKI-N kernel: PM: suspend entry (deep)
What I’ve DONE:
  • Turn on the i915 module Early KFS
  • Search Internet for a long time
THX FOR ANY HELP!
Tell me I lack any information needed or language that not so proper
Honestly, that kernel is still a RC. Please try a LTS kernel or 5.16 as is a bit more mature than the RC … Also i would suggest to go trough this Power management/Suspend and hibernate - ArchWiki
Hello, do you have any news? I have same issue. Thx in advance.
Seems like this is a workaround we need.
