Can not get my Qanba Obsidian 2 to register correctly
Even with steam input, my obsidian 2 will not register the circle button being pressed and a few other buttons, i have tried so many work around and so far i have had no luck at all. my ps5 controller works fine i tried a hitbox as well and no anvil.
Welcome to the forum. To increase your chances to get help please post the output of inxi -zv8 enclosed in three backticks (``` that is preformatted text, also available under the + icon). Moreover, what did you try already? I don’t own a Qanba Obsidian 2 but it seems to come with different operation modes like PC or PS4 is this right? If so did you try all the modes already?
Yes, when i switched it to pc mode it changes the buttons that don’t work its strange
Ok so, i tried messing with xinput, and with the manjaro controller utilty and the same issue arises.
sorry if this isnt very helpful
Welcome to the Manjaro community @kama1
As requested earlier by @jofi, please provide the output of:
inxi -zv8
Please be aware that any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions :point_down:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks:
or three tildes:
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
How to Request Support
As a new or infrequent forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
inxi --filter --verbosity=8
inxi -zv8
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
So like this?
Hi @kama1
Yes, and no.
Only code, commands or command output needs to be displayed as pre-formatted text – most everything else should be treated as normal text or markdown.
You have been asked to provide your system information – this is typically needed for others to help you effectively.
The command to use is simple: inxi -zv8, and the generated output of the command is your system information, which should be presented as pre-formatted text.
See the Mini-HowTo’s (below). :point_down:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
With respect your issue:
Please provide a more in depth description of the problem. While you may know what you are asking, those reading, who might wish to help might not understand.
  • Remember, nobody but you lives inside your head. :slight_smile:
  • You need to fully explain the problem for others.
The following are not direct questions to answer. They are examples to illustrate that more information is needed.
  • What is an Obsidian 2? It may be a game, but your question assumes we should know that already (I’ve not heard of it).
  • What is a circle button? We can presume it’s a button on a PS5 controller since you mentioned the PS5, but those who don’t have a PlayStation would likely not know what you are asking.
  • What exactly have you tried? Some may suggest things you have already tried, but didn’t work. This wastes time, and frankly is an annoyance, when all you had to do was explain what you’ve done from the beginning.
A non-gamer, or someone who has never played Obsidian 2 will have no idea what you’re talking about.
Please see Forum Rules: How to Post.
Hopefully, you begin to “get the picture”.
 inxi -zv8
  Kernel: 6.18.33-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=cdd7af94-cb75-4d70-b5ca-7f2e3fe9c760 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.26.0
  Type: Desktop Mobo: Gigabyte model: B550M DS3H v: x.x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: F10 date: 09/18/2020
  System RAM: total: 16 GiB available: 15.54 GiB used: 9.96 GiB (64.1%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMW16GX4M2C3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3563 min/max: 561/4654 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3563 2: 3563 3: 3563
    4: 3563 5: 3563 6: 3563 7: 3563 8: 3563 9: 3563 10: 3563 11: 3563 12: 3563
    bogomips: 88625
    vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-1
    code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1
    bus-ID: 0b:00.0 chip-ID: 1002:731f class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: ViewSonic XG2401 SERIES serial: <filter>
    built: 2019 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 92 gamma: 1.2
    chroma: red: x: 0.647 y: 0.329 green: x: 0.310 y: 0.620 blue: x: 0.153
    y: 0.071 white: x: 0.314 y: 0.329 size: 531x299mm (20.91x11.77")
    diag: 609mm (24") ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050,
    1400x1050, 1280x1024, 1440x900, 1280x960, 1152x864, 1280x720, 1024x768,
    832x624, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.1-arch1.2 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 5600 XT (radeonsi navi10 ACO DRM
    3.64 6.18.33-1-MANJARO) device-ID: 1002:731f memory: 5.86 GiB unified: no
    display-ID: :1.0
  API: Vulkan v: 1.4.350 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5600 XT (RADV NAVI10) driver: mesa radv v: 26.1.1-arch1.2
    device-ID: 1002:731f surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.18.33-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
    lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.27 TiB used: 299.04 GiB (12.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
    used: 299.04 GiB (64.2%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: cdd7af94-cb75-4d70-b5ca-7f2e3fe9c760
    used: 664 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: F80B-0274
  ID-3: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-4: /var/cache raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-5: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: bitlocker
    label: JANE D: 10/28/2025 uuid: 480554ee-0a68-4d5f-8dd3-e92d02d5f5cb
  Device-1: 1-3:5 info: QANBA USA LLC Obsidian 2 Arcade Joystick type: HID
    driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 2c22:2703 class-ID: ff00 serial: <filter>
  Device-2: 1-6:2 info: Corsair DARK CORE RGB PRO Gaming Dongle
    type: mouse,HID,keyboard driver: hid-generic,usbhid interfaces: 6 rev: 2.0
    chip-ID: 1b1c:1b81 class-ID: 0301 serial: <filter>
  Device-3: 1-10:3 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-1: 3-4:3 info: Corsair K65 RGB MINI 60% Mechanical Gaming Keyboard
    type: keyboard,HID,mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
    chip-ID: 1b1c:1bc3 class-ID: 0301 serial: <filter>
  System Temperatures: cpu: 53.6 C mobo: 35.0 C gpu: amdgpu temp: 56.0 C
    mem: 56.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1595 libs: 403 tools: pamac pm: flatpak pkgs: 0
    1: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    5: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    6: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    7: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 361
  1: cpu: 5.8% command: exe pid: 2232 mem: 658.1 MiB (4.1%)
  2: cpu: 3.8% command: konsole pid: 88129 mem: 152.6 MiB (0.9%)
  3: cpu: 3.3% command: firefox pid: 2296 mem: 701.0 MiB (4.4%)
  4: cpu: 2.4% command: zsh pid: 88154 mem: 10.3 MiB (0.0%)
  5: cpu: 2.0% command: steamwebhelper pid: 6207 mem: 137.0 MiB (0.8%)
  Memory top: 5 of 361
  1: mem: 2963.4 MiB (18.6%) command: firefox pid: 68554 cpu: 0.4%
  2: mem: 934.8 MiB (5.8%) command: firefox pid: 8401 cpu: 1.1%
  3: mem: 701.0 MiB (4.4%) command: firefox pid: 2296 cpu: 3.3%
  4: mem: 658.1 MiB (4.1%) command: exe pid: 2232 cpu: 5.8%
  5: mem: 607.6 MiB (3.8%) command: steamwebhelper pid: 6302 cpu: 1.9%
  Processes: 361 Power: uptime: 10h 58m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.5 gcc: 16.1.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
I’m a friend of hers, so I will supply some information since she’s been busy.
  • She did a bad job explaining, but a Qanba Obsidian 2 and what she called a “hitbox” are both game controllers. Both of them have the capability to emulate other kinds of controllers, like Xbox and Nintendo Switch controllers, and she tried changing the kind of controller emulated.
  • I had her try loading the kernel modules for xbox and playstation controllers with sudo modprobe hid-playstation and sudo modprobe xpad and verified they were loaded with lsmod. We also made sure the drivers were installed with sudo pacman -Syu joystick. I think she also tried turning off steam input and looking around in the KDE Plasma settings for controller related stuff.
Her problem is that some buttons don’t work where the hardware does and it’s the same buttons (PlayStation X button for example) across multiple controllers except her PS5 controller works fine.
