For example, if I want to choose the first 3 columns, on VS code I can use Alt+Left click and drag on TexStudio I can use Ctrl+Left click and drag, but how can I do that on Kate?
In Kate you can use the Block Selection Mode from the Edit menu item.
The default key binding to toggle this mode on/off is Ctrl+Shift+b.
KDE docs:
https://docs.kde.org/stable5/en/applications/katepart/kate-part-selection.html
