I really wanna use Java 11 But I dont know if its supported
goto discover.manjaro.org search and you will find …
Just install the appropriate package and take a look at Java - ArchWiki
Open TLauncher then open Settings.
Next set the Java Path to your javaw.exe. Something like C:\Program Files (x86)\Java\jdk-16.0.1\bin\javaw.exe
Then set the JVM Arguments to -XX:+IgnoreUnrecognizedVMOptions
