If I do not use HP computers and printers, can I uninstall hp-uiscan?
I do not know if it will hurt some system settings.
hp-uiscan
is part of the hplip
package. You can safely remove it, but you may need to also remove manjaro-printer
if it’s installed because it depends on it. You can always reinstall things like cups
later if you ever need to print.
https://wiki.manjaro.org/index.php?title=Printing
so that I can use manjaro-printer
without hp-uiscan
and HP device manager
manjaro-printer
is just a meta package for the printing software packages. If you only want some of them, first make note of the packages it depends on:
pamac info manjaro-printer
Remove manjaro-printer
then reinstall the packages you want.
Couldn’t you simply mark the parts of the program you want to keep as explicitly installed beforehand to save reinstalling them?
sudo pacman -D --asexplicit cups
Just an idea …
Yes, indeed.
