Perhaps a stupid question: Can I set a certain audio device to be used as a default using wireplumber - and can this setting be made permanent so that it survives a reboot?
Problem is that I cannot determine if this is a wireplumber or an xfce problem. Hence the two posts.
Here’s what’s happening:
I can successfully set the default device as I wish using wpctl set-default {DeviceID}. Verifying the setting in wpctl status indicates that the change was successful:
├─ Sinks:
│ 34. Internes Audio Analog Stereo [vol: 0.74]
│ * 48. GM107 High Definition Audio Controller [GeForce 940MX] Digital Stereo (HDMI) [vol: 0.70]
However, after restarting the machine, the setting is reverted:
├─ Sinks:
│ * 34. Internes Audio Analog Stereo [vol: 0.74]
│ 48. GM107 High Definition Audio Controller [GeForce 940MX] Digital Stereo (HDMI) [vol: 0.70]
Why does it not seem possible to make that setting permanent?
