Hey there,
I want to get a reading of the power level of my CPU, unfortunately k10-temp is only showing Vcore and Icore:
$ sensors
k10temp-pci-00c3
Adapter: PCI adapter
Vcore: 1.41 V
Vsoc: 1.13 V
Tctl: +43.0°C
Tdie: +43.0°C
Icore: 33.00 A
Isoc: 10.75 A
Since power can easily be calculated by multiplying the two, ie Power=Icore*Vcore, I was wondering if it is possible to create another “sensor” as such?
Which I then could in turn monitor in my favorite monitoring software (ksysguard).
Actually they don’t, the k10-temp is developed by the community.
Furthermore even if, that’s really not the answer your expecting in a community forum. If I wanted to ask AMD, I would have done so directly and not posted in forum where user help other users…
