Hi!
From running checkrebuild
I get the following result:
]$ checkrebuild
foreign electron13
foreign electron18
foreign electron9
foreign protonmail-import-export-app-bin
foreign synology-drive
Sorry, for asking stupid questions. But, why does for example protonmail-import-export-app-bin
and synology-drive
still work on my system, despite getting this result?
And, can I simply remove the above listed electron packages, without messing up my system?
Notes:
I looked at What to do with rebuild-detector results, and tried rebuilding electron9
ninja: build stopped: subcommand failed.
==> ERROR: A failure occurred in build().
Aborting...
Afterwards I found that:
electron9
was dropped to the AUR from the Arch community repo recently (source)
checkrebuild -v
foreign electron13
foreign electron18
foreign electron9
ldd /usr/lib/protonmail/import-export/qml/QtWebView/libdeclarative_webview.so
/usr/lib/protonmail/import-export/qml/QtWebView/libdeclarative_webview.so: /usr/lib/protonmail/import-export/qml/QtWebView/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebView.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtWebChannel/libdeclarative_webchannel.so
/usr/lib/protonmail/import-export/qml/QtWebChannel/libdeclarative_webchannel.so: /usr/lib/protonmail/import-export/qml/QtWebChannel/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebChannel.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtWebEngine/libqtwebengineplugin.so
/usr/lib/protonmail/import-export/qml/QtWebEngine/libqtwebengineplugin.so: /usr/lib/protonmail/import-export/qml/QtWebEngine/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebEngine.so.5)
/usr/lib/protonmail/import-export/qml/QtWebEngine/libqtwebengineplugin.so: /usr/lib/protonmail/import-export/qml/QtWebEngine/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebChannel.so.5)
/usr/lib/protonmail/import-export/qml/QtWebEngine/libqtwebengineplugin.so: /usr/lib/protonmail/import-export/qml/QtWebEngine/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/qml/QtWebEngine/libqtwebengineplugin.so: /usr/lib/protonmail/import-export/qml/QtWebEngine/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtTest/libqmltestplugin.so
/usr/lib/protonmail/import-export/qml/QtTest/libqmltestplugin.so: /usr/lib/protonmail/import-export/qml/QtTest/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QuickTest.so.5)
/usr/lib/protonmail/import-export/qml/QtTest/libqmltestplugin.so: /usr/lib/protonmail/import-export/qml/QtTest/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Test.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtWebSockets/libdeclarative_qmlwebsockets.so
/usr/lib/protonmail/import-export/qml/QtWebSockets/libdeclarative_qmlwebsockets.so: /usr/lib/protonmail/import-export/qml/QtWebSockets/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebSockets.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtSensors/libdeclarative_sensors.so
/usr/lib/protonmail/import-export/qml/QtSensors/libdeclarative_sensors.so: /usr/lib/protonmail/import-export/qml/QtSensors/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sensors.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtScxml/libdeclarative_scxml.so
/usr/lib/protonmail/import-export/qml/QtScxml/libdeclarative_scxml.so: /usr/lib/protonmail/import-export/qml/QtScxml/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Scxml.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtRemoteObjects/libqtremoteobjects.so
/usr/lib/protonmail/import-export/qml/QtRemoteObjects/libqtremoteobjects.so: /usr/lib/protonmail/import-export/qml/QtRemoteObjects/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5RemoteObjects.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/libqtquickvirtualkeyboardplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/libqtquickvirtualkeyboardplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/XmlListModel/libqmlxmllistmodelplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/XmlListModel/libqmlxmllistmodelplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/XmlListModel/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5XmlPatterns.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/Styles/libqtquickvirtualkeyboardstylesplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/Styles/libqtquickvirtualkeyboardstylesplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/Styles/../../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/Settings/libqtquickvirtualkeyboardsettingsplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/Settings/libqtquickvirtualkeyboardsettingsplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/VirtualKeyboard/Settings/../../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/Shapes/libqmlshapesplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/Shapes/libqmlshapesplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/Shapes/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QuickShapes.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/Scene3D/libqtquickscene3dplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/Scene3D/libqtquickscene3dplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/Scene3D/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt53DAnimation.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/Scene2D/libqtquickscene2dplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/Scene2D/libqtquickscene2dplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/Scene2D/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt53DQuickScene2D.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQuick/LocalStorage/libqmllocalstorageplugin.so
/usr/lib/protonmail/import-export/qml/QtQuick/LocalStorage/libqmllocalstorageplugin.so: /usr/lib/protonmail/import-export/qml/QtQuick/LocalStorage/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sql.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtQml/RemoteObjects/libqtqmlremoteobjects.so
/usr/lib/protonmail/import-export/qml/QtQml/RemoteObjects/libqtqmlremoteobjects.so: /usr/lib/protonmail/import-export/qml/QtQml/RemoteObjects/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5RemoteObjects.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtPurchasing/libdeclarative_purchasing.so
/usr/lib/protonmail/import-export/qml/QtPurchasing/libdeclarative_purchasing.so: /usr/lib/protonmail/import-export/qml/QtPurchasing/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Purchasing.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtPositioning/libdeclarative_positioning.so
/usr/lib/protonmail/import-export/qml/QtPositioning/libdeclarative_positioning.so: /usr/lib/protonmail/import-export/qml/QtPositioning/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/qml/QtPositioning/libdeclarative_positioning.so: /usr/lib/protonmail/import-export/qml/QtPositioning/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtNfc/libdeclarative_nfc.so
/usr/lib/protonmail/import-export/qml/QtNfc/libdeclarative_nfc.so: /usr/lib/protonmail/import-export/qml/QtNfc/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Nfc.so.5)
/usr/lib/protonmail/import-export/qml/QtNfc/libdeclarative_nfc.so: /usr/lib/protonmail/import-export/qml/QtNfc/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5DBus.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtLocation/libdeclarative_location.so
/usr/lib/protonmail/import-export/qml/QtLocation/libdeclarative_location.so: /usr/lib/protonmail/import-export/qml/QtLocation/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/qml/QtLocation/libdeclarative_location.so: /usr/lib/protonmail/import-export/qml/QtLocation/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/qml/QtLocation/libdeclarative_location.so: /usr/lib/protonmail/import-export/qml/QtLocation/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/qml/QtLocation/libdeclarative_location.so: /usr/lib/protonmail/import-export/qml/QtLocation/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/qml/Qt/labs/location/liblocationlabsplugin.so
/usr/lib/protonmail/import-export/qml/Qt/labs/location/liblocationlabsplugin.so: /usr/lib/protonmail/import-export/qml/Qt/labs/location/../../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/qml/Qt/labs/location/liblocationlabsplugin.so: /usr/lib/protonmail/import-export/qml/Qt/labs/location/../../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/qml/Qt/labs/location/liblocationlabsplugin.so: /usr/lib/protonmail/import-export/qml/Qt/labs/location/../../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/qml/Qt/labs/location/liblocationlabsplugin.so: /usr/lib/protonmail/import-export/qml/Qt/labs/location/../../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtDataVisualization/libdatavisualizationqml2.so
/usr/lib/protonmail/import-export/qml/QtDataVisualization/libdatavisualizationqml2.so: /usr/lib/protonmail/import-export/qml/QtDataVisualization/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5DataVisualization.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtCharts/libqtchartsqml2.so
/usr/lib/protonmail/import-export/qml/QtCharts/libqtchartsqml2.so: /usr/lib/protonmail/import-export/qml/QtCharts/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Charts.so.5)
ldd /usr/lib/protonmail/import-export/qml/QtBluetooth/libdeclarative_bluetooth.so
/usr/lib/protonmail/import-export/qml/QtBluetooth/libdeclarative_bluetooth.so: /usr/lib/protonmail/import-export/qml/QtBluetooth/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Bluetooth.so.5)
/usr/lib/protonmail/import-export/qml/QtBluetooth/libdeclarative_bluetooth.so: /usr/lib/protonmail/import-export/qml/QtBluetooth/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5DBus.so.5)
ldd /usr/lib/protonmail/import-export/qml/Qt3D/Animation/libquick3danimationplugin.so
/usr/lib/protonmail/import-export/qml/Qt3D/Animation/libquick3danimationplugin.so: /usr/lib/protonmail/import-export/qml/Qt3D/Animation/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt53DQuickAnimation.so.5)
/usr/lib/protonmail/import-export/qml/Qt3D/Animation/libquick3danimationplugin.so: /usr/lib/protonmail/import-export/qml/Qt3D/Animation/../../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt53DAnimation.so.5)
ldd /usr/lib/protonmail/import-export/plugins/webview/libqtwebview_webengine.so
/usr/lib/protonmail/import-export/plugins/webview/libqtwebview_webengine.so: /usr/lib/protonmail/import-export/plugins/webview/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebView.so.5)
/usr/lib/protonmail/import-export/plugins/webview/libqtwebview_webengine.so: /usr/lib/protonmail/import-export/plugins/webview/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebEngine.so.5)
/usr/lib/protonmail/import-export/plugins/webview/libqtwebview_webengine.so: /usr/lib/protonmail/import-export/plugins/webview/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebChannel.so.5)
/usr/lib/protonmail/import-export/plugins/webview/libqtwebview_webengine.so: /usr/lib/protonmail/import-export/plugins/webview/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/webview/libqtwebview_webengine.so: /usr/lib/protonmail/import-export/plugins/webview/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_thai.so
/usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_thai.so: /usr/lib/protonmail/import-export/plugins/virtualkeyboard/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_tcime.so
/usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_tcime.so: /usr/lib/protonmail/import-export/plugins/virtualkeyboard/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sqldrivers/libqsqlpsql.so
/usr/lib/protonmail/import-export/plugins/sqldrivers/libqsqlpsql.so: /usr/lib/protonmail/import-export/plugins/sqldrivers/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sql.so.5)
libpq.so.5 => not found
ldd /usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_openwnn.so
/usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_openwnn.so: /usr/lib/protonmail/import-export/plugins/virtualkeyboard/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_pinyin.so
/usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_pinyin.so: /usr/lib/protonmail/import-export/plugins/virtualkeyboard/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/plugins/texttospeech/libqtexttospeech_speechd.so
/usr/lib/protonmail/import-export/plugins/texttospeech/libqtexttospeech_speechd.so: /usr/lib/protonmail/import-export/plugins/texttospeech/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5TextToSpeech.so.5)
libspeechd.so.2 => not found
ldd /usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_hangul.so
/usr/lib/protonmail/import-export/plugins/virtualkeyboard/libqtvirtualkeyboard_hangul.so: /usr/lib/protonmail/import-export/plugins/virtualkeyboard/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sqldrivers/libqsqlodbc.so
/usr/lib/protonmail/import-export/plugins/sqldrivers/libqsqlodbc.so: /usr/lib/protonmail/import-export/plugins/sqldrivers/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sql.so.5)
libodbc.so.2 => not found
ldd /usr/lib/protonmail/import-export/plugins/sqldrivers/libqsqlite.so
/usr/lib/protonmail/import-export/plugins/sqldrivers/libqsqlite.so: /usr/lib/protonmail/import-export/plugins/sqldrivers/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sql.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sensors/libqtsensors_linuxsys.so
/usr/lib/protonmail/import-export/plugins/sensors/libqtsensors_linuxsys.so: /usr/lib/protonmail/import-export/plugins/sensors/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sensors.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sensors/libqtsensors_iio-sensor-proxy.so
/usr/lib/protonmail/import-export/plugins/sensors/libqtsensors_iio-sensor-proxy.so: /usr/lib/protonmail/import-export/plugins/sensors/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sensors.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sensors/libqtsensors_generic.so
/usr/lib/protonmail/import-export/plugins/sensors/libqtsensors_generic.so: /usr/lib/protonmail/import-export/plugins/sensors/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sensors.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sensorgestures/libqtsensorgestures_shakeplugin.so
/usr/lib/protonmail/import-export/plugins/sensorgestures/libqtsensorgestures_shakeplugin.so: /usr/lib/protonmail/import-export/plugins/sensorgestures/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sensors.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sensorgestures/libqtsensorgestures_plugin.so
/usr/lib/protonmail/import-export/plugins/sensorgestures/libqtsensorgestures_plugin.so: /usr/lib/protonmail/import-export/plugins/sensorgestures/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sensors.so.5)
ldd /usr/lib/protonmail/import-export/plugins/sceneparsers/libassimpsceneimport.so
/usr/lib/protonmail/import-export/plugins/sceneparsers/libassimpsceneimport.so: /usr/lib/protonmail/import-export/plugins/sceneparsers/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt53DAnimation.so.5)
ldd /usr/lib/protonmail/import-export/plugins/renderplugins/libscene2d.so
/usr/lib/protonmail/import-export/plugins/renderplugins/libscene2d.so: /usr/lib/protonmail/import-export/plugins/renderplugins/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt53DQuickScene2D.so.5)
ldd /usr/lib/protonmail/import-export/plugins/position/libqtposition_serialnmea.so
/usr/lib/protonmail/import-export/plugins/position/libqtposition_serialnmea.so: /usr/lib/protonmail/import-export/plugins/position/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/position/libqtposition_serialnmea.so: /usr/lib/protonmail/import-export/plugins/position/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialPort.so.5)
ldd /usr/lib/protonmail/import-export/plugins/position/libqtposition_positionpoll.so
/usr/lib/protonmail/import-export/plugins/position/libqtposition_positionpoll.so: /usr/lib/protonmail/import-export/plugins/position/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
ldd /usr/lib/protonmail/import-export/plugins/position/libqtposition_geoclue2.so
/usr/lib/protonmail/import-export/plugins/position/libqtposition_geoclue2.so: /usr/lib/protonmail/import-export/plugins/position/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
ldd /usr/lib/protonmail/import-export/plugins/position/libqtposition_geoclue.so
/usr/lib/protonmail/import-export/plugins/position/libqtposition_geoclue.so: /usr/lib/protonmail/import-export/plugins/position/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
ldd /usr/lib/protonmail/import-export/plugins/platforms/libqwebgl.so
/usr/lib/protonmail/import-export/plugins/platforms/libqwebgl.so: /usr/lib/protonmail/import-export/plugins/platforms/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebSockets.so.5)
ldd /usr/lib/protonmail/import-export/plugins/printsupport/libcupsprintersupport.so
/usr/lib/protonmail/import-export/plugins/printsupport/libcupsprintersupport.so: /usr/lib/protonmail/import-export/plugins/printsupport/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PrintSupport.so.5)
ldd /usr/lib/protonmail/import-export/plugins/platforms/libqeglfs.so
/usr/lib/protonmail/import-export/plugins/platforms/libqeglfs.so: /usr/lib/protonmail/import-export/plugins/platforms/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5EglFSDeviceIntegration.so.5)
ldd /usr/lib/protonmail/import-export/plugins/platforminputcontexts/libqtvirtualkeyboardplugin.so
/usr/lib/protonmail/import-export/plugins/platforminputcontexts/libqtvirtualkeyboardplugin.so: /usr/lib/protonmail/import-export/plugins/platforminputcontexts/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5VirtualKeyboard.so.5)
ldd /usr/lib/protonmail/import-export/plugins/mediaservice/libgstmediaplayer.so
/usr/lib/protonmail/import-export/plugins/mediaservice/libgstmediaplayer.so: /usr/lib/protonmail/import-export/plugins/mediaservice/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5MultimediaWidgets.so.5)
ldd /usr/lib/protonmail/import-export/plugins/mediaservice/libgstmediacapture.so
/usr/lib/protonmail/import-export/plugins/mediaservice/libgstmediacapture.so: /usr/lib/protonmail/import-export/plugins/mediaservice/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5MultimediaWidgets.so.5)
ldd /usr/lib/protonmail/import-export/plugins/mediaservice/libgstcamerabin.so
/usr/lib/protonmail/import-export/plugins/mediaservice/libgstcamerabin.so: /usr/lib/protonmail/import-export/plugins/mediaservice/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5MultimediaWidgets.so.5)
ldd /usr/lib/protonmail/import-export/plugins/mediaservice/libgstaudiodecoder.so
/usr/lib/protonmail/import-export/plugins/mediaservice/libgstaudiodecoder.so: /usr/lib/protonmail/import-export/plugins/mediaservice/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5MultimediaWidgets.so.5)
ldd /usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_nokia.so
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_nokia.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_nokia.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_nokia.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_nokia.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_osm.so
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_osm.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_osm.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_osm.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_osm.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapboxgl.so
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapboxgl.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapboxgl.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapboxgl.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapboxgl.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Sql.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapboxgl.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapbox.so
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapbox.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapbox.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapbox.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_mapbox.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_itemsoverlay.so
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_itemsoverlay.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_itemsoverlay.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_itemsoverlay.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_itemsoverlay.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_esri.so
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_esri.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Location.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_esri.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PositioningQuick.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_esri.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/geoservices/libqtgeoservices_esri.so: /usr/lib/protonmail/import-export/plugins/geoservices/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
ldd /usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebEngineWidgets.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Designer.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5PrintSupport.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Xml.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5WebChannel.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Positioning.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QmlModels.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqwebengineview.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5QuickWidgets.so.5)
ldd /usr/lib/protonmail/import-export/plugins/egldeviceintegrations/libqeglfs-x11-integration.so
/usr/lib/protonmail/import-export/plugins/egldeviceintegrations/libqeglfs-x11-integration.so: /usr/lib/protonmail/import-export/plugins/egldeviceintegrations/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5EglFSDeviceIntegration.so.5)
ldd /usr/lib/protonmail/import-export/plugins/egldeviceintegrations/libqeglfs-kms-egldevice-integration.so
/usr/lib/protonmail/import-export/plugins/egldeviceintegrations/libqeglfs-kms-egldevice-integration.so: /usr/lib/protonmail/import-export/plugins/egldeviceintegrations/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5EglFSDeviceIntegration.so.5)
ldd /usr/lib/protonmail/import-export/plugins/egldeviceintegrations/libqeglfs-emu-integration.so
/usr/lib/protonmail/import-export/plugins/egldeviceintegrations/libqeglfs-emu-integration.so: /usr/lib/protonmail/import-export/plugins/egldeviceintegrations/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5EglFSDeviceIntegration.so.5)
ldd /usr/lib/protonmail/import-export/plugins/designer/libqquickwidget.so
/usr/lib/protonmail/import-export/plugins/designer/libqquickwidget.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Designer.so.5)
/usr/lib/protonmail/import-export/plugins/designer/libqquickwidget.so: /usr/lib/protonmail/import-export/plugins/designer/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Xml.so.5)
ldd /usr/lib/protonmail/import-export/plugins/canbus/libqttinycanbus.so
/usr/lib/protonmail/import-export/plugins/canbus/libqttinycanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialBus.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqttinycanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Network.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqttinycanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialPort.so.5)
ldd /usr/lib/protonmail/import-export/plugins/canbus/libqtvirtualcanbus.so
/usr/lib/protonmail/import-export/plugins/canbus/libqtvirtualcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialBus.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqtvirtualcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialPort.so.5)
ldd /usr/lib/protonmail/import-export/plugins/canbus/libqtsocketcanbus.so
/usr/lib/protonmail/import-export/plugins/canbus/libqtsocketcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialBus.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqtsocketcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Network.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqtsocketcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialPort.so.5)
ldd /usr/lib/protonmail/import-export/plugins/canbus/libqtpeakcanbus.so
/usr/lib/protonmail/import-export/plugins/canbus/libqtpeakcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialBus.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqtpeakcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Network.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqtpeakcanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialPort.so.5)
ldd /usr/lib/protonmail/import-export/plugins/canbus/libqtpassthrucanbus.so
/usr/lib/protonmail/import-export/plugins/canbus/libqtpassthrucanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialBus.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqtpassthrucanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5Network.so.5)
/usr/lib/protonmail/import-export/plugins/canbus/libqtpassthrucanbus.so: /usr/lib/protonmail/import-export/plugins/canbus/../../lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5SerialPort.so.5)
ldd /usr/lib/protonmail/import-export/lib/libQt5MultimediaGstTools.so.5
/usr/lib/protonmail/import-export/lib/libQt5MultimediaGstTools.so.5: /usr/lib/protonmail/import-export/lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5MultimediaWidgets.so.5)
ldd /usr/lib/protonmail/import-export/lib/libQt5EglFsKmsSupport.so.5
/usr/lib/protonmail/import-export/lib/libQt5EglFsKmsSupport.so.5: /usr/lib/protonmail/import-export/lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /usr/lib/libQt5EglFSDeviceIntegration.so.5)
ldd /usr/lib/nautilus/extensions-4/libnautilus-drive-extension-4.so
libnautilus-extension.so.4 => not found
ldd /usr/lib/nautilus/extensions-3.0/libnautilus-drive-extension.so
libnautilus-extension.so.1 => not found
ldd /usr/lib/electron9/electron
libicui18n.so.71 => not found
libicuuc.so.71 => not found
libavcodec.so.59 => not found
libavformat.so.59 => not found
libavutil.so.57 => not found
libvpx.so.7 => not found
libre2.so.9 => not found
libFLAC.so.8 => not found
ldd /usr/lib/electron18/electron
ldd /usr/lib/electron13/electron
ldd /opt/Synology/SynologyDrive/package/cloudstation/icon-overlay/15/lib/plugin-cb.so
ldd /opt/Synology/SynologyDrive/package/cloudstation/bin/cloud-drive-ui
libicuuc.so.64 => not found
libfct-qt.so.1 => not found
ldd /opt/Synology/SynologyDrive/package/cloudstation/icon-overlay/15/lib/plugin-cb-4.so
ldd /opt/Synology/SynologyDrive/package/cloudstation/bin/cloud-drive-daemon
libprotobuf.so.17 => not found
ldd /opt/Synology/SynologyDrive/package/cloudstation/bin/cloud-drive-auto-updater
ldd /opt/Synology/SynologyDrive/package/cloudstation/bin/cloud-drive-cleaner
ldd /opt/Synology/SynologyDrive/bin/launcher
