I injure one of my finger, and have to voice-type… but bluetooth doesn’t work pair with motherboard. Can you fix bluetooth, so I can use on-screen keyboard to voice type. E-mails, texting, and calling using Signal (Signal (messaging app) - Wikipedia) on Manjaro is kinda important. Thanks.
You’ve already been reminded of the Forum Rules which includes How to Post.
Please also see [HowTo] Request support and provide more details accordingly.
Bluetooth pairs, or “connects” and then, “disconnected” message… why? Why i cannot connect with bluetooth and stay connected… why have to switch to different kernel… why have to apply all these workarounds like on internet. Is possible to have google keyboard on Manjaro with gboard voice assist (https://play.google.com/store/apps/details?id=com.google.android.inputmethod.latin&hl=en&gl=US&pli=1, Use Google Assistant to type with your voice - Gboard Help, The best dictation and speech-to-text software in 2024 | Zapier)… If bluetooth doesn’t work at manjaro kernal-level, or connect, how will it work on android emulator…
Using linux requires having to read forums and troubleshoot things. without knowing your CPU, motherboard, and other system information it is really hard to help Users out, even some basic error logs to why your bluetooth is disconnecting would help us out greatly
there are different kernels in your system because some work better on different hardware and some of them are for testing branch purposes only, they also have kernels that are for LTS which stands for LONG TERM SUPPORT, these will have 5 years of security updates and bug fixes,
Linux requires solving problems, and you will run into issues at some point and will have to read thoroughly through forums to find an answer and some help, I hope your problem gets solved soon
are you trying to connect your phone by chance? if so look into KDE connect it might be a better option
Not “we”, but you.
So far, “we” don’t know anything about your hardware.
Without knowing that, “we” can’t even begin to make meaningful suggestions.
It should be obvious to you that this is not nearly enough information - and thus no one could tell you “why?”.
inxi -Fazy
and
system logs capturing the fruitless connection attempts would give “us” something to go on.
for instance:
journalctl -f
in a terminal, while you attempt to connect and it fails
copy/paste all that and “we” might have a clue.
(the command creates output as things happen - a live view on what the system sees currently happening)
All the best for you and your finger!
I hope you don’t get a cold as well - impairing your speech.
Kernel: 6.8.7-lqx2-1-lqx arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: hpet,acpi_pm parameters: audit=0
intel_pstate=disable rcupdate.rcu_expedited=1
BOOT_IMAGE=/@/boot/vmlinuz-linux-lqx
root=UUID=60ee5189-9367-426e-853f-4c641fe50397 rw rootflags=subvol=@ quiet
apparmor=1 amdgpu.ppfeaturemask=0xffffffff amd_iommu=on iommu=pt iommu=1
video=efifb:off disable_idle_d3=1 vfio-pci.ids= 1002:73df
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B650M MORTAR WIFI (MS-7D76) v: 2.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: A.10 date: 10/19/2022
Info: model: AMD Ryzen 5 7600X bits: 64 type: MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 5 smt: <unsupported> cache: L1: 320 KiB
desc: d-5x32 KiB; i-5x32 KiB L2: 5 MiB desc: 5x1024 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2359 high: 5300 min/max: 400/6149 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5299 2: 5300 3: 400
4: 400 5: 400 bogomips: 52996
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none empty: Writeback-2
bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 37.0 C
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Acer EI491CR serial: <filter>
built: 2019 res: 3840x1080 hz: 60 dpi: 81 gamma: 1.2
size: 1200x340mm (47.24x13.39") diag: 1242mm (48.9") modes: max: 3840x1080
min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
navi22 LLVM 16.0.6 DRM 3.57 6.8.7-lqx2-1-lqx) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.0.2-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Micro-Star MSI
bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 0db0:7696 class-ID: 0300
API: ALSA v: k6.8.7-lqx2-1-lqx status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-2: virbr0 state: down mac: <filter>
Info: services: NetworkManager
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:7 chip-ID: 0e8d:0616
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 8.31 TiB used: 4.39 TiB (52.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: MSI model: M461 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFMC1.0 temp: 25.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: MSI model: M461 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFMC1.0 temp: 32.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X1960G
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Fanxiang model: S500Pro 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 model: N/A size: 117.19 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
used: 126.8 GiB (26.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
compressor: lz4 max-pool: 20%
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 41.4 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 38.0 C mem: 54.0 C fan: 0 watts: 12.00
Memory: total: N/A available: 58.53 GiB used: 3.08 GiB (5.3%)
Processes: 348 Power: uptime: 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 23.4 GiB services: csd-power,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1831 libs: 515 tools: pamac,paru,yay pm: flatpak
pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: gnome-terminal inxi: 3.3.34
May 03 08:57:27 ap3i-ms7d76 blueman-manager[3193]: blueman-manager 08.57.27 WARNING DeviceList:193 set_adapter: Failed to set adapter, trying first available.
May 03 08:58:01 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=04:7c:16:4f:90:8c:9c:3d:cf:55:dd:e9:08:00 SRC=165.154.33.72 DST=10.0.0.4 LEN=44 TOS=0x00 PREC=0x60 TTL=29 ID=0 DF PROTO=TCP SPT=33060 DPT=8010 WINDOW=1024 RES=0x00 SYN URGP=0
May 03 08:58:11 ap3i-ms7d76 systemd[1530]: Reached target Bluetooth.
May 03 08:58:13 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
May 03 08:58:15 ap3i-ms7d76 bluetoothd[1494]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 58:FC:C6:3E:84:D6: Software caused connection abort (103)
May 03 08:58:15 ap3i-ms7d76 blueman-manager[3193]: blueman-manager 08.58.15 WARNING ManagerDeviceMenu:145 fail : fail g-dbus-error-quark: GDBus.Error:org.freedesktop.DBus.Error.Failed: blueman.bluez.errors.DBusFailedError: br-connection-canceled
May 03 08:58:15 ap3i-ms7d76 blueman-manager[3193]: (0)
May 03 08:58:35 ap3i-ms7d76 bluetoothd[1494]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 58:FC:C6:3E:84:D6: Software caused connection abort (103)
May 03 08:58:35 ap3i-ms7d76 blueman-manager[3193]: blueman-manager 08.58.35 WARNING ManagerDeviceMenu:145 fail : fail g-dbus-error-quark: GDBus.Error:org.freedesktop.DBus.Error.Failed: blueman.bluez.errors.DBusFailedError: br-connection-canceled
May 03 08:58:35 ap3i-ms7d76 blueman-manager[3193]: (0)
May 03 09:00:19 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
May 03 09:02:24 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
May 03 09:04:16 ap3i-ms7d76 systemd[1]: Starting Cleanup of Temporary Directories...
May 03 09:04:17 ap3i-ms7d76 systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
May 03 09:04:17 ap3i-ms7d76 systemd[1]: Finished Cleanup of Temporary Directories.
May 03 09:04:30 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
May 03 09:06:35 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
May 03 09:08:40 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
May 03 09:10:38 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=04:7c:16:4f:90:8c:9c:3d:cf:55:dd:e9:08:00 SRC=64.112.75.2 DST=10.0.0.4 LEN=436 TOS=0x08 PREC=0x20 TTL=29 ID=33015 DF PROTO=UDP SPT=5308 DPT=5060 LEN=416
May 03 09:10:46 ap3i-ms7d76 kernel: [UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Did you see what you posted?
Looked back at what you gave us?
Please format it as code
this symbol: </>
so it looks like the terminal output that you saw
<pre>May 03 08:57:27 ap3i-ms7d76 blueman-manager[3193]: blueman-manager 08.57.27 WARNING DeviceList:193 set_adapter: Failed to set adapter, trying first available.
May 03 08:58:01 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=04:7c:16:4f:90:8c:9c:3d:cf:55:dd:e9:08:00 SRC=165.154.33.72 DST=10.0.0.4 LEN=44 TOS=0x00 PREC=0x60 TTL=29 ID=0 DF PROTO=TCP SPT=33060 DPT=8010 WINDOW=1024 RES=0x00 SYN URGP=0 </b></font>
May 03 08:58:13 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 </b></font>
May 03 08:58:15 ap3i-ms7d76 bluetoothd[1494]: <font color="#C01C28"><b>src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 58:FC:C6:3E:84:D6: Software caused connection abort (103)</b></font>
May 03 08:58:35 ap3i-ms7d76 bluetoothd[1494]: <font color="#C01C28"><b>src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 58:FC:C6:3E:84:D6: Software caused connection abort (103)</b></font>
May 03 09:00:19 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 </b></font>
May 03 09:02:24 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 </b></font>
May 03 09:04:30 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 </b></font>
May 03 09:06:35 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 </b></font>
May 03 09:08:40 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 </b></font>
May 03 09:10:38 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=04:7c:16:4f:90:8c:9c:3d:cf:55:dd:e9:08:00 SRC=64.112.75.2 DST=10.0.0.4 LEN=436 TOS=0x08 PREC=0x20 TTL=29 ID=33015 DF PROTO=UDP SPT=5308 DPT=5060 LEN=416 </b></font>
May 03 09:10:46 ap3i-ms7d76 kernel: <font color="#D7D75F"><b>[UFW BLOCK] IN=enp14s0 OUT= MAC=01:00:5e:00:00:01:9c:3d:cf:55:dd:e9:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 </b></font>
</pre>
I am don’t know if formatted correctly, but i “copy as html” and paste in between </> like you said
Why?
Simply mark the terminal output and copy then paste.
(I have never even seen the option to “copy as html” when in a terminal)
Terminal output is just text - not html.
If it looks the same as in your terminal, it was correct.
If it doesn’t look like that … it wasn’t correct.
BTW:
not another post - just go back and edit the previous one …
ps:
just like that
Thank you!
Also, whilst considering the onscreen option … personally I can’t imagine a single finger preventing typing (or was it bound to another finger?).
I favour the following:
When passing text to my wife (and I can’t type Thai, so I always use this for Thai) I open Telegram on my phone/tablet and dictate from a mobile device… this because text to speech isn’t trivial… and mobile devices are already well set up to make it easy.
Directly on the computer, a microphone works well with cloud services, especially for inputting text to translate and either copying it directly, or copying a translation.
No, it wasn’t bound to another finger, per say, but my finger is pretty busted… I kinda really need an all-around, voice-typing for Manjaro operating system… like system-wide… if possible… I kind of feel helpless and vulnerable… almost disabled… can this be something of the future…?
Thanks, Nachlese.
