Since the last system update (stable update 2026-08-23), the camera isn’t working correctly in any program (the camera activates but the image isn’t displayed). This happens on both my computers: a desktop PC with an external camera connected via USB, and a laptop with an integrated camera, and it affects both the KDE and XFCE desktop environments. Before this update, the camera worked fine in all programs.
If I revert the update (using Timeshift), the camera image is displayed correctly again. Is anyone else experiencing this or know of a possible solution? Thank you very much.
I’m not. I’m not aware of any other reports, which doesn’t mean there won’t be.
Please provide your system information in accordance with forum guidelines – See the Mini-HowTo’s (below)
– Perhaps others with similar systems might experience something similar.
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
Hello @jotabe and welcome to the Manjaro Community!
Whilst I might not be able to help with your specific issue (I haven’t experienced this yet myself), it will help if you can furnish us with some System Information.
To this end, could you provide the output of this Terminal command? (quick guide below):
inxi -zv8
Note that the output produced by this command is privacy-filtered.
Please also remember to use proper code formatting as this makes it much easier to read on the Forum:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks
or three tildes
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Cheers! ![]()
I don’t have it too. So it is probably driver related, in which case the exact hardware is relevant. Besides inxi, lsusb can also be useful for troubleshooting.
Also note that sometimes several “fake cameras” are available in theory in the apps - i have 3 according to the video4linux driver, but of course only one, the real one, works. Be sure to check the drop down menu in the app and check for other devices.
Thank you for your responses and interest. Here is the inxi output on my desktop computer:
❯ inxi -zv8
Kernel: 6.18.45-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
root=UUID=6d6ae727-21c3-463c-a677-b46950b9d916 rw quiet splash
udev.log_priority=3 resume=UUID=31f4b41c-9198-4ebe-9faf-d07f32ab7a9d
Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
Mobo: ASUSTeK model: TUF GAMING B760M-PLUS II v: Rev 1.xx
Firmware: UEFI vendor: American Megatrends v: 1836 date: 04/16/2026
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 32 GiB available: 31.09 GiB used: 3.94 GiB (12.7%)
Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Controller0-DIMM0 type: no module installed
Device-2: Controller0-DIMM1 type: DDR5 detail: synchronous size: 16 GiB
speed: 4800 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMK32GX5M2B6400C32
serial: N/A
Device-3: Controller1-DIMM0 type: no module installed
Device-4: Controller1-DIMM1 type: DDR5 detail: synchronous size: 16 GiB
serial: N/A
Info: model: Intel Core i7-14700F bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x137
Topology: cpus: 1x dies: 1 clusters: 11 cores: 20 threads: 28 mt: 8 tpc: 2
st: 12 smt: enabled cache: L1: 1.8 MiB desc: d-12x32 KiB, 8x48 KiB; i-8x32
KiB, 12x64 KiB L2: 28 MiB desc: 8x2 MiB, 3x4 MiB L3: 33 MiB desc: 1x33 MiB
Speed (MHz): avg: 800 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 bogomips: 118272
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 610.57.04 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-6xx.xx+ status: current (as of 2026-07) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2783
class-ID: 0300
Device-2: Guillemot Hercules Dualpix Infinite
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-10.1:11 chip-ID: 06f8:300a class-ID: 0102
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 108 gamma: 1.2
chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149
y: 0.055 white: x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43")
diag: 690mm (27.2") ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x720,
1024x768, 800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unknown tag 112
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 610.57.04
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070
SUPER/PCIe/SSE2 memory: 11.71 GiB display-ID: :0.0
API: Vulkan v: 1.4.357 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 SUPER driver: nvidia v: 610.57.04 device-ID: 10de:2783
surfaces: N/A
Device-1: Intel 700 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
Device-3: Guillemot Hercules Dualpix Infinite
API: ALSA v: k6.18.45-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
Device-1: ASUSTek Bluetooth Controller driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0b05:1bef
class-ID: e001
Hardware-1: Intel RST Volume Management Device Controller driver: vmd v: 0.6
port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev: class-ID: 0104
Local Storage: total: 7.73 TiB used: 3.01 TiB (38.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR004 temp: 47.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:15 vendor: Crucial model: CT2000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR003 temp: 51.9 C
scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:18 vendor: Samsung
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Crucial model: CT4000MX500SSD1
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-1: / raw-size: 80 GiB size: 78.19 GiB (97.74%) used: 29.05 GiB (37.2%)
fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9 label: MjroKDEroot
uuid: 6d6ae727-21c3-463c-a677-b46950b9d916
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%)
used: 744.7 MiB (36.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: EFI uuid: FA1B-E465
ID-3: /home raw-size: 80 GiB size: 78.19 GiB (97.74%)
used: 33.56 GiB (42.9%) fs: ext4 dev: /dev/nvme0n1p10 maj-min: 259:10
label: MjroKDEhome uuid: 077b177b-fa32-451b-9b24-3fba59616374
ID-4: /media/Datos raw-size: 931.5 GiB size: 916.69 GiB (98.41%)
used: 274.65 GiB (30.0%) fs: ext4 dev: /dev/nvme0n1p14 maj-min: 259:14
label: Datos uuid: 66c20865-b291-4af2-a0ba-49e2dbb53643
ID-5: /media/Games raw-size: 1.5 TiB size: 1.48 TiB (98.36%)
used: 1.38 TiB (93.4%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:16
label: Games uuid: a77aebab-6b5b-4c98-ba5c-d077fdb0edbd
ID-6: /media/Media raw-size: 1.5 TiB size: 1.48 TiB (98.42%)
used: 1.3 TiB (88.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Media
uuid: b0e566c2-00ce-4aa3-92c9-2e840a9e79cc
ID-1: swap-1 type: partition size: 32.54 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 31f4b41c-9198-4ebe-9faf-d07f32ab7a9d
Device-1: 1-2:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-2: 1-6:3 info: ASUSTek Bluetooth Controller type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 0b05:1bef class-ID: e001
Hub-2: 1-9:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-9.1:6 info: American Power Conversion Uninterruptible Supply
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 2mA
chip-ID: 051d:0002 class-ID: 0300 serial: <filter>
Hub-3: 1-10:5 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-10.1:11 info: Guillemot Hercules Dualpix Infinite
type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 168mA
Hub-4: 1-10.3:7 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
Device-1: 1-10.3.2:8 info: CX 2.4G Receiver type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3554:fc05 class-ID: 0301
Device-2: 1-10.3.3:9 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-3: 1-10.3.4:10 info: LG USA 27UP850 - WK.AEUDCSN External Monitor
4K type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 043e:9a39
Hub-5: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Hub-6: 2-9:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-7: 2-9.3:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
chip-ID: 0451:8140 class-ID: 0900
System Temperatures: cpu: 42.0 C mobo: 46.0 C
Fan Speeds (rpm): fan-1: 1048 fan-2: 843 fan-3: 0 fan-4: 1024 fan-5: 1057
fan-6: 0 fan-7: 0
Packages: pm: pacman pkgs: 1501 libs: 413 tools: pamac pm: flatpak pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
3: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
4: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
6: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 448
1: cpu: 18.9% command: librewolf pid: 2016 mem: 849.0 MiB (2.6%)
2: cpu: 18.2% command: Telegram pid: 8793 mem: 738.1 MiB (2.3%)
3: cpu: 15.0% command: kwin_wayland pid: 1247 mem: 311.6 MiB (0.9%)
4: cpu: 13.9% command: librewolf pid: 2952 mem: 390.5 MiB (1.2%)
5: cpu: 6.8% command: konsole pid: 11338 mem: 136.6 MiB (0.4%)
Memory top: 5 of 448
1: mem: 849.0 MiB (2.6%) command: librewolf pid: 2016 cpu: 18.9%
2: mem: 738.1 MiB (2.3%) command: Telegram pid: 8793 cpu: 18.2%
3: mem: 613.7 MiB (1.9%) command: plasmashell pid: 1357 cpu: 6.0%
4: mem: 400.2 MiB (1.2%) command: librewolf pid: 3151 cpu: 0.1%
5: mem: 390.5 MiB (1.2%) command: librewolf pid: 2952 cpu: 13.9%
Processes: 448 Power: uptime: 1h 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.33 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: gcc: 16.2.1 Shell: Zsh v: 5.9.2 running-in: konsole
inxi: 3.3.41
After running some tests, I’ve found that the issue seems to be with certain programs rather than the cameras:
Cameractrls fails to open, and kamoso shows a black video window even though it’s able to take photos and record video (and the resulting photo or video files can be viewed correctly afterward, even though the kamoso video window was black while they were being captured)
These issues occur after the 2026-08-23 system update with both of my USB webcams (a Logitech BRIO 4K and a Hercules Dualpix Infinity), on both my desktop computer and my Lenovo laptop (where they also fail using the built-in camera).
However, programs like guvcview or OBS continue working without issues and show the image correctly on the video window so it appears that the problem isn’t with the cameras, but rather that some programs fail to run properly after the latest system update.
This is the console output when I run cameractrls:
❯ cameractrls
/usr/bin/cameractrls:297: DeprecationWarning: Due to '_pack_', the 'v4l2_plane_pix_format' Structure will use memory layout compatible with MSVC (Windows). If this is intended, set _layout_ to 'ms'. The implicit default is deprecated and slated to become an error in Python 3.19.
class v4l2_plane_pix_format(ctypes.Structure):
/usr/bin/cameractrls:306: DeprecationWarning: Due to '_pack_', the 'v4l2_pix_format_mplane' Structure will use memory layout compatible with MSVC (Windows). If this is intended, set _layout_ to 'ms'. The implicit default is deprecated and slated to become an error in Python 3.19.
class v4l2_pix_format_mplane(ctypes.Structure):
/usr/bin/cameractrls:821: DeprecationWarning: Due to '_pack_', the 'v4l2_querymenu' Structure will use memory layout compatible with MSVC (Windows). If this is intended, set _layout_ to 'ms'. The implicit default is deprecated and slated to become an error in Python 3.19.
class v4l2_querymenu(ctypes.Structure):
usage: /usr/bin/cameractrls [--help] [-d DEVICE] [--list] [-c CONTROLS]
optional arguments:
-h, --help show this help message and exit
-d DEVICE use DEVICE, default /dev/video0
-l, --list list the controls and values
-L, --list-devices list capture devices
-c CONTROLS set CONTROLS (eg.: hdr=on,fov=wide)
example:
/usr/bin/cameractrls -c brightness=128,kiyo_pro_hdr=on,kiyo_pro_fov=wide
It show warning messages but I don’t know how to interpret or correct them. Cameractrls is a great program with more options than others to set the camera controls, and I would like to continue using it. Any help or suggestion will be welcome.
And what does cameractrls -L list?
❯ cameractrls -L
"BRIO 4K Stream Edition (/dev/video0)" at /dev/v4l/by-id/usb-046d_BRIO_4K_Stream_Edition_C42AB180-video-index0 -> /dev/video0
"Integrated Camera: Integrated C (/dev/video2)" at /dev/v4l/by-id/usb-Azurewave_Integrated_Camera-video-index0 -> /dev/video2
So you have 2 cameras, built-in and usb? Which one doesn’t work?
I copied the output of cameracrtls -L from my Lenovo laptop, which has an integrated Azurewave camera and an external Logitech BRIO 4K camera connected via USB.
As I mentioned in my second post, I was able to confirm that the problem isn’t with the cameras themselves; both are working correctly. (I also tested another USB camera, a Hercules Infinity Dualpix, with the same result.)
The issue lies with some applications, such as kamoso (which displays a completely black image window even though the camera is working and taking photos correctly, which I can then view).
And in the case of cameracrtls (the program I usually use to configure the camera), it seems to fail to run and crashes before the program window even opens. Based on the warning messages, could there be a problem with Python and this program since the last system update? Before the update, it ran without any issues.
Cameractrls indeed does not start anymore, i just tested. A bit strange, since those are warnings, not yet errors. Maybe there is something else.
I guess until it is fixed you will have to use another app for configuring the camera. Try Qt v4l2 test utility.
The flatpak may be still working, it is worth testing.
Thank you very much for the replies. I see that the Python problem is affecting other packages and users as well. I will use Qtv4l2 (I prefer it to using cameractrls flatpak) to configure the camera until cameractrls can run without problems again.
