Kernel: 5.18.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0 Desktop: GNOME v: 42.3.1
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 43.8 Wh (99.1%) condition: 44.2/60.0 Wh (73.7%) volts: 17.1 min: 15.4
model: Celxpert L19C4PC0 status: N/A
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1623 high: 2987 min/max: 1400/2900 boost: enabled cores: 1: 2041 2: 1397
3: 1878 4: 1395 5: 1673 6: 1606 7: 1397 8: 1523 9: 1397 10: 1624 11: 1472 12: 1395 13: 1394
14: 2987 15: 1397 16: 1397 bogomips: 92663
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia v: 470.129.06
arch: Turing bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1 bus-ID: 05:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: amdgpu,nvidia gpu: amdgpu resolution: 1920x1080~120Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.18.12-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 282.43 GiB (59.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB temp: 39.9 C
ID-1: / size: 459.72 GiB used: 282.31 GiB (61.4%) fs: ext4 dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 128.5 MiB (1.4%) dev: /dev/nvme0n1p2
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 379 Uptime: 50m Memory: 15 GiB used: 5.68 GiB (37.8%) Init: systemd Compilers:
gcc: 12.1.0 clang: 14.0.6 Packages: 1601 Client: gnome-shell v: 42.3.1 inxi: 3.3.19
I have a Nikon Z50, when I connect it using a USB cable, it doesn’t show up in lsusb
. gphoto2
can’t see the camera. What can I do?
bus-ID: 05:00.6
I have a Nikon Z50 and Entangle used to be able to detect the camera. After not using it for a long time, I tried using it again and now it just can’t see my camera. gphoto
also can’t detect my camera.
Hello,
Please check Forum Rules - Manjaro to avoid cross-posting aka duplicate posts.
Since is about a laptop, check tlp
power settings for the USB port where you connect the camera. You can make use of tlpui
and disable power saving completely, and try again to reconnect your camera.
Thanks! I tried disabling USB Autosuspend, I tried turning TLP off. Still can’t see the camera. Other devices work with all the USB ports. Turning the camera off charges it through USB.
From what i read about that camera, doesn’t have to have the WiFi enabled in order to connect even via USB with the PC?
wildcard:
Nikon Z50
to be sure the USB cable isn’t faulty or something like that:
run:
journalctl -f
in a terminal
and then plug in and disconnect the device
to see what the system is seeing happening …
