I would like to import some old videos from DV tapes using my Samsung VP-K80/K85 camcorder. This device has only RCA Connectors as output (no firewire). So I bought two cables :
RCA ↔ HDMI
RCA ↔ USB
Enabling journald log, nothing happens with HDMI cable while with the USB one, I get the following messages :
kernel - usb 1-3: device not accepting address 56, error -71
kernel - usb usb1-port3: unable to enumerate USB device
In addition, lsusb do not list any device related to my camcorder
Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.21.3
I did this my self with a few months back, captured I used and RCA → HDMI that upscaled to 1080p and then connected it to an HDMI capture module. Then I used Simple UVC Viewer (guvcview) to capture the video. The drawback is that you have to capture the video in realtime… 1 hour tape will take an hour to capture.
Your computer will never see your camera… only what ever you may connect in between the two. Your cables must be a converter of somekind which then outputs a video signal. My solution is the only way if the camera only has RCA outputs.
