In unstable calamares is not working it says it can’t load modules then says due to distribution bad configuration. the modules it says it can’t load are
user@user &
user@user
user@user &
user@user
If you already have an installed system that you’ve put in unstable, why would you need Calamares for?
Because I was using buildiso to build an iso. I had to add python38 to my online-repo as could not use 3.9 for building android 10 roms.
By the way if you install calamares on unstable it won’t start either fails with the same error message
@philm
Solved with today’s update of Calamares.
