I have an instalation issue. For some reason (I don’t know), calamares is throwing this error:
<div><strong>Command '['btrfs', 'subvolume', 'create', '/tmp/calamares-root-_925njzh/@']' returned non-zero exit status 1.</strong></div><div>None</div><div><br/>Traceback:</div><div><pre>File "/usr/lib/calamares/modules/mount/main.py", line 251, in run
mount_partition(root_mount_point, partition, partitions)
File "/usr/lib/calamares/modules/mount/main.py", line 197, in mount_partition
subprocess.check_call(["btrfs", "subvolume", "create",
File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)</pre></div>
I hope someone could put me in the right direction with this, please.
