I downloaded the minimal version and it seems to run fine from the USB stick. However, it will not install.
I make it all the way through setup and partitioning but immediately after clicking “Install”, I get this message:
Installation Failed The installer failed to create a partition table on HGST545050A7E680 --------------- Create a new partition table (type: gpt) on 'dev/sda’ -------------------- Job: Create new partition table on device "/dev/sda’ ------------------- Command: sfdisk /dev/sda
Any suggestions as to what I (or the installer) did wrong?
Im running Manjaro Openbox as well, though I installed it from the previous ISO. I am not sure what the challenge may, I am sure some of the veteran linux guys can better assist. I am only running OIB since July this year and really loving the experience so far
I don’t install new systems often, but I probably had similar issue once or twice. And it’s probably something that not only Calamares suffers. Anyway, in my case removing/deleting partition and creating new one fixed the issue. I assume you have installed many distributions on these partition.
I had the same problem and this continues to be an issue of some laptop/ desktop configurations. Here’s what I found. When installing Manjaro, just delete the partition where you want to run the OS using gparted before the installation. That should do it.
