Calamares Installer Fails at Final Prompt
I am trying to install Manjaro Gnome on my Macbook Pro 11,1. I have successfully ran KDE and XFCE versions before. When getting to the final prompt to accept the installation, the installer quits. I have tried two different downloads of the image and both were written using Etcher.
Welcome to the forum! :wave:
FYI, the graphical installer used in all Manjaro editions is called Calamares. :wink:
Do you have more than 2GB RAM? There has been recent issues with machines with less than 4GB.
Hello and thank you! Yes the laptop has 8GB of RAM. I am trying the opensource install option to see if that changes anything. Before I had selected proprietary.
It also failed using open source option.
FYI, The only reason to choose proprietary is if you have a fairly recent NVIDIA GPU.
Either way, if it happens again, instead of installing from the dock shortcut, run the following command to launch the installer instead to upload a log to https://0x0.st and link it here:
calamares_polkit | curl -F 'file=@-' 0x0.st
