I have tried to install a fresh Manjaro on an HP Spectre x360. The live ISO is working fine and all hardware seems to be functioning well. Unfortunately when I run the Calamares installer, it disappears after about 5 or 10 seconds.
I have encountered this issue using both the minimal and full installation KDE Plasma .iso downloaded from the website.
I’ve searched and found some similar issues in the past, but I have not found any relevant solutions yet.
Below is some information that might be helpful for diagnoses.
It seems to be failing at the below, I’m not sure if this is a build bug with the current release of Calamares or not.
Thanks in advance for everyone’s time and support!
Output from sudo calamares:
sudo calamares
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
20:00:16 [1]: ASSERT: "efiSectorCount > 0" in file /build/calamares/src/calamares-3.2.60/src/modules/partition/core/PartitionActions.cpp, line 123
zsh: IOT instruction sudo calamares
Output from sudo calamares -d:
19:59:34 [6]: Calamares::Settings::Settings(const QString&, bool)
Using Calamares settings file at "/etc/calamares/settings.conf"
.. Required settings.conf key hide-back-and-next-during-exec is missing.
19:59:34 [6]: void Logger::setupLogfile()
Using log file: "/root/.cache/calamares/session.log"
19:59:34 [6]: void CalamaresApplication::init()
Calamares version: 3.2.60-5
.. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, ca@valencia, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, oc, pl, pt_BR, pt_PT, ro, ru, si, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
19:59:34 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
19:59:34 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
19:59:34 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Branding::PanelFlavor&, Branding::PanelSide&)
WARNING: Branding setting for sidebar is missing, using "widget" "left"
WARNING: Branding setting for navigation is missing, using "widget" "bottom"
19:59:34 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
Loaded branding component "manjaro"
.. Loaded QRC translation "tz_" "en_US"
.. Loaded QRC translation "calamares_" "en_US"
.. STARTUP: initSettings, initQmlPath, initBranding done
.. STARTUP: initModuleManager: module init started
19:59:34 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
WARNING: .. Module descriptor contains extra keys:
"requires"
19:59:34 [6]: void Calamares::ModuleManager::doInit()
Found 57 modules
19:59:34 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
19:59:34 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1920, 1036) minimum size QSize(1024, 520)
.. Proposed window size: 1024 560
19:59:34 [2]: QString Calamares::_stylesheet(const QDir&)
WARNING: The branding component "/usr/share/calamares/branding/manjaro" does not ship stylesheet.qss.
STARTUP: CalamaresWindow created; loadModules started
19:59:34 [6]: void Config::initLanguages()
Trying to match locale "en_US"
Trying to match locale QLocale(English, Latin, United States)
19:59:34 [6]: void Config::setLocaleIndex(int)
Index 14 Selected locale "en"
.. Loaded QRC translation "tz_" "en"
.. Loaded QRC translation "calamares_" "en"
19:59:34 [2]: OpenType support missing for "Mukti Narrow", script 12
19:59:34 [2]: OpenType support missing for "Droid Sans", script 11
19:59:34 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
19:59:34 [6]: QStringList loadLocales(const QString&)
Loading locales from "/etc/locale.gen"
.. Read 488 lines
.. After filtering 314 lines
ViewModule "locale@locale" loading complete.
19:59:34 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 189 keyboard models
19:59:34 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now total= 0 selected= -1
.. Loaded QRC translation "kb_" "en"
19:59:34 [6]: void Config::detectCurrentKeyboardLayout()
("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
19:59:35 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "keyboard@keyboard" loading complete.
19:59:35 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
19:59:35 [6]: Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x5593cf3f3fa0 "pmsfdiskbackendplugin" "1"
19:59:35 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
ViewModule "partition@partition" loading complete.
19:59:35 [2]: void copyLegacy(const QVariantMap&, const QString&, QVariantMap&, const QString&)
WARNING: Legacy *users* key "userShell" overrides hostname-settings.
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
19:59:35 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
19:59:35 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
19:59:35 [2]: QThread::setPriority: Cannot set priority, thread is not running
19:59:35 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
19:59:35 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
CppJobModule "initcpio@initcpio" loading complete.
Module "users@users" already loaded.
CppJobModule "umount@umount" loading complete.
19:59:35 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
19:59:35 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
19:59:35 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
STARTUP: Window now visible and ProgressTreeView populated
.. 8 view steps loaded.
19:59:35 [6]: bool GeneralRequirements::checkHasPower()
A battery exists, checking for mains power.
19:59:35 [6]: void Config::xkbApply()
xkbmap selection changed to: "us" - ""
19:59:35 [6]: smartctl initialization failed for "/dev/mmcblk0" : No such file or directory
19:59:35 [6]: error during smart output parsing for "/dev/mmcblk0" : Success
19:59:35 [6]: getting temp failed for "/dev/nvme0n1" : Success
19:59:35 [6]: getting powered on time failed for "/dev/nvme0n1" : Success
19:59:35 [6]: getting power cycles failed for "/dev/nvme0n1" : Success
19:59:35 [2]: unknown file system type "" on "/dev/nvme0n1p1"
19:59:35 [2]: unknown file system type "" on "/dev/nvme0n1p2"
19:59:35 [2]: unknown file system type "" on "/dev/nvme0n1p3"
19:59:35 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= "CN"
19:59:35 [6]: void Config::setLocaleIndex(int)
Index 58 Selected locale "zh_CN"
.. No translation for "tz_" "zh_CN" using default (en)
.. Loaded QRC translation "calamares_" "zh_CN"
.. No translation for "kb_" "zh_CN" using default (en)
19:59:35 [2]: unknown file system type "" on "/dev/nvme0n1p4"
19:59:35 [6]: getting temp failed for "/dev/nvme1n1" : Success
19:59:35 [6]: getting powered on time failed for "/dev/nvme1n1" : Success
19:59:35 [6]: getting power cycles failed for "/dev/nvme1n1" : Success
19:59:35 [2]: unknown file system type "" on "/dev/nvme1n1p1"
19:59:35 [2]: unknown file system type "" on "/dev/nvme1n1p2"
19:59:35 [2]: unknown file system type "" on "/dev/nvme1n1p3"
19:59:35 [2]: unknown file system type "" on "/dev/nvme1n1p4"
19:59:35 [6]: smartctl initialization failed for "/dev/sda" : No such file or directory
19:59:35 [6]: error during smart output parsing for "/dev/sda" : Success
19:59:35 [2]: unknown file system type "" on "/dev/md126"
19:59:35 [2]: unknown file system type "" on "/dev/md127"
19:59:36 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
Removing unsuitable devices: 6 candidates.
.. Running ("blkid", "/dev/mmcblk0")
.. Finished. Exit code: 0 output:
/dev/mmcblk0: PTUUID="4f3109ba-6594-8e44-8211-22ecbe586e94" PTTYPE="gpt"
.. Running ("blkid", "/dev/mmcblk0p1")
/dev/mmcblk0p1: UUID="0d39b4c4-9264-463a-8060-71e924625f29" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="6964e34f-fc9b-3a4c-890b-24acd2e5454d"
.. Running ("blkid", "")
.. Target cmd: ("blkid", "") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme0n1")
/dev/nvme0n1: TYPE="isw_raid_member"
.. Running ("blkid", "/dev/nvme0n1p1")
.. Target cmd: ("blkid", "/dev/nvme0n1p1") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme0n1p2")
.. Target cmd: ("blkid", "/dev/nvme0n1p2") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme0n1p3")
.. Target cmd: ("blkid", "/dev/nvme0n1p3") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme0n1p4")
.. Target cmd: ("blkid", "/dev/nvme0n1p4") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme1n1")
/dev/nvme1n1: TYPE="isw_raid_member"
.. Running ("blkid", "/dev/nvme1n1p1")
.. Target cmd: ("blkid", "/dev/nvme1n1p1") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme1n1p2")
.. Target cmd: ("blkid", "/dev/nvme1n1p2") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme1n1p3")
.. Target cmd: ("blkid", "/dev/nvme1n1p3") Exit code: 2 (no output)
.. Running ("blkid", "/dev/nvme1n1p4")
.. Target cmd: ("blkid", "/dev/nvme1n1p4") Exit code: 2 (no output)
.. Running ("blkid", "/dev/sda")
/dev/sda: BLOCK_SIZE="2048" UUID="2022-07-29-12-50-00-00" LABEL="MANJARO_KDE_2136" TYPE="iso9660" PTTYPE="dos"
.. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sda"
.. Running ("blkid", "/dev/md126")
.. Target cmd: ("blkid", "/dev/md126") Exit code: 2 (no output)
.. Running ("blkid", "/dev/md127")
.. Target cmd: ("blkid", "/dev/md127") Exit code: 2 (no output)
.. there are 5 devices left.
19:59:36 [6]: void PartitionCoreModule::doInit()
LIST OF DETECTED DEVICES:
.. node capacity name prettyName
.. "/dev/mmcblk0" 62273594880 DevName$654524a1 DevNamePretty$978df2fd
.. "/dev/nvme0n1" 512105932800 DevName$91deafbc DevNamePretty$af5a3e7f
.. "/dev/nvme1n1" 29257320960 DevName$8c259ebb DevNamePretty$74c7fe48
.. "/dev/md126" -1 DevName$5dca6573 DevNamePretty$c596970b
.. "/dev/md127" -1 DevName$4e68fd04 DevNamePretty$c0122389
.. 5 devices detected.
19:59:36 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
GeneralRequirements output:
storage : 8482560409
enoughStorage : true
RAM : 1073741824
enoughRam : true
hasPower : false
hasInternet : true
isRoot : true
19:59:36 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 5 requirement results from "welcome"
19:59:36 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 1
"partition"
19:59:37 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
19:59:38 [6]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
os-prober gave no output.
19:59:38 [6]: void PartitionCoreModule::doInit()
Ignoring device that is not Disk_Device to bootLoaderDevices list.
19:59:38 [2]: unknown file system type "" on "/dev/md126"
19:59:38 [2]: unknown file system type "" on "/dev/md127"
19:59:38 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
19:59:38 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
system is EFI and new EFI system partition has been found.
19:59:38 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 1 requirement results from "partition"
19:59:38 [6]: void ChoicePage::updateDeviceStatePreview()
Updating partitioning state widgets.
19:59:38 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/md126" with 0 entries.
.. part of an inactive RAID device
19:59:38 [6]: ChoicePage::setupActions()::<lambda()>
Setting texts for 0 osprober entries
No partitions available for replace-action.
No partitions available for resize-action.
No partitions ( any-mounted? false is-raid? true ) for erase-action.
19:59:38 [6]: void ChoicePage::continueApplyDeviceChoice()
Previous device -1 new device 0
19:59:38 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Erase "erase"
19:59:38 [6]: PartitionTable* CreatePartitionTableJob::createTable()
CreatePartitionTableJob::createTable trying to make table for device "/dev/md126"
19:59:38 [6]: void Calamares::RequirementsChecker::finished()
All requirements have been checked.
19:59:38 [6]: void Calamares::RequirementsModel::describe() const
Requirements model has 6 items
.. requirement 0 "storage" satisfied? true mandatory? true
.. requirement 1 "ram" satisfied? true mandatory? true
.. requirement 2 "power" satisfied? false mandatory? false
.. requirement 3 "internet" satisfied? true mandatory? false
.. requirement 4 "root" satisfied? true mandatory? true
.. requirement 5 "partitions" satisfied? true mandatory? true
19:59:39 [2]: unknown file system type "" on "/dev/md127"
19:59:39 [1]: ASSERT: "efiSectorCount > 0" in file /build/calamares/src/calamares-3.2.60/src/modules/partition/core/PartitionActions.cpp, line 123
inxi --no-host -v 7
Kernel: 5.15.57-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.23 serial: <superuser required> UEFI: AMI
v: F.22 date: 06/01/2020
ID-1: BAT0 charge: 45.7 Wh (64.2%) condition: 71.2/71.2 Wh (100.0%)
volts: 11.6 min: 11.6 model: HP Primary type: Li-ion serial: SerialNumber
status: discharging cycles: 186
Device-1: hid-0018:04F3:298D.0001-battery model: ELAN2514:00 04F3:298D
serial: N/A charge: N/A status: N/A
RAM: total: 15.27 GiB used: 3.68 GiB (24.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP
smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB
L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 750 high: 800 min/max: 400/4900 cores: 1: 800 2: 800
3: 800 4: 800 5: 700 6: 700 7: 700 8: 700 bogomips: 36812
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 515.57 arch: Pascal pcie: speed: 2.5 GT/s lanes: 4
bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Quanta HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0408:5255 class-ID: 0e02 serial: 01.00.00
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: AU Optronics 0x30eb res: 1920x1080 hz: 60
dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: 3840x2160
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
class-ID: 0401
Sound Server-1: ALSA v: k5.15.57-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: 0c:dd:24:d1:e8:2c
IP v4: 192.168.1.16/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.1.255
IP v6: 2409:8a20:4cef:a8f0:8a42:a81a:9b57:cd5b/64
IP v6: fe80::c005:a5d:857f:38a4/64 type: noprefixroute scope: link
WAN IP: 223.64.120.188
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Device-1: md126 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 2944 chunk-size: N/A
Components: Online: N/A Spare: 0: nvme1n1
Device-2: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 2136 chunk-size: N/A
Components: Online: N/A Spare: 0: nvme0n1
Local Storage: total: 569.65 GiB used: 0 KiB (0.0%)
ID-1: /dev/mmcblk0 vendor: SanDisk model: SD64G size: 58 GiB type: SSD
serial: 0xda6541aa scheme: GPT
ID-2: /dev/nvme0n1 vendor: Intel model: HBRPEKNX0202AH size: 476.94 GiB
speed: 15.8 Gb/s lanes: 2 type: SSD serial: BTTE93030L5V512B-1 rev: HPS1
temp: 26.9 C
ID-3: /dev/nvme1n1 vendor: Intel model: HBRPEKNX0202AHO size: 27.25 GiB
speed: 15.8 Gb/s lanes: 2 type: SSD serial: BTTE93030L5V512B-2 rev: HPS2
temp: 35.9 C
ID-4: /dev/sda type: USB model: USB 2.0 Flash Drive size: 7.46 GiB
type: SSD serial: CEB6AE69 rev: 8.07 scheme: MBR
Message: No partition data found.
ID-1: /dev/mmcblk0p1 size: 58 GiB fs: ext4 label: N/A
uuid: 0d39b4c4-9264-463a-8060-71e924625f29
ID-2: /dev/sda1 size: 3.32 GiB fs: iso9660
ID-3: /dev/sda2 size: 4 MiB fs: vfat label: MISO_EFI uuid: F70E-0063
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 058f:6387 class-ID: 0806 serial: CEB6AE69
Device-2: 1-5:3 info: Quanta HP Wide Vision FHD Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-9:4 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00bb
class-ID: ff00 serial: e6ef940dd6b4
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C pch: 45.0 C mobo: N/A
Processes: 295 Uptime: 22m wakeups: 2533 Init: systemd v: 251
default: graphical Compilers: gcc: 12.1.0 clang: 14.0.6 Packages:
pacman: 1206 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
