Cairo-dock issue under wayland
cairo-dock doesn’t work under wayland, is there any way to fix the problem?
cairo-dock[2097]: segfault at fffffffffffffff8 ip 000074724b5cc2db sp 00007ffd396a0820 error 7 in libgldi.so.3.5.0[74724b54a000+85000] likely on CPU 1 (core 1, socket 0)
22.05.24 13:24	systemd-coredump	Process 2097 (cairo-dock) of user 1000 dumped core.
Stack trace of thread 2097:
#0  0x000074724b5cc2db n/a (libgldi.so.3 + 0xa62db)
#1  0x000074724be01596 n/a (libffi.so.8 + 0x7596)
#2  0x000074724bdfe00e n/a (libffi.so.8 + 0x400e)
#3  0x000074724be00bd3 ffi_call (libffi.so.8 + 0x6bd3)
#4  0x000074724a499645 n/a (libwayland-client.so.0 + 0x7645)
#5  0x000074724a499e73 n/a (libwayland-client.so.0 + 0x7e73)
#6  0x000074724a49a13c wl_display_dispatch_queue_pending (libwayland-client.so.0 + 0x813c)
#7  0x000074724a49ccf0 wl_display_roundtrip_queue (libwayland-client.so.0 + 0xacf0)
#8  0x000074724b5cc1c7 n/a (libgldi.so.3 + 0xa61c7)
#9  0x000074724b54c7b9 gldi_managers_init (libgldi.so.3 + 0x267b9)
#10 0x000074724b54c8d1 gldi_init (libgldi.so.3 + 0x268d1)
#11 0x0000588ec15cbc3b main (cairo-dock + 0xcc3b)
#12 0x000074724b367d4a n/a (libc.so.6 + 0x25d4a)
#13 0x000074724b367e0c __libc_start_main (libc.so.6 + 0x25e0c)
#14 0x0000588ec15cd0d5 _start (cairo-dock + 0xe0d5)
Stack trace of thread 2126:
#0  0x000074724b44f48d syscall (libc.so.6 + 0x10d48d)
#1  0x000074724c116487 g_cond_wait (libglib-2.0.so.0 + 0xb4487)
#2  0x000074724c086454 n/a (libglib-2.0.so.0 + 0x24454)
#3  0x000074724c0eb29e n/a (libglib-2.0.so.0 + 0x8929e)
#4  0x000074724c0ea065 n/a (libglib-2.0.so.0 + 0x88065)
#5  0x000074724b3d01cf n/a (libc.so.6 + 0x8e1cf)
#6  0x000074724b4516ec n/a (libc.so.6 + 0x10f6ec)
Stack trace of thread 2129:
#0  0x000074724b4439ed __poll (libc.so.6 + 0x1019ed)
#1  0x000074724c11b306 n/a (libglib-2.0.so.0 + 0xb9306)
#2  0x000074724c0bb712 g_main_context_iteration (libglib-2.0.so.0 + 0x59712)
#3  0x00007472472dcfde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 2137:
#2  0x000074724c0bcdc7 g_main_loop_run (libglib-2.0.so.0 + 0x5adc7)
#3  0x000074724b19383c n/a (libgio-2.0.so.0 + 0x10983c)
Stack trace of thread 2128:
#1  0x000074724c116e43 g_cond_wait_until (libglib-2.0.so.0 + 0xb4e43)
#2  0x000074724c086425 n/a (libglib-2.0.so.0 + 0x24425)
#3  0x000074724c0efc1b n/a (libglib-2.0.so.0 + 0x8dc1b)
Stack trace of thread 2127:
#3  0x000074724c0bb762 n/a (libglib-2.0.so.0 + 0x59762)
system details
$ inxi -Fxxxz
  Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_x11 with: cairo-dock
    vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 0HD5W2 v: A00 serial: <superuser required> part-nu: 06B9
    uuid: <superuser required> UEFI-[Legacy]: Dell v: 1.11.1 date: 10/10/2018
  Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP smt: enabled
    arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
  Speed (MHz): avg: 3400 min/max: 800/3400 cores: 1: 3400 2: 3400 3: 3400
    4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 bogomips: 54417
  Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
    arch: Gen-9 ports: active: HDMI-A-1,HDMI-A-3 empty: DP-1, DP-2, DP-3,
    HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: intel dri: i965 gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1014x285mm (39.92x11.22")
    s-diag: 1053mm (41.47")
  Monitor-1: HDMI-A-1 mapped: HDMI1 pos: right model: Acer K242HL
    serial: <filter> res: 1920x1080 hz: 60 dpi: 92
    size: 530x300mm (20.87x11.81") diag: 609mm (24") modes: max: 1920x1080
    min: 720x400
  Monitor-2: HDMI-A-3 mapped: HDMI3 pos: primary,left model: Acer K242HL
    min: 720x400
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
    device-ID: 8086:1912
  API: Vulkan v: 1.3.279 layers: N/A surfaces: xcb,xlib device: 0
    type: integrated-gpu driver: mesa intel device-ID: 8086:1912
  Device-1: Focusrite-Novation Focusrite Scarlett 2i2 driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 1235:8016
    class-ID: fe01
  Device-2: USB MIDI Interface driver: snd-usb-audio type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 bus-ID: 1-7:5 chip-ID: fc02:0101 class-ID: 0103
  API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: active with: 1: a2jmidid status: active
    2: nsmd status: off
  Server-3: PipeWire v: 1.0.5 status: off with: wireplumber status: off
  Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wireguard1 state: unknown speed: N/A duplex: N/A mac: N/A
  Local Storage: total: 1.39 TiB used: 257.05 GiB (18.1%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
  ID-2: /dev/sdb vendor: Silicon Power model: SPCC Solid State Disk
    size: 953.87 GiB speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 916a
    scheme: GPT
  ID-1: / size: 57.37 GiB used: 30.98 GiB (54.0%) fs: ext4 dev: /dev/sda2
  ID-2: /boot size: 511 MiB used: 171.3 MiB (33.5%) fs: vfat dev: /dev/sda1
  ID-3: /home size: 152.74 GiB used: 62.27 GiB (40.8%) fs: ext4
    dev: /dev/sda3
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 34.0 C pch: 49.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB available: 31.11 GiB used: 2.95 GiB (9.5%)
  Processes: 279 Power: uptime: 26m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 255 default: graphical
  Packages: pm: pacman pkgs: 1601 Compilers: clang: 17.0.6 gcc: 13.2.1
    Shell: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
Hi @cluster,
Cairo-dock is X11 only, as you mentioned.
However, if you switch to cairo-dock-plug-ins-wayland-git and cairo-dock-core-wayland-git from the AUR, you might have better luck.
pamac build cairo-dock-core-wayland-git cairo-dock-plug-ins-wayland-git
As it happens, I installed cairo-dock earlier today (for a short while), and it seems to work as expected, apart from some compositor and/or theming related issues. Perhaps it’s only crashing in conjuntion with the Intel graphics. :man_shrugging:
