I have a fresh install (~ 1 week) of Manjaro Kde Plasma and I can’t get my webcam to work.
# v4l2-ctl --list-devices
Cannot open device /dev/video0, exiting.
I’d be glad to go through any troubleshooting steps. Thank you in advance
Hey @megavolt, thanks for the reply.
It’s connected via USB.
lsusb -vt
|__ Port 2: Dev 17, If 2, Class=Audio, Driver=snd-usb-audio, 480M
ID 046d:085c Logitech, Inc. C922 Pro Stream Webcam
|__ Port 2: Dev 17, If 0, Class=Video, Driver=, 480M
|__ Port 2: Dev 17, If 3, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 17, If 1, Class=Video, Driver=, 480M
sudo lsusb -v -d 046d:085c
this is verbose indeed. I don’t understand what I’m seeing. Here’s the whole output:
hm… no driver has been loaded here.
sudo modprobe -v uvcvideo
Check again if a driver has been targeted: lsusb -vt
Sorry for the late reply, it appears that the driver does not exist
modprobe: FATAL: Module uvcvideo not found in directory /lib/modules/5.15.41-1-MANJARO
What packages would I need to install for this?
None… that is a kernel driver. Looks like you did not reboot after upgrading the kernel. The path has been changed and no new drivers can be loaded.
I can’t believe that it was something so trivial. My webcam works fine now. Thank you!
