Buttons hidden under "More" only work when clicking on their centre/label
Hi folks,
the buttons “Torrent”, “Image”, “Signature” and “Checksum” on the ISO-download-pages which are tucked away under “More” seem to work only when clicking on the centred text inside them. If I click slightly off-centre, nothing happens, no action is performed, no link appears in the browser’s status bar, even though the cursor looks like a pointing finger. The behaviour of these specific buttons contrasts with that of other buttons on the site.
I also observed the following: While other <button>s seem to be children of their respective anchor element (i. e. <a href="something"><button></button></a>) each “More”-<button> is a parent of its respective anchor element (<button><a href=”something”></a></button>).
Changing the HTML so that the <button>s behind “More” are children of their <a>s seemed to fix the clickability issue. I’m not a dev, though. Therefore, I cannot know to what extent such change might be feasible.
The current behaviour of the buttons hidden behind “More” feels, however, somewhat confusing.
(Tested with Firefox and Vivaldi)
Yep, seems like a bug. Confirmed with chromium too. But i am not sure who is responsible for the site now. I guess @philm would know. I removed the tags from topic title cause it is not browser dependent.
@romangg. :wink:
Or, simply changing the anchor elements (within the buttons) to display as block, and perhaps adding some line-height would likely resolve the issue (if it were a static site).
I’ve personally noticed much the same as you describe, but dismissed it as an artefact of the chosen infrastructure.
Thanks for bringing this to our attention.
@romangg might like to investigate it further.
Thanks for the report. Indeed looks like only a minor adjustment is needed. If anybody wanna try out a bit of HTML coding, then give it a go and a PR is welcome.
@linux-aarhus was so nice to provide a patch. The issue should be fixed now. :slight_smile:
