I just installed this fresh manjaro gnome update all the things but my webcam isnt working i tried using discord, google meeting on chrome or the cheese application itself its not working
ive been trying to do what other people said in the forums thats facing the problem as me
im using an
Lenovo Lenovo ideapad 320-14AST
AMD A6-9220 RADEON R4, 5 COMPUTE CORES 2C+3G × 2
here are some info about my webcam using the commands i found to use
lsusb 1 ✘
Bus 001 Device 004: ID 174f:116a Syntek EasyCamera
Bus 001 Device 003: ID 0bda:0821 Realtek Semiconductor Corp. RTL8821A Bluetooth
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc. Root Hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Try using guvcview and see what happens when you select either /dev/video0 or /dev/video1. The laptop has hardware key to toggle the webcam, though. Might want to press that once before doing anything else.
GUVCVIEW: version 2.0.8
V4L2_CORE: (UVCIOC_CTRL_MAP) Error: No such file or directory
ALSA lib pcm_dsnoop.c:566:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:999:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1001:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
V4L2_CORE: Could not grab image (select timeout): Resource temporarily unavailable
this is what happens when i select /dev/video0
im able to get into the guvcview the application but the camera where it would show what it sees is not showing anything its just black
as for when i select the /dev/video1
no video device found
