Hello, since I installed Manjaro on my laptop, I cannot use my built-in microphone. When I do alsamixer, go on capture and select my soundcard it says:
This sound device does not have any capture controls.
arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC255 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
pacmd list-cards:
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 28
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xb1228000 irq 137"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#2: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#3: Built-in Audio Analog Stereo
ports:
analog-input: Analog Input (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
inxi -Fzxxxa:
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=56854a1f-4834-4002-bd3d-e049f0f0e5eb rw quiet apparmor=1
security=apparmor resume=UUID=824d7097-a109-432a-8a0a-fbd4ecd874f1 udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Swift SF514-52T v: V1.07 serial: <filter>
Mobo: KBL model: Carlsberg_KL v: V1.07 serial: <filter> UEFI: Insyde v: 1.07 date: 07/09/2018
Battery: ID-1: BAT0 charge: 23.8 Wh condition: 23.8/36.0 Wh (66%) volts: 8.3/7.7 model: PANASONIC AP16L5J type: Li-ion
serial: <filter> status: Not charging
CPU: Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
stepping: A (10) microcode: D6 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32012
Speed: 700 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700 5: 700 6: 700 7: 700 8: 700
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5917
Device-2: Sunplus Innovation HD User Facing type: USB driver: uvcvideo bus ID: 1-7:4 chip ID: 1bcf:2cb0
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 4040 bus ID: 01:00.0 chip ID: 8086:095a
IF-ID-1: gpd0 state: down mac: N/A
Drives: Local Storage: total: 238.47 GiB used: 23.38 GiB (9.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ1 size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: E8FK12.3 scheme: GPT
Partition: ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%) used: 23.38 GiB (10.4%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 49.0 C mobo: 30.0 C
Info: Processes: 219 Uptime: 30m Memory: 7.66 GiB used: 2.04 GiB (26.6%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1132 pacman: 1124 lib: 317 flatpak: 0 snap: 8 Shell: Bash v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
alsamixer:
┌─────────────────────────────────── AlsaMixer v1.2.3 ───────────────────────────────────┐
│ Card: HDA Intel PCH F1: Help │
│ Chip: Realtek ALC255 F2: System information │
│ View: F3: Playback F4:[Capture] F5: All F6: Select sound card │
│ Item: Esc: Exit │
│ This sound device does not have any capture controls. │
In order to get the audio working I needed to add
options snd-hda-intel dmic_detect=0
to /etc/modprobe.d/alsa-base.conf if that is useful
