I tried pulseaudio -k ; pulseaudio -D but it didnt work.
terminal output for inxi -Fxxz:
System: Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20Y1S01M00 v: ThinkPad P14s Gen 1 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20Y1S01M00 serial: <filter> UEFI: LENOVO v: R1BET61W(1.30 ) date: 12/21/2020
Battery: ID-1: BAT0 charge: 29.0 Wh (56.3%) condition: 51.5/50.5 Wh (101.9%) volts: 12.1 min: 11.6 model: LGC 5B10W139
serial: <filter> status: Charging
CPU: Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 rev: 1 cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 54318
Speed: 2795 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz): 1: 2795 2: 3150 3: 1397 4: 1396 5: 1397
6: 1397 7: 1397 8: 1397 9: 3294 10: 3555 11: 1858 12: 1862 13: 1863 14: 1862 15: 1397 16: 1397
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 07:00.0
chip-ID: 1002:1636
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 2-2:2 chip-ID: 04f2:b6d0
Display: x11 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.42-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel bus-ID: 07:00.5 chip-ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 07:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3400
bus-ID: 02:00.0 chip-ID: 10ec:8168
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 8086:2723
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 2000
bus-ID: 05:00.0 chip-ID: 10ec:8168
IF: enp5s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 6-4:3 chip-ID: 8087:0029
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 49.51 GiB (10.4%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA512TDV size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
temp: 43.9 C
Partition: ID-1: / size: 28.67 GiB used: 11.33 GiB (39.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 431.17 GiB used: 38.18 GiB (8.9%) fs: ext4 dev: /dev/nvme0n1p4
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 57.8 C mobo: 0.0 C gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 349 Uptime: 2m Memory: 14.93 GiB used: 1.8 GiB (12.0%) Init: systemd v: 248 Compilers: gcc: 11.1.0
Packages: pacman: 1240 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
It’s already solved.
Solution:
sudo nano /etc/pulse/default.pa
uncomment both lines:
load-module module-alsa-sink
load-module module-alsa-source device=hw:1,0
