Initially, both sound and microphone was not working, I fixed sound by editing alsa-base.conf and have been trying similar for the mic. 3.5mm headset microphone works fine but the built in mic and bluetooth microphone do not.
I’m pretty sure the actual built in microphone is fine - but have not tested as installed Manjaro over WIndows as soon as I updated the BIOS lol…
Pulse detects ‘built in microphone’. Alsa shows - one capture device. There is also an ‘Internal Mic Boost’ and ‘Rear Mic Boost’ for some reason? Is it all just wired up wrong?
To get the microphone to appear as an input device in Alsa and Pulseaudio I added pulse/default.pa
load-module module-alsa-source device=hw:0,0
# the line above should be somewhere before the line below
.ifexists module-udev-detect.so
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC245 Analog [ALC245 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
[hb@hb-hpenvylaptop13ba0xxx ~]$ inxi -Fazy
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=5a017360-24c3-4247-bd9b-7ba046702446 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP ENVY Laptop 13-ba0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 875A v: 07.35 serial: <filter> UEFI: Insyde v: F.11
date: 08/05/2020
ID-1: BAT1 charge: 9.8 Wh condition: 50.5/51.0 Wh (99%) volts: 10.9/11.6
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Discharging
Topology: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: 96
L2 cache: 8192 KiB
bogomips: 23968
Speed: 1160 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1088 2: 1100
3: 1077 4: 1083 5: 1078 6: 1074 7: 1100 8: 1079
Device-1: Intel Iris Plus Graphics G7 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:8a52
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:34c8
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3 chip ID: 8086:34f0
Local Storage: total: 953.87 GiB used: 20.21 GiB (2.1%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNV1T02 KIOXIA
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: HP00AE00 scheme: GPT
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 3060 bus ID: 00:17.0 chip ID: 8086.282a rev: 30
ID-1: / raw size: 953.57 GiB size: 937.60 GiB (98.33%)
used: 20.21 GiB (2.2%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 52.0 C mobo: 10.0 C
Processes: 227 Uptime: 42m Memory: 7.56 GiB used: 2.00 GiB (26.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1325 lib: 408
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
