My built-in microphone gets recognized (see below) but it does not record sound. E.g. I tried executing parec | pacat
and I didn’t hear myself but there is an icon on my panel that the microphone is in use. The sound settings are ok (set in pulseaudio to 100%, yet no success). Or when I tried the following command, the only thing I could hear was a barely hearable static:
arecord -f cd -d 10 --device="hw:0,0" /tmp/test-mic.wav && vlc /tmp/test-mic.wav
Output of arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
please post system information
inxi -Faz
and ALSA information
sudo alsa-info.sh --upload
nik:
inxi -Faz
System: Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=61d22fee-8468-41b5-a063-3da96567324d ro quiet apparmor=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUS Laptop E410MA_E410MA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: E410MA v: 1.0 serial: <filter> UEFI: American Megatrends v: E410MA.302 date: 09/11/2020
Battery: ID-1: BAT0 charge: 42.1 Wh (100.0%) condition: 42.1/42.1 Wh (100.1%) volts: 11.8 min: 11.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
CPU: Info: Quad Core model: Intel Pentium Silver N5030 bits: 64 type: MCP arch: Goldmont Plus family: 6
model-id: 7A (122) stepping: 8 microcode: 18 cache: L2: 4 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8756
Speed: 2754 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 2754 2: 2757 3: 2645 4: 2783
Graphics: Device-1: Intel UHD Graphics 605 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3184
class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-5:4 chip-ID: 13d3:5a11
class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 605 (GLK 3) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave driver: rtl8821ce v: N/A
modules: rtw88_8821ce,8821ce port: e000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-2: Realtek RTL8188CUS 802.11n WLAN Adapter type: USB driver: rtl8192cu bus-ID: 1-1:2 chip-ID: 0bda:8176
class-ID: 0000 serial: <filter>
IF: wlp0s21f0u1 state: down mac: <filter>
Bluetooth: Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 13d3:3529
Drives: Local Storage: total: 238.47 GiB used: 21.07 GiB (8.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ256HAJD-00000 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: FXV7101Q temp: 36.9 C
scheme: GPT
Partition: ID-1: / raw-size: 202.84 GiB size: 198.65 GiB (97.94%) used: 21.05 GiB (10.6%) fs: ext4 dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 25.6 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 65.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 176 Uptime: 2h 54m wakeups: 4 Memory: 7.6 GiB used: 3.65 GiB (48.1%) Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1313 lib: 412 flatpak: 0 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.03
Link to ALSA information
