I am trying to build myself custom iso after couple of years and I am getting errors in buildpkg and I have no ideas where this is coming from or how can I fix it.
$ buildpkg -p my-package
--> Loading compiler settings: x86_64
==> Updating chroot for [stable] (x86_64)...
==> ERROR: '/var/lib/manjaro-tools/buildpkg/stable/x86_64/wvi' does not appear to be a Manjaro chroot.
==> ERROR: Aborting...
Another - and better - option is to use chrootbuild
sudo pacman -Syu manjaro-chrootbuild
Then
sudo chrootbuild -p my-package
In any case run with the -h argument to get a list of options
$ buildpkg -h
Usage: buildpkg [options]
-a <arch> Arch [default: x86_64]
-b <branch> Branch [default: stable]
-c Recreate chroot
-h This help
-i <pkg> Install a package into the working copy of the chroot
-n Install and run namcap check
-p <pkg> Build list or pkg [default: default]
-q Query settings and pretend build
-r <dir> Chroots directory
[default: /var/lib/manjaro-tools/buildpkg]
-s Sign packages
-w Clean up cache and sources
$ chrootbuild -h
Usage: chrootbuild [options]
-b <branch> Branch to use:
(unstable/testing/stable-staging/stable;
arm-unstable/arm-testing/arm-stable)
default: unstable / arm-unstable
-c Start with clean chroot fs
-d Disable colors.
-D Build with debug symbols.
-f Force unmount chroot if busy.
-g Push changes to git when building lists
-G Generate Checksums
-h This help
-H Use the host's keyrings
-i <pkg> Install package(s) to chroot fs
(for multiple packages repeat -i flag)
-k <repo> Use custom repo:
(mobile/kde-unstable)
-K <list> Kernel-modules list to build
-l <list> List(s) to build
(for multiple lists repeat -l flag)
-m Build a multilib package
-M <url> Use custom mirror
-n Install built pkg to chroot fs
-p <pkg> Package(s) to build
(for multiple packages repeat -p flag)
-r custom chrootdir path
default: /var/lib/chrootbuild
-s Sign package(s)
-u Build pkgs only if update available (lists only)
-x
This works so I have to specify the -c for create in the same command as the package. I did try doing buildpkg -c followed by buildpkg -p but that did not help. Thanks a lot.
