Hello
This issue is somewhat odd and i try to figure what the problem there is. It sometimes on different positions. An example:
--> overlayfs umount: [/build_manjaro_iso/chroot/buildiso/xfce/x86_64/mhwdfs]
umount: /home/user/build_manjaro_iso/chroot/buildiso/xfce/x86_64/mhwdfs: target is busy.
==> ERROR: A failure occurred in make_image_mhwd().
Aborting...
I made a symbolic link from ~/build_manjaro_iso/ to /build_manjaro_iso/
Then added to the config:
cache_dir=/build_manjaro_iso/cache
chroots_dir=/build_manjaro_iso/chroot
log_dir=/build_manjaro_iso/logs
Everything is in the same folder:
ls /build_manjaro_iso/
cache chroot iso-profiles logs manjaro-tools target
It makes also no difference if i let the folders in manjaro-tools.conf at default.
I created a VM with XFCE default. Here it works.
My idea is that there is an issue with software raid… My /home is running on a Raid0 with 2 HDDs, while / is installed on a SSD.
Is it somehow possible to add more wait time or just a sync command before ‘umount’ the mountpoints?
Has anyone experienced the same issue?
Thanks for reading
