Specs: Current Manjaro/xfce/One Netbook A1
Due to the A1’s buggy battery output, the battery stops charging at 80% (both Manjaro and Win10 see it as fully charged). This means that at 0%, the battery has at least 20% left.
Is there a way to make a battery output use negative numbers up to -20% in xfce’s genmon applet?
I’m guessing that the first problem would be rendering an accurate output in negative numbers, if only because the rate of battery discharge in positive numbers depends on cpu/wifi/screen use rather than simple uptime.
I’m also guessing that this approach is impossible, but I wanted at least to confirm it with users that know more than me.
