Build packages from AUR
I am delighted to discover this Manjaro community. I am testing Manjaro for more than a year on VM (Oracle). I would like to share my experience installing a package from AUR, librewolf and I hope you can give me some clues how to solve this issue. The package build started OK but after a lot of time (more than 1 hour) the CPU and HDD accumulating load over 20 from 0.44-1.0 and hdd grew from 5G to 10, 15, 17G. At some point the system crashed and I had to restart and start over again a few times with no success finishing installation. I increased the VMā€™s allocated MEM from 1024 to 2048 and then 4G but did not help. Any tips would be appreciated. Thanks!
Hi @lattimro, and welcome!
Browsers take a long time to compile. Iā€™ve noticed it myself:
From that post:
Firefox source is 350ā€™ish MB compressed
Kernel source is about 170 MB compressed.
So yeah, it can take a long time.
However, the *-bin packages are precompiled and you donā€™'t need yo compile them. And I noticed that there is a binary for (the package with the -bin extension) for librewolf. You can install it with:
pamac build librewolf-bin
Hope this helps!
thanks for confirming that this is normal to takes so much time for compiling. I tried also the binary you have mentioned but it crashed too. I installed from flatpack and it took few minutes.
You are very welcome!
I think the continued crashing has somethin, no I donā€™t know what the ā€œsomethingā€ could be, to do with it running in a VM, but Iā€™m not sure.
But flatpak is one of my favorite ways to install software. So itā€™s all good IMHO.
As long as you managed, allā€™s good IMO.
If you donā€™t tell us how it ā€œcrashedā€, thereā€™s nothing we can do about it.
I did not have any info how crashed but means frozen should be more appropriate. I just noticed the CPU load increased and I supposed the allocated MEM reached a critical value and freeze the kernel. I had to power off the VM client (Manjaro). I wish I could have more info on that.
I donā€™t think it crashed completely. I think CPU usage was just so hight that it looked that way.
Donā€™t bother about getting more information. I suspect nothing is wrong, per sĆØ
