I’m trying to install the package joplin-desktop. However, the build fails: ZeroBin.net
I even have no idea, what all these messages mean. However, I looked further:
$ cat /tmp/xfs-a1650444/build.log
# This file contains the result of Yarn building a package (root@workspace:.)
# Script name: postinstall
[23:09:21] Using gulpfile /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/gulpfile.js
[23:09:21] Starting 'build'...
> yarn [ 'run', 'buildParallel' ]
➤ YN0000: [joplin]: Process started
➤ YN0000: [@joplin/app-desktop]: Process started
➤ YN0000: [joplin]: [23:09:25] Using gulpfile /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-cli/gulpfile.js
➤ YN0000: [joplin]: [23:09:25] Starting 'build'...
➤ YN0000: [joplin]: [23:09:25] Starting 'prepareBuild'...
➤ YN0000: [joplin]: [23:09:25] Finished 'prepareBuild' after 84 ms
➤ YN0000: [joplin]: [23:09:25] Finished 'build' after 87 ms
➤ YN0000: [joplin]: Process exited (exit code 0), completed in 1s 736ms
➤ YN0000: [@joplin/fork-htmlparser2]: Process started
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Using gulpfile /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/gulpfile.js
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'build'...
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'compileScripts'...
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'compilePackageInfo'...
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'copyPluginAssets'...
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'copyApplicationAssets'...
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'updateIgnoredTypeScriptBuild'...
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'buildCommandIndex'...
➤ YN0000: [@joplin/app-desktop]: [23:09:25] Starting 'compileSass'...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/HelpButton.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/IconButton.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/ImportScreen.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/ItemList.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/Navigator.jsx...
➤ YN0000: [@joplin/fork-htmlparser2]: node_modules/@types/prettier/index.d.ts(41,54): error TS2315: Type 'IsTuple' is not generic.
➤ YN0000: [@joplin/fork-htmlparser2]: node_modules/@types/prettier/index.d.ts(53,6): error TS2456: Type alias 'IsTuple' circularly references itself.
➤ YN0000: [@joplin/fork-htmlparser2]: node_modules/@types/prettier/index.d.ts(53,65): error TS2574: A rest element type must be an array type.
➤ YN0000: [@joplin/fork-htmlparser2]: node_modules/@types/prettier/index.d.ts(53,84): error TS2315: Type 'IsTuple' is not generic.
➤ YN0000: [@joplin/fork-htmlparser2]: node_modules/@types/prettier/index.d.ts(96,5): error TS2589: Type instantiation is excessively deep and possibly infinite.
➤ YN0000: [@joplin/fork-htmlparser2]: node_modules/@types/prettier/index.d.ts(131,5): error TS2589: Type instantiation is excessively deep and possibly infinite.
➤ YN0000: [@joplin/fork-htmlparser2]: node_modules/@types/prettier/index.d.ts(165,5): error TS2589: Type instantiation is excessively deep and possibly infinite.
➤ YN0000: [@joplin/fork-htmlparser2]: Process exited (exit code 2), completed in 9s 924ms
➤ YN0000: [@joplin/server]: Process started
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/NotePropertiesDialog.jsx...
➤ YN0000: [@joplin/server]: [23:09:36] Using gulpfile /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/server/gulpfile.js
➤ YN0000: [@joplin/server]: [23:09:36] Starting 'build'...
➤ YN0000: [@joplin/server]: [23:09:36] Starting 'compilePackageInfo'...
➤ YN0000: [@joplin/server]: Generated /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/server/dist/packageInfo.js
➤ YN0000: [@joplin/server]: [23:09:36] Finished 'compilePackageInfo' after 54 ms
➤ YN0000: [@joplin/server]: [23:09:36] Finished 'build' after 56 ms
➤ YN0000: [@joplin/server]: Process exited (exit code 0), completed in 1s 272ms
➤ YN0000: [@joplin/turndown]: Process started
➤ YN0000: [@joplin/turndown]: src/turndown.js → lib/turndown.cjs.js...
➤ YN0000: [@joplin/turndown]: created lib/turndown.cjs.js in 356ms
➤ YN0000: [@joplin/turndown]: Process exited (exit code 0), completed in 1s 337ms
➤ YN0000: [@joplin/turndown-plugin-gfm]: Process started
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/NoteRevisionViewer.jsx...
➤ YN0000: [@joplin/turndown-plugin-gfm]: src/gfm.js → lib/turndown-plugin-gfm.cjs.js...
➤ YN0000: [@joplin/turndown-plugin-gfm]: created lib/turndown-plugin-gfm.cjs.js in 78ms
➤ YN0000: [@joplin/turndown-plugin-gfm]: Process exited (exit code 0), completed in 0s 920ms
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/NoteSearchBar.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/NoteStatusBar.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/PromptDialog.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/TagItem.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/ToolbarSpace.jsx...
➤ YN0000: [@joplin/app-desktop]: Compiling /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/VerticalResizer.jsx...
➤ YN0000: [@joplin/app-desktop]: Generating /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/commands/index.ts...
➤ YN0000: [@joplin/app-desktop]: [23:09:51] Finished 'compileScripts' after 26 s
➤ YN0000: [@joplin/app-desktop]: Generated /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/packageInfo.js
➤ YN0000: [@joplin/app-desktop]: [23:09:51] Finished 'compilePackageInfo' after 26 s
➤ YN0000: [@joplin/app-desktop]: Generated /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/style.min.css
➤ YN0000: [@joplin/app-desktop]: [23:09:51] Finished 'compileSass' after 26 s
➤ YN0000: [@joplin/app-desktop]: [23:09:51] Finished 'updateIgnoredTypeScriptBuild' after 26 s
➤ YN0000: [@joplin/app-desktop]: Generating /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/gui/MainScreen/commands/index.ts...
➤ YN0000: [@joplin/app-desktop]: Generating /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/gui/NoteEditor/commands/index.ts...
➤ YN0000: [@joplin/app-desktop]: Generating /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/gui/NoteList/commands/index.ts...
➤ YN0000: [@joplin/app-desktop]: Copying to /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../gui/note-viewer/pluginAssets
➤ YN0000: [@joplin/app-desktop]: Generating /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/gui/NoteListControls/commands/index.ts...
➤ YN0000: [@joplin/app-desktop]: Generating /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/gui/Sidebar/commands/index.ts...
➤ YN0000: [@joplin/app-desktop]: Generating /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/lib/commands/index.ts...
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/tinymce => packages/app-desktop/vendor/lib/tinymce
➤ YN0000: [@joplin/app-desktop]: [23:09:51] Finished 'buildCommandIndex' after 26 s
➤ YN0000: [@joplin/app-desktop]: Copying to /var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/app-desktop/tools/../pluginAssets
➤ YN0000: [@joplin/app-desktop]: [23:09:51] Finished 'copyPluginAssets' after 26 s
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/@fortawesome/fontawesome-free/webfonts => packages/app-desktop/vendor/lib/@fortawesome/fontawesome-free/webfonts
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/roboto-fontface/fonts => packages/app-desktop/vendor/lib/roboto-fontface/fonts
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/codemirror/theme => packages/app-desktop/vendor/lib/codemirror/theme
➤ YN0000: [@joplin/app-desktop]: Copying Assets/TinyMCE/langs => packages/app-desktop/vendor/lib/tinymce/langs
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/@fortawesome/fontawesome-free/css/all.min.css => packages/app-desktop/vendor/lib/@fortawesome/fontawesome-free/css/all.min.css
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/react-datetime/css/react-datetime.css => packages/app-desktop/vendor/lib/react-datetime/css/react-datetime.css
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/smalltalk/css/smalltalk.css => packages/app-desktop/vendor/lib/smalltalk/css/smalltalk.css
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/roboto-fontface/css/roboto/roboto-fontface.css => packages/app-desktop/vendor/lib/roboto-fontface/css/roboto/roboto-fontface.css
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/codemirror/lib/codemirror.css => packages/app-desktop/vendor/lib/codemirror/lib/codemirror.css
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/codemirror/addon/dialog/dialog.css => packages/app-desktop/vendor/lib/codemirror/addon/dialog/dialog.css
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/@joeattardi/emoji-button/dist/index.js => packages/app-desktop/vendor/lib/@joeattardi/emoji-button/dist/index.js
➤ YN0000: [@joplin/app-desktop]: Copying packages/app-desktop/node_modules/mark.js/dist/mark.min.js => packages/app-desktop/vendor/lib/mark.js/dist/mark.min.js
➤ YN0000: [@joplin/app-desktop]: Copying packages/lib/services/plugins/sandboxProxy.js => packages/app-desktop/vendor/lib/@joplin/lib/services/plugins/sandboxProxy.js
➤ YN0000: [@joplin/app-desktop]: [23:09:52] Finished 'copyApplicationAssets' after 26 s
➤ YN0000: [@joplin/app-desktop]: [23:09:52] Finished 'build' after 26 s
➤ YN0000: [@joplin/app-desktop]: Process exited (exit code 0), completed in 28s 239ms
➤ YN0000: Done in 28s 257ms
[23:09:52] 'build' errored after 31 s
[23:09:52] Error: Command failed with exit code 1: yarn run buildParallel
at makeError (/var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/tools/node_modules/execa/lib/error.js:59:11)
at handlePromise (/var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/packages/tools/node_modules/execa/index.js:114:26)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async fn (/var/tmp/pamac-build-hm/joplin/src/joplin-2.7.15/gulpfile.js:35:5)
I still couldn’t figure out the error, so I found this: Failed in build(): root@workspace:. couldn't be built successfully · Issue #112 · alfredopalhares/arch-pkgbuilds · GitHub From that, it seems like PKGBUILD should be changed. However, I have no idea, what that means or how it can be done. I’m very new to Manjaro and not familiar with the package system at all (yet). Could someone guide me, please? My goal is that I will be able to fix more and more errors by myself in the future.
What do those messages mean? With all those messages displayed, I’m not even sure, that everything is right with my system.
