I suspect you can cheat the build process by running a local http.server instead of a regular online mirror.
HIghly experimental
Recently I have been playing with a script to create a custom iso from your installed system. It is not quite finished - in any case you are welcome peek into it.
Untested - no support - most likely buggy.
#!/usr/bin/env bash
# The purpose of this script is to duplicate a running Manjaro system
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <https://www.gnu.org/licenses/>.
# Copyright (c) 2021 @linux-aarhus
# extract system info
# - running kernel : uname -r | awk -F'.' '{print "linux"$1$2}'
# - system branch : pacman-mirrors -G
# package filtering commands
# - explicit inst. packages : pacman -Qqetn > pkglist.txt
# - dependencies : comm -13 <(pacman -Qqdt | sort) <(pacman -Qqdtt | sort) > deplist.txt
# - foreign packages : pacman -Qqem > aurlist.txt
# caveats
# - foreign package repos : packages from third party repo in pacman cannot be installed
# - possible workaround : add the repo to a ``user-repos.conf` in the profile folder`
# - duplicates : if pacman encounters duplicate files the process will break
# THIS IS A WORK IN PROGRESS
# MODIFY AS NEEDED
# manjaro edition
TPL_EDITION="kde"
# branch to use (default is current branch)
TPL_BRANCH=$(pacman-mirrors -G)
# kernel to use (default is running kernel)
TPL_KERNEL=$(uname -r | awk -F'.' '{print "linux"$1$2}')
# iso profiles work dir
TPL_DIR=manjaro-iso-profiles
# your spin name
MY_TPL="my-manjaro"
# work dir
MY_WORKDIR=$HOME/work-dir
# output dir
MY_ISODIR=$HOME/iso
# modify below lists to fit your usecase
# - only configurations from $HOME is copied
# - be careful not to include files/foldes containing credentials or ssh keys
# - if you need configuration stored in other places you must modify the script accordingly
# dotfolders to copy - add foldders as you see fit
CONFIG_FOLDERS=('.config' '.local')
# dotfiles to copy - add files as you see fit
CONFIG_FILES=('.bashrc' '.gtkrc-2.0' '.profile' '.zshrc')
# nasty hack to cheat manjaro-tools into believing in an online user-repo
# one caveat it that you need to remove the repo from before the final build
BUILDREPO="false"
BUILDREPONAME="my-repo"
BUILDREPOURL="http://$HOST"
BUILDREPOPORT="8080"
# /END MODIFICATION
# upstream iso-profiles repo
CLONE_URL="https://gitlab.manjaro.org/profiles-and-settings/iso-profiles.git"
prepare_online_mirror(){
# create list of foreign packages
pacman -Qqem > $MY_WORKDIR/$TPL_DIR/community/$MY_TPL/custom-packages.txt
# create dir to hold build mirror
if [ $BUILDREPONAME != "" ]; then
mkdir -p $MY_WORKDIR/$BUILDREPONAME
else
return
fi
# change dir into our work dir
cd $MY_WORKDIR
# read the custom-packages.txt file
while IFS= read -r pkg; do
# clone tha script from AUR
git clone https://aur.archlinux.org/$pkg.git
# cd into the script folder
cd $pkg
# use makepkg to generate package - install necessary dependencies
makepkg -s
# move resulting package to the repo folder
mv $MY_WORKDIR/$pkg/"$pkg*.pkg.tar.xz" $MY_WORKDIR/online-mirror
# traverse back to the work-dir
cd $MY_WORKDIR
done < $MY_WORKDIR/$TPL_DIR/community/$MY_TPL/custom-packages.txt
# create a database for the packages
repo-add $MY_WORKDIR/$BUILDREPONAME/$BUILDREPONAME.db.tar.xz $MY_WORKDIR/$BUILDREPONAME/*.pkg.tar.zx
# Add an online repo to the build process
if [ $BUILDREPOURL != "" ]; then
echo "[$BUILDREPONAME]\nSiglevel = Optional\nServer = $BUILDREPOURL" > $MY_WORKDIR/$TPL_DIR/community/$TPL_EDITION/user-repos.conf
fi
fi
# start a local http server
if [ BUILDREPO == "true" ]; then
bash -c "python -m http.server -d $MY_WORKDIR/$BUILDREPONAME $BUILDREPOPORT" &
fi
# ---- DO NOT RUN AS ROOT -----------------------------------------------------
# You don't want permission issues in your home
if (( $EUID == 0 )); then
echo "Do not run this script as root!"
exit 1
fi
# ---- Install the tools as needed ---------------------------------------------
sudo pacman -Syu manjaro-tools-iso-git manjaro-tools-base-git manjaro-tools-yaml-git git base-devel --needed
# ---- we cannot clone into an existing folder ---------------------------------
if ! [ -d "$MY_WORKDIR/$TPL_DIR" ]; then
cd "$MY_WORKDIR"
# Clone the profiles repo
git clone $CLONE_URL "$TPL_DIR"
fi
# ---- Check if edition exist --------------------------------------------------
if ! [ -d $MY_WORKDIR/$TPL_DIR/community/$MY_TPL ]; then
# copy the profile and rename it
if [[ $TPL_EDITION =~ (kde|xfce|gnome) ]]; then
cp -r $MY_WORKDIR/$TPL_DIR/manjaro/$TPL_EDITION $MY_WORKDIR/$TPL_DIR/community
mv $MY_WORKDIR/$TPL_DIR/community/$TPL_EDITION $MY_WORKDIR/$TPL_DIR/community/$MY_TPL
else
cp -r $MY_WORKDIR/$TPL_DIR/community/$TPL_EDITION $MY_WORKDIR/$TPL_DIR/community
fi
fi
# ---- Copy configurations ---------------------------------------------------
# The copy process can be amended to copy files from other locations
# create the target skel folder
mkdir -p $MY_WORKDIR/$TPL_DIR/community/$MY_TPL/desktop-overlay/etc/skel
# copy dot folders to the profiles desktop-overlay folder
for folder in ${CONFIG_FOLDERS[@]}; do
echo " ==> copying $folder"
cp -r $HOME/$folder $MY_WORKDIR/$TPL_DIR/community/$MY_TPL/desktop-overlay/etc/skel
done
# copy dot files
for dotfile in ${CONFIG_FILES[@]}; do
echo " ==> copying $dotfile"
cp $HOME/$dotfile $MY_WORKDIR/$TPL_DIR/community/$MY_TPL/desktop-overlay/etc/skel
done
# ---- Create package list ---------------------------------------------------
# create a backup copy of the previous list
cp $MY_WORKDIR/$TPL_DIR/community/$MY_TPL/Packages-Desktop \
$MY_WORKDIR/$TPL_DIR/community/$MY_TPL/Packages-Desktop-$(date +%Y%m%d%H%M).bak
# creating desktop-package list
comm -13 <(cat /desktopfs-pkgs.txt | sort) <(pacman -Qqetn | sort) > $MY_WORKDIR/$TPL_DIR/community/$MY_TPL/Packages-Desktop
# ---- Setup tools -------------------------------------------------------------
# setup manjaro tools so it can find the iso-profiles
# the tools look for environment variable `run_dir`
mkdir -p $HOME/.config/manjaro-tools
echo "run_dir=$MY_WORKDIR/$TPL_DIR" > $HOME/.config/manjaro-tools/iso-profiles.conf
# ---- build out custom packages from AUR --------------------------------------
fi
# ---- Prebuild images -------------------------------------------------------
buildiso -p $MY_TPL -k $TPL_KERNEL -b $TPL_BRANCH -r $MY_WORKDIR/build -t $MY_ISODIR -xf
# ---- Remove online mirror --------------------------------------------------
# we need to remove online mirror from pacman.cong
# simply replace with the default file
cp /usr/share/manjaro-tools/pacman-default.conf $MY_WORKDIR/build/buildiso/$MY_TPL/x86_64/rootfs/etc/pacman.conf
fi
# ---- Assemble ISO ----------------------------------------------------------
buildiso -p $MY_TPL -k $TPL_KERNEL -b $TPL_BRANCH -r $MY_WORKDIR/build -t $MY_ISODIR -zcf
