Build KDE Iso Failed => kpmcore5 and kpmcore are in conflict
Hi,
How to select the kpmcore-24.05.0-1 during the build iso image? needed for partitionmanager
 core 139,8 KiB   624 KiB/s 00:00 [#########################] 100%
 extra 8,3 MiB  20,1 MiB/s 00:00 [#######################] 100%
 multilib 144,9 KiB   647 KiB/s 00:00 [#################] 100%
resolving dependencies...
:: kpmcore5-23.08.5-1 and kpmcore-24.05.0-1 are in conflict. Remove kpmcore? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
==> ERROR: Failed to install packages to new root
==> ERROR: Failed to install all packages
==> ERROR: A failure occurred in make_image_live().
    Aborting...
 --> overlayfs umount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/livefs]
 --> umount overlayfs: [/var/lib/manjaro-tools/buildiso/kde/x86_64/livefs]
[nls@lap ~]$
I Selected kpmcore for partitionmanager in the Packages-Desktop configuration file, but the issue is back.
partitionmanager
kpmcore #for partitionmanager
Last issue (for the iso maintainers), the kde iso profile is up to date but plasma is named plasma5 by default and not Plasma6, lol
## Plasma5
audiocd-kio
bluedevil
kde-gtk-config
kdeplasma-addons
Thanks for your help.
If your ISO uses calamares5 (3.2) in Packages-Live you cannot bundle partitionmanager.
This is a known conflict.
Either remove partitionmanager from the ISO or switch to calamares (3.3) in Packages-Live.
You should verify that Calamares no longer has issues with installing onto btrfs filesystem - as this was the original reason the official profile used a qt5 based installer.
Thanks for your answer, I did an install with calamares 3.3 in packages-live, no issues :slight_smile:
Enjoy !
