Build Iso with exfat-utils
Hi,
I tried to build a x86 iso image with exfat-utils update in March 2023, exfatprogs last up date October 2022.
Something go wrong during the iso build :
resolving dependencies...
:: exfat-utils and exfatprogs are in conflict. Remove exfatprogs? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
==> ERROR: Failed to install packages to new root
==> ERROR: Failed to install all packages
==> ERROR: A failure occurred in make_image_desktop().
    Aborting...
 --> overlayfs umount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs]
 --> umount overlayfs: [/var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs]
I set the iso-profile, but it doesn’t work, how to solve it ? I don’t find the file set with exfatprogs.
Are you agree to build iso with exfat-utils instead of exfatprogs ?
code
base-devel
exfat-utils
Use exfatprogs.
Ok, thanks for your answer.
