Hi,
I try to build netactview on arm
I occur failure, I add the line arch=(‘i686’ ‘x86_64’ ‘aarch64’) in the pkgbuild
I tried with any arch=(‘any’), same issue
Generating netactview information...
Building netactview...
==> ERROR: netactview is not available for the 'aarch64' architecture.
Preparing...
Cloning netactview build files...
Checking netactview dependencies...
Resolving dependencies...
Checking inter-conflicts...
==> ERROR: Cannot find the fakeroot binary.
Is it possible to solve it ?
netactview is very practice on x86
philm
April 24, 2023, 6:23am
2
What you mean by add? There is a line called arch=('x86_64')
. Did you modified that? Also do you try to build it on your ARM device or how you try to build it?
thanks for your answer
You’re right, I modified the line called arch=(‘x86_64’)
I tried to build it on arm64, here is the arm forum…
cscs
April 24, 2023, 7:04am
4
Im guessing you dont have fakeroot
installed, which would mean you likely neglected one of the requirements for using the AUR, the base-devel
group.
Hey @nl.smart
creating the package netactview (aur) with aarch64(any) should work.
see logs
makepkg -s
LANG=C makepkg -s SIGINT master
==> Making package: netactview 0.6.4-5 (Mo 24 Apr 2023 09:11:26 CEST)
==> Installing missing dependencies...
resolving dependencies...
Packages (1) libglade-2.6.4-7
Total Installed Size: 0,34 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [------------------------------------------------] 100%
(1/1) checking package integrity [------------------------------------------------] 100%
(1/1) loading package files [------------------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------------------] 100%
(1/1) checking available disk space [------------------------------------------------] 100%
(1/1) installing libglade [------------------------------------------------] 100%
Optional dependencies for libglade
python2: libglade-convert script
(1/1) Arming ConditionNeedsUpdate...
Packages (19) perl-clone-0.46-1 perl-encode-locale-1.05-10 perl-file-listing-6.15-2 perl-html-parser-3.81-1 perl-html-tagset-3.20-13
perl-http-cookies-6.10-3 perl-http-daemon-6.16-1 perl-http-date-6.05-6 perl-http-message-6.44-1
perl-http-negotiate-6.01-11 perl-io-html-1.004-3 perl-libwww-6.67-1 perl-lwp-mediatypes-6.04-3 perl-net-http-6.22-2
perl-try-tiny-0.31-2 perl-uri-5.17-1 perl-www-robotrules-6.02-11 perl-xml-parser-2.46-4 intltool-0.51.0-6
Total Download Size: 0,72 MiB
Total Installed Size: 1,76 MiB
:: Retrieving packages...
perl-html-parser-3.81-1-aarch64 78,7 KiB 315 KiB/s 00:00 [------------------------------------------------] 100%
perl-libwww-6.67-1-any 136,9 KiB 456 KiB/s 00:00 [------------------------------------------------] 100%
perl-http-message-6.44-1-any 71,5 KiB 210 KiB/s 00:00 [------------------------------------------------] 100%
perl-uri-5.17-1-any 79,2 KiB 208 KiB/s 00:00 [------------------------------------------------] 100%
perl-xml-parser-2.46-4-aarch64 141,8 KiB 308 KiB/s 00:00 [------------------------------------------------] 100%
perl-net-http-6.22-2-any 22,7 KiB 175 KiB/s 00:00 [------------------------------------------------] 100%
perl-http-cookies-6.10-3-any 21,7 KiB 241 KiB/s 00:00 [------------------------------------------------] 100%
intltool-0.51.0-6-any 41,1 KiB 257 KiB/s 00:00 [------------------------------------------------] 100%
perl-lwp-mediatypes-6.04-3-any 18,8 KiB 134 KiB/s 00:00 [------------------------------------------------] 100%
perl-try-tiny-0.31-2-any 18,7 KiB 144 KiB/s 00:00 [------------------------------------------------] 100%
perl-http-daemon-6.16-1-any 18,4 KiB 231 KiB/s 00:00 [------------------------------------------------] 100%
perl-io-html-1.004-3-any 14,3 KiB 179 KiB/s 00:00 [------------------------------------------------] 100%
perl-www-robotrules-6.02-11-any 12,2 KiB 203 KiB/s 00:00 [------------------------------------------------] 100%
perl-http-negotiate-6.01-11-any 12,1 KiB 173 KiB/s 00:00 [------------------------------------------------] 100%
perl-encode-locale-1.05-10-any 10,8 KiB 358 KiB/s 00:00 [------------------------------------------------] 100%
perl-html-tagset-3.20-13-any 10,8 KiB 108 KiB/s 00:00 [------------------------------------------------] 100%
perl-clone-0.46-1-aarch64 10,3 KiB 147 KiB/s 00:00 [------------------------------------------------] 100%
perl-file-listing-6.15-2-any 10,1 KiB 169 KiB/s 00:00 [------------------------------------------------] 100%
perl-http-date-6.05-6-any 9,5 KiB 135 KiB/s 00:00 [------------------------------------------------] 100%
Total (19/19) 739,6 KiB 787 KiB/s 00:01 [------------------------------------------------] 100%
(19/19) checking keys in keyring [------------------------------------------------] 100%
(19/19) checking package integrity [------------------------------------------------] 100%
(19/19) loading package files [------------------------------------------------] 100%
(19/19) checking for file conflicts [------------------------------------------------] 100%
(19/19) checking available disk space [------------------------------------------------] 100%
( 1/19) installing perl-encode-locale [------------------------------------------------] 100%
( 2/19) installing perl-http-date [------------------------------------------------] 100%
( 3/19) installing perl-file-listing [------------------------------------------------] 100%
( 4/19) installing perl-html-tagset [------------------------------------------------] 100%
( 5/19) installing perl-clone [------------------------------------------------] 100%
( 6/19) installing perl-io-html [------------------------------------------------] 100%
( 7/19) installing perl-lwp-mediatypes [------------------------------------------------] 100%
( 8/19) installing perl-uri [------------------------------------------------] 100%
( 9/19) installing perl-http-message [------------------------------------------------] 100%
(10/19) installing perl-html-parser [------------------------------------------------] 100%
(11/19) installing perl-http-cookies [------------------------------------------------] 100%
(12/19) installing perl-http-daemon [------------------------------------------------] 100%
(13/19) installing perl-http-negotiate [------------------------------------------------] 100%
(14/19) installing perl-net-http [------------------------------------------------] 100%
(15/19) installing perl-try-tiny [------------------------------------------------] 100%
(16/19) installing perl-www-robotrules [------------------------------------------------] 100%
(17/19) installing perl-libwww [------------------------------------------------] 100%
Optional dependencies for perl-libwww
perl-lwp-protocol-https: for https:// url schemes
(18/19) installing perl-xml-parser [------------------------------------------------] 100%
(19/19) installing intltool [------------------------------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Warn about old perl modules
==> Retrieving sources...
-> Downloading netactview-0.6.4.tar.bz2...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 422 100 422 0 0 519 0 --:--:-- --:--:-- --:--:-- 519
100 403 100 403 0 0 142 0 0:00:02 0:00:02 --:--:-- 400
100 291k 100 291k 0 0 98579 0 0:00:03 0:00:03 --:--:-- 1665k
-> Found drop-libgnome.patch
-> Found drop-gconf.patch
-> Found netactview_polkit
-> Found org.archlinux.pkexec.netactview.policy
netactview-0.6.4.tar.bz2 ... Passed
drop-libgnome.patch ... Passed
drop-gconf.patch ... Passed
netactview_polkit ... Passed
org.archlinux.pkexec.netactview.policy ... Passed
==> Extracting sources...
-> Extracting netactview-0.6.4.tar.bz2 with bsdtar
==> Starting prepare()...
patching file configure.ac
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "netactview"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: netactview 0.6.4-5 (Mo 24 Apr 2023 09:12:04 CEST)
Build device N2+
good luck
Thanks all, it works.
To solve it :
I installed base-devel
I applied arch=(‘any’) in the pkgbuild
it works, one more time thanks a lot all
system
Closed
April 26, 2023, 10:01pm
7
