Bugs and errors under the hood (I/O Waiting processes)
hey all
I have been hardening and optimizing my system lately and I am really happy with Manjaro and my setup, however I would like to know if there are any errors under the hood.
How do I know if there are some things running in the background that are causing trouble?
One thing I found out through lynis for instance is that one or more processes which were waiting to get IO requests handled first.
With this command I checked what it was:
while true; do date; ps auxf | awk '{if($8=="D") print $0;}'; sleep 1; done
the output from that command for me is this (repeatedly):
Sun Dec 6 12:13:31 PM CET 2020
root 93931 0.0 0.0 0 0 ? D 12:08 0:00 _ [kworker/u16:38+events_unbound]
I have a few questions:
  • Is it harmful?
  • How do I fix this (is there a fix?)?
  • How to find and solve more “bugs” like this?
Thank you in advance
That is no bug - nor error - it is a kernel process
You could try to look at the output of systemd-analyze security also…
Don’t be alarmed at the status of most system utilities that were installed by the official repos though, you could just check for unknown services…
https://askubuntu.com/questions/1182494/how-to-address-results-of-systemd-analyze-security
how do you harden this?
I guess i need to change settings in the .services files?
but i don’t know what to do, I also could not really find a guide
does anybody maybe know how to tackle this?
Did you check the search engines?
Here is a search result which should give you a start :wink:
https://duckduckgo.com/?q="systemd"+hardening+services&norw=1&t=ffnt&ia=web
I know it’s kind of lame to give a link to search results, but the subject is so diverse and deep that it’s beyond scope to post here…
alright thanks man, it’s a complicated topic indeed i wish there was some kind of guide that said which services need which settings for instance.
but thanks for the link
here is another link with possible service settings:
https://www.freedesktop.org/software/systemd/man/systemd.exec.html#Sandboxing
:sweat_smile:
Would you believe me if i told you that i have a whole submenu of bookmarks related to Systemd alone?
That page is among them :wink:
