Hi everybody.
I created an account just for reporting this issue.
I’m using manjaro with cinnamon installed last month. I have been using this S.O. for some days until tried to use accent to write some text in spanish… Well… latam keyboard works well until you try to use any accent. Then it fails.
A workaround that used to work is to add as second keyboard languaje “English Intl, Without dead keys”. After that, i could use and type using accents. The thing is if I rebooted the system, it brokes again, and the workaround stopped working. After that i cant add any languaje without getting an error.
It says:
Error activating XKB configuration.
There can be various reasons for that.If you report this situation as a bug, include the results of xprop -root | grep XKB
gsettings get org.gnome.libgnomekbd.keyboard model
gsettings get org.gnome.libgnomekbd.keyboard layout
gsettings get org.gnome.libgnomekbd.keyboard options
I’m a good boy, and will add these logs as requested.
_XKB_RULES_NAMES_BACKUP(STRING) = "evdev", "", "latam", "nodeadkeys", ""
_XKB_RULES_NAMES(STRING) = "evdev", "", "latam", "nodeadkeys", ""
Thanks in advance for your help.
