I noticed a process ~/.local/share/Steam/ubuntu12_32/../ubuntu12_64/fossilize_replay stays lingering around even after you exit Steam eg. shut it down.
This process also seems to be launched multiple times.
And after a few times it consumes 100% CPU.
- Using
steam-manjaroversion1.0.0.66-2
System info from Steam
Computer Information:
Manufacturer: Unknown
Model: Unknown
Form Factor: Desktop
No Touch Input Detected
Processor Information:
CPU Vendor: GenuineIntel
CPU Brand: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
CPU Family: 0x6
CPU Model: 0x3f
CPU Stepping: 0x2
CPU Type: 0x0
Speed: 3600 Mhz
12 logical processors
6 physical processors
HyperThreading: Supported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Unsupported
SSE41: Supported
SSE42: Supported
AES: Supported
AVX: Supported
AVX2: Unsupported
AVX512F: Unsupported
AVX512PF: Unsupported
AVX512ER: Unsupported
AVX512CD: Unsupported
AVX512VNNI: Unsupported
SHA: Unsupported
CMPXCHG16B: Supported
LAHF/SAHF: Supported
PrefetchW: Unsupported
Operating System Version:
"Manjaro Linux" (64 bit)
Kernel Name: Linux
Kernel Version: 5.9.8-2-MANJARO
X Server Vendor: The X.Org Foundation
X Server Release: 12009000
X Window Manager: KWin
Steam Runtime Version: steam-runtime_0.20201005.0
Video Card:
Driver: NVIDIA Corporation GeForce GTX 1080 Ti/PCIe/SSE2
Driver Version: 4.6.0 NVIDIA 455.45.01
OpenGL Version: 4.6
Desktop Color Depth: 24 bits per pixel
Monitor Refresh Rate: 59 Hz
VendorID: 0x10de
DeviceID: 0x1b06
Revision Not Detected
Number of Monitors: 1
Number of Logical Video Cards: 1
Primary Display Resolution: 2560 x 1080
Desktop Resolution: 2560 x 1080
Primary Display Size: 26.50" x 11.18" (28.74" diag)
67.3cm x 28.4cm (73.0cm diag)
Primary Bus: PCI Express 16x
Primary VRAM: 11264 MB
Supported MSAA Modes: 2x 4x 8x 16x
Sound card:
Audio device: Realtek ALC1150
RAM: 32025 Mb
VR Hardware:
VR Headset: None detected
Miscellaneous:
UI Language: English
LANG: en_US.UTF-8
Total Hard Disk Space Available: 3815447 Mb
Largest Free Hard Disk Block: 3522134 Mb
"LD_* scout runtime" information:
"can-write-uinput" : true,
"steam-installation" : {
"path" : "/home/trimoon/.local/share/Steam",
"data_path" : "/home/trimoon/.local/share/Steam",
"bin32_path" : "/home/trimoon/.local/share/Steam/ubuntu12_32",
"issues" : [
"unexpected-steam-uri-handler"
"runtime" : {
"path" : "/home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime",
"version" : "0.20201005.0",
"issues" : [
"pinned_libs_32" : {
"list" : [
" 431215 0 drwxr-xr-x 1 trimoon trimoon 292 Kas 5 12:43 pinned_libs_32",
" 431217 4 lrwxrwxrwx 1 trimoon trimoon 96 Kas 5 12:43 pinned_libs_32/libdbus-1.so.3 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/lib/i386-linux-gnu/libdbus-1.so.3.5.8",
" 431218 4 -rw-r--r-- 1 trimoon trimoon 58 Kas 5 12:43 pinned_libs_32/system_libdbus-1.so.3",
" 431219 0 -rw-r--r-- 1 trimoon trimoon 0 Kas 5 12:43 pinned_libs_32/has_pins",
" 431220 4 lrwxrwxrwx 1 trimoon trimoon 101 Kas 5 12:43 pinned_libs_32/libGLU.so.1 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libGLU.so.1.3.08004",
" 431221 4 -rw-r--r-- 1 trimoon trimoon 50 Kas 5 12:43 pinned_libs_32/system_libGLU.so.1",
" 431222 4 lrwxrwxrwx 1 trimoon trimoon 98 Kas 5 12:43 pinned_libs_32/libcurl.so.4 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libcurl.so.4.2.0",
" 431223 4 -rw-r--r-- 1 trimoon trimoon 52 Kas 5 12:43 pinned_libs_32/system_libcurl.so.4",
" 431224 4 lrwxrwxrwx 1 trimoon trimoon 98 Kas 5 12:43 pinned_libs_32/libjack.so.0 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libjack.so.0.1.0",
" 431225 4 -rw-r--r-- 1 trimoon trimoon 53 Kas 5 12:43 pinned_libs_32/system_libjack.so.0",
" 431235 4 lrwxrwxrwx 1 trimoon trimoon 12 Kas 5 12:43 pinned_libs_32/libcurl.so.3 -> libcurl.so.4"
"pinned_libs_64" : {
"list" : [
" 431216 0 drwxr-xr-x 1 trimoon trimoon 320 Kas 5 12:43 pinned_libs_64",
" 431226 4 lrwxrwxrwx 1 trimoon trimoon 103 Kas 5 12:43 pinned_libs_64/libGLU.so.1 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/x86_64-linux-gnu/libGLU.so.1.3.08004",
" 431227 4 -rw-r--r-- 1 trimoon trimoon 46 Kas 5 12:43 pinned_libs_64/system_libGLU.so.1",
" 431228 0 -rw-r--r-- 1 trimoon trimoon 0 Kas 5 12:43 pinned_libs_64/has_pins",
" 431229 4 lrwxrwxrwx 1 trimoon trimoon 100 Kas 5 12:43 pinned_libs_64/libcurl.so.4 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/x86_64-linux-gnu/libcurl.so.4.2.0",
" 431230 4 -rw-r--r-- 1 trimoon trimoon 48 Kas 5 12:43 pinned_libs_64/system_libcurl.so.4",
" 431231 4 lrwxrwxrwx 1 trimoon trimoon 110 Kas 5 12:43 pinned_libs_64/libdbusmenu-glib.so.4 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/x86_64-linux-gnu/libdbusmenu-glib.so.4.0.13",
" 431232 4 -rw-r--r-- 1 trimoon trimoon 67 Kas 5 12:43 pinned_libs_64/system_libdbusmenu-glib.so.4",
" 431233 4 lrwxrwxrwx 1 trimoon trimoon 100 Kas 5 12:43 pinned_libs_64/libjack.so.0 -> /home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/x86_64-linux-gnu/libjack.so.0.1.0",
" 431234 4 -rw-r--r-- 1 trimoon trimoon 49 Kas 5 12:43 pinned_libs_64/system_libjack.so.0",
" 431236 4 lrwxrwxrwx 1 trimoon trimoon 12 Kas 5 12:43 pinned_libs_64/libcurl.so.3 -> libcurl.so.4"
"os-release" : {
"id" : "manjaro",
"id_like" : [
"arch"
"name" : "Manjaro Linux",
"pretty_name" : "Manjaro Linux",
"build_id" : "rolling"
"container" : {
"type" : "none"
"driver_environment" : [
"architectures" : {
"i386-linux-gnu" : {
"can-run" : true,
"library-issues-summary" : [
"graphics-details" : {
"x11/vulkan" : {
"messages" : "ERROR: [Loader Message] Code 0 : /usr/lib/libvulkan_intel.so: wrong ELF class: ELFCLASS64\nERROR: [Loader Message] Code 0 : /usr/lib/libvulkan_radeon.so: wrong ELF class: ELFCLASS64\nERROR: [Loader Message] Code 0 : /home/trimoon/.local/share/Steam/ubuntu12_64/steamoverlayvulkanlayer.so: wrong ELF class: ELFCLASS64\n",
"renderer" : "GeForce GTX 1080 Ti",
"version" : "1.2.142 (device 10de:1b06) (driver 455.180.64)"
"x11/vdpau" : {
"renderer" : "NVIDIA VDPAU Driver Shared Library 455.45.01 Thu Nov 5 22:52:28 UTC 2020\n",
"version" : null
"x11/vaapi" : {
"messages" : "libva error: /usr/lib32/dri/nvidia_drv_video.so has no function __vaDriverInit_1_0\nvaInitialize (va_display, &major_version, &minor_version) failed: unknown libva error (-1)\n",
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"glx/gl" : {
"renderer" : "GeForce GTX 1080 Ti/PCIe/SSE2",
"version" : "4.6.0 NVIDIA 455.45.01",
"library-vendor" : "glvnd"
"egl_x11/gl" : {
"egl_x11/glesv2" : {
"version" : "OpenGL ES 3.2 NVIDIA 455.45.01",
"dri_drivers" : [
"library_path" : "/usr/lib32/dri/i915_dri.so"
"library_path" : "/usr/lib32/dri/i965_dri.so"
"library_path" : "/usr/lib32/dri/iris_dri.so"
"library_path" : "/usr/lib32/dri/kms_swrast_dri.so"
"library_path" : "/usr/lib32/dri/nouveau_dri.so"
"library_path" : "/usr/lib32/dri/nouveau_vieux_dri.so"
"library_path" : "/usr/lib32/dri/r200_dri.so"
"library_path" : "/usr/lib32/dri/r300_dri.so"
"library_path" : "/usr/lib32/dri/r600_dri.so"
"library_path" : "/usr/lib32/dri/radeon_dri.so"
"library_path" : "/usr/lib32/dri/radeonsi_dri.so"
"library_path" : "/usr/lib32/dri/swrast_dri.so"
"library_path" : "/usr/lib32/dri/virtio_gpu_dri.so"
"library_path" : "/usr/lib32/dri/vmwgfx_dri.so"
"va-api_drivers" : [
"library_path" : "/usr/lib32/dri/i965_drv_video.so"
"library_path" : "/usr/lib32/dri/nouveau_drv_video.so"
"library_path" : "/usr/lib32/dri/nvidia_drv_video.so"
"library_path" : "/usr/lib32/dri/r600_drv_video.so"
"library_path" : "/usr/lib32/dri/radeonsi_drv_video.so"
"library_path" : "/usr/lib32/dri/s3g_drv_video.so"
"library_path" : "/usr/lib32/dri/vdpau_drv_video.so"
"library_path" : "/home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/dri/dummy_drv_video.so"
"vdpau_drivers" : [
"library_path" : "/usr/lib32/vdpau/libvdpau_nouveau.so",
"library_link" : "libvdpau_nouveau.so.1.0.0"
"library_path" : "/usr/lib32/vdpau/libvdpau_nouveau.so.1",
"library_path" : "/usr/lib32/vdpau/libvdpau_nvidia.so",
"library_link" : "libvdpau_nvidia.so.1"
"library_path" : "/usr/lib32/vdpau/libvdpau_nvidia.so.1",
"library_link" : "libvdpau_nvidia.so.455.45.01"
"library_path" : "/usr/lib32/vdpau/libvdpau_r300.so",
"library_link" : "libvdpau_r300.so.1.0.0"
"library_path" : "/usr/lib32/vdpau/libvdpau_r300.so.1",
"library_path" : "/usr/lib32/vdpau/libvdpau_r600.so",
"library_link" : "libvdpau_r600.so.1.0.0"
"library_path" : "/usr/lib32/vdpau/libvdpau_r600.so.1",
"library_path" : "/usr/lib32/vdpau/libvdpau_radeonsi.so",
"library_link" : "libvdpau_radeonsi.so.1.0.0"
"library_path" : "/usr/lib32/vdpau/libvdpau_radeonsi.so.1",
"library_path" : "/usr/lib32/vdpau/libvdpau_trace.so",
"library_link" : "libvdpau_trace.so.1"
"library_path" : "/usr/lib32/vdpau/libvdpau_trace.so.1",
"library_link" : "libvdpau_trace.so.1.0.0"
"glx_drivers" : [
"library_soname" : "libGLX_indirect.so.0",
"library_path" : "/usr/lib32/libGLX_mesa.so.0.0.0"
"library_soname" : "libGLX_mesa.so.0",
"library_soname" : "libGLX_nvidia.so.0",
"library_path" : "/usr/lib32/libGLX_nvidia.so.455.45.01"
"x86_64-linux-gnu" : {
"can-run" : true,
"x11/vulkan" : {
"messages" : "ERROR: [Loader Message] Code 0 : /usr/lib32/libvulkan_intel.so: wrong ELF class: ELFCLASS32\nERROR: [Loader Message] Code 0 : /usr/lib32/libvulkan_radeon.so: wrong ELF class: ELFCLASS32\nERROR: [Loader Message] Code 0 : /home/trimoon/.local/share/Steam/ubuntu12_32/steamoverlayvulkanlayer.so: wrong ELF class: ELFCLASS32\n",
"x11/vdpau" : {
"renderer" : "NVIDIA VDPAU Driver Shared Library 455.45.01 Thu Nov 5 22:54:01 UTC 2020\n",
"version" : null
"x11/vaapi" : {
"messages" : "vaCreateSurfaces (va_display, VA_RT_FORMAT_RGB32, width, height, surfaces, surfaces_count, &attr, 1) failed: attribute not supported (10)\nx86_64-linux-gnu-check-va-api: vdpau_video.c:325: vdpau_DestroySurfaces: Assertion `obj_surface' failed.\ntimeout: the monitored command dumped core\n",
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : -1,
"terminating-signal" : 6,
"terminating-signal-name" : "Aborted"
"glx/gl" : {
"egl_x11/gl" : {
"dri_drivers" : [
"library_path" : "/usr/lib/dri/i915_dri.so"
"library_path" : "/usr/lib/dri/i965_dri.so"
"library_path" : "/usr/lib/dri/iris_dri.so"
"library_path" : "/usr/lib/dri/kms_swrast_dri.so"
"library_path" : "/usr/lib/dri/nouveau_dri.so"
"library_path" : "/usr/lib/dri/nouveau_vieux_dri.so"
"library_path" : "/usr/lib/dri/r200_dri.so"
"library_path" : "/usr/lib/dri/r300_dri.so"
"library_path" : "/usr/lib/dri/r600_dri.so"
"library_path" : "/usr/lib/dri/radeon_dri.so"
"library_path" : "/usr/lib/dri/radeonsi_dri.so"
"library_path" : "/usr/lib/dri/swrast_dri.so"
"library_path" : "/usr/lib/dri/virtio_gpu_dri.so"
"library_path" : "/usr/lib/dri/vmwgfx_dri.so"
"library_path" : "/usr/lib/dri/zink_dri.so"
"library_path" : "/usr/lib/dri/i965_drv_video.so"
"library_path" : "/usr/lib/dri/nouveau_drv_video.so"
"library_path" : "/usr/lib/dri/nvidia_drv_video.so"
"library_path" : "/usr/lib/dri/r600_drv_video.so"
"library_path" : "/usr/lib/dri/radeonsi_drv_video.so"
"library_path" : "/usr/lib/dri/s3g_drv_video.so"
"library_path" : "/usr/lib/dri/vdpau_drv_video.so"
"library_path" : "/home/trimoon/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/x86_64-linux-gnu/dri/dummy_drv_video.so"
"vdpau_drivers" : [
"library_path" : "/usr/lib/vdpau/libvdpau_nouveau.so",
"library_path" : "/usr/lib/vdpau/libvdpau_nouveau.so.1",
"library_path" : "/usr/lib/vdpau/libvdpau_nvidia.so",
"library_path" : "/usr/lib/vdpau/libvdpau_nvidia.so.1",
"library_path" : "/usr/lib/vdpau/libvdpau_r300.so",
"library_path" : "/usr/lib/vdpau/libvdpau_r300.so.1",
"library_path" : "/usr/lib/vdpau/libvdpau_r600.so",
"library_path" : "/usr/lib/vdpau/libvdpau_r600.so.1",
"library_path" : "/usr/lib/vdpau/libvdpau_radeonsi.so",
"library_path" : "/usr/lib/vdpau/libvdpau_radeonsi.so.1",
"library_path" : "/usr/lib/vdpau/libvdpau_trace.so",
"library_path" : "/usr/lib/vdpau/libvdpau_trace.so.1",
"glx_drivers" : [
"library_path" : "/usr/lib/libGLX_mesa.so.0.0.0"
"library_path" : "/usr/lib/libGLX_nvidia.so.455.45.01"
"locale-issues" : [
"c-utf8-missing",
"i18n-supported-missing"
"locales" : {
"<default>" : {
"resulting-name" : "LC_CTYPE=en_US.UTF-8;LC_NUMERIC=tr_TR.UTF-8;LC_TIME=tr_TR.UTF-8;LC_COLLATE=en_US.UTF-8;LC_MONETARY=tr_TR.UTF-8;LC_MESSAGES=en_US.UTF-8;LC_PAPER=tr_TR.UTF-8;LC_NAME=tr_TR.UTF-8;LC_ADDRESS=tr_TR.UTF-8;LC_TELEPHONE=tr_TR.UTF-8;LC_MEASUREMENT=tr_TR.UTF-8;LC_IDENTIFICATION=tr_TR.UTF-8",
"charset" : "UTF-8",
"is_utf8" : true
"C" : {
"resulting-name" : "C",
"charset" : "ANSI_X3.4-1968",
"is_utf8" : false
"C.UTF-8" : {
"error-domain" : "srt-locale-error-quark",
"error-code" : 0,
"error" : "No such file or directory"
"en_US.UTF-8" : {
"resulting-name" : "en_US.UTF-8",
"is_utf8" : true
"egl" : {
"icds" : [
"json_path" : "/usr/share/glvnd/egl_vendor.d/10_nvidia.json",
"library_path" : "libEGL_nvidia.so.0"
"json_path" : "/usr/share/glvnd/egl_vendor.d/50_mesa.json",
"library_path" : "libEGL_mesa.so.0"
"vulkan" : {
"icds" : [
"json_path" : "/usr/share/vulkan/icd.d/intel_icd.i686.json",
"library_path" : "/usr/lib32/libvulkan_intel.so",
"api_version" : "1.2.145"
"json_path" : "/usr/share/vulkan/icd.d/radeon_icd.i686.json",
"library_path" : "/usr/lib32/libvulkan_radeon.so",
"api_version" : "1.2.131"
"json_path" : "/usr/share/vulkan/icd.d/intel_icd.x86_64.json",
"library_path" : "/usr/lib/libvulkan_intel.so",
"json_path" : "/usr/share/vulkan/icd.d/radeon_icd.x86_64.json",
"library_path" : "/usr/lib/libvulkan_radeon.so",
"json_path" : "/usr/share/vulkan/icd.d/nvidia_icd.json",
"library_path" : "libGLX_nvidia.so.0",
"api_version" : "1.2.142"
"desktop-entries" : [
"id" : "steam.desktop",
"commandline" : "/usr/bin/steam-runtime %U",
"filename" : "/usr/share/applications/steam.desktop",
"default_steam_uri_handler" : true,
"steam_uri_handler" : true
"cpu-features" : {
"x86-64" : true,
"sse3" : true,
"cmpxchg16b" : true
"scout runtime container" information:
"steamscript_path" : "/usr/lib/steam/steam",
"steamscript_version" : "1.0.0.66",
"issues" : [
"missing-steam-uri-handler",
"runtime" : {
"path" : "/",
"version" : "0.20201022.1",
"issues" : [
"overrides" : {
"list" : [
" 58 0 drwxr-xr-x 4 trimoon trimoon 80 Kas 22 14:04 overrides",
" 75 0 drwxr-xr-x 4 trimoon trimoon 140 Kas 22 14:04 overrides/lib",
" 200 0 drwxr-xr-x 4 trimoon trimoon 2040 Kas 22 14:04 overrides/lib/x86_64-linux-gnu",
" 304 0 drwxr-xr-x 2 trimoon trimoon 480 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri",
" 326 0 lrwxrwxrwx 1 trimoon trimoon 43 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/nvidia_drv_video.so -> /run/host/usr/lib64/dri/nvidia_drv_video.so",
" 325 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/s3g_drv_video.so -> /run/host/usr/lib64/dri/s3g_drv_video.so",
" 324 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/i965_drv_video.so -> /run/host/usr/lib64/dri/i965_drv_video.so",
" 323 0 lrwxrwxrwx 1 trimoon trimoon 42 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/vdpau_drv_video.so -> /run/host/usr/lib64/dri/vdpau_drv_video.so",
" 322 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/i915_dri.so -> /run/host/usr/lib64/dri/i915_dri.so",
" 321 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/i965_dri.so -> /run/host/usr/lib64/dri/i965_dri.so",
" 320 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/iris_dri.so -> /run/host/usr/lib64/dri/iris_dri.so",
" 319 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/kms_swrast_dri.so -> /run/host/usr/lib64/dri/kms_swrast_dri.so",
" 318 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/nouveau_dri.so -> /run/host/usr/lib64/dri/nouveau_dri.so",
" 317 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/nouveau_vieux_dri.so -> /run/host/usr/lib64/dri/nouveau_vieux_dri.so",
" 316 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/r200_dri.so -> /run/host/usr/lib64/dri/r200_dri.so",
" 315 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/r300_dri.so -> /run/host/usr/lib64/dri/r300_dri.so",
" 314 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/r600_dri.so -> /run/host/usr/lib64/dri/r600_dri.so",
" 313 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/radeon_dri.so -> /run/host/usr/lib64/dri/radeon_dri.so",
" 312 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/radeonsi_dri.so -> /run/host/usr/lib64/dri/radeonsi_dri.so",
" 311 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/swrast_dri.so -> /run/host/usr/lib64/dri/swrast_dri.so",
" 310 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/virtio_gpu_dri.so -> /run/host/usr/lib64/dri/virtio_gpu_dri.so",
" 309 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/vmwgfx_dri.so -> /run/host/usr/lib64/dri/vmwgfx_dri.so",
" 308 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/zink_dri.so -> /run/host/usr/lib64/dri/zink_dri.so",
" 307 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/nouveau_drv_video.so -> /run/host/usr/lib64/dri/nouveau_drv_video.so",
" 306 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/r600_drv_video.so -> /run/host/usr/lib64/dri/r600_drv_video.so",
" 305 0 lrwxrwxrwx 1 trimoon trimoon 45 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so -> /run/host/usr/lib64/dri/radeonsi_drv_video.so",
" 303 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libEGL.so.1 -> /run/host/usr/lib/libEGL.so.1.1.0",
" 302 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLdispatch.so.0 -> /run/host/usr/lib/libGLdispatch.so.0.0.0",
" 301 0 lrwxrwxrwx 1 trimoon trimoon 31 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libdl.so.2 -> /run/host/usr/lib/libdl-2.32.so",
" 300 0 lrwxrwxrwx 1 trimoon trimoon 30 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libc.so.6 -> /run/host/usr/lib/libc-2.32.so",
" 299 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libBrokenLocale.so.1 -> /run/host/usr/lib/libBrokenLocale-2.32.so",
" 298 0 lrwxrwxrwx 1 trimoon trimoon 32 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libanl.so.1 -> /run/host/usr/lib/libanl-2.32.so",
" 297 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libpthread.so.0 -> /run/host/usr/lib/libpthread-2.32.so",
" 296 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libcrypt.so.1 -> /run/host/usr/lib/libcrypt-2.32.so",
" 295 0 lrwxrwxrwx 1 trimoon trimoon 30 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libm.so.6 -> /run/host/usr/lib/libm-2.32.so",
" 294 0 lrwxrwxrwx 1 trimoon trimoon 32 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libmemusage.so -> /run/host/usr/lib/libmemusage.so",
" 293 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libmvec.so.1 -> /run/host/usr/lib/libmvec-2.32.so",
" 292 0 lrwxrwxrwx 1 trimoon trimoon 32 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnsl.so.1 -> /run/host/usr/lib/libnsl-2.32.so",
" 291 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libpcprofile.so -> /run/host/usr/lib/libpcprofile.so",
" 290 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libresolv.so.2 -> /run/host/usr/lib/libresolv-2.32.so",
" 289 0 lrwxrwxrwx 1 trimoon trimoon 31 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/librt.so.1 -> /run/host/usr/lib/librt-2.32.so",
" 288 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libthread_db.so.1 -> /run/host/usr/lib/libthread_db-1.0.so",
" 287 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libutil.so.1 -> /run/host/usr/lib/libutil-2.32.so",
" 286 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libEGL_nvidia.so.0 -> /run/host/usr/lib/libEGL_nvidia.so.455.45.01",
" 285 0 lrwxrwxrwx 1 trimoon trimoon 45 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-glsi.so.455.45.01 -> /run/host/usr/lib/libnvidia-glsi.so.455.45.01",
" 284 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libEGL_mesa.so.0 -> /run/host/usr/lib/libEGL_mesa.so.0.0.0",
" 283 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libgbm.so.1 -> /run/host/usr/lib/libgbm.so.1.0.0",
" 282 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libdrm.so.2 -> /run/host/usr/lib/libdrm.so.2.4.0",
" 281 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libwayland-server.so.0 -> /run/host/usr/lib/libwayland-server.so.0.1.0",
" 280 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libffi.so.7 -> /run/host/usr/lib/libffi.so.7.1.0",
" 279 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libexpat.so.1 -> /run/host/usr/lib/libexpat.so.1.6.12",
" 278 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libglapi.so.0 -> /run/host/usr/lib/libglapi.so.0.0.0",
" 277 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libX11-xcb.so.1 -> /run/host/usr/lib/libX11-xcb.so.1.0.0",
" 276 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb.so.1 -> /run/host/usr/lib/libxcb.so.1.1.0",
" 275 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libXau.so.6 -> /run/host/usr/lib/libXau.so.6.0.0",
" 274 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libXdmcp.so.6 -> /run/host/usr/lib/libXdmcp.so.6.0.0",
" 273 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb-dri2.so.0 -> /run/host/usr/lib/libxcb-dri2.so.0.0.0",
" 272 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb-xfixes.so.0 -> /run/host/usr/lib/libxcb-xfixes.so.0.0.0",
" 271 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libwayland-client.so.0 -> /run/host/usr/lib/libwayland-client.so.0.3.0",
" 270 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb-dri3.so.0 -> /run/host/usr/lib/libxcb-dri3.so.0.0.0",
" 269 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb-present.so.0 -> /run/host/usr/lib/libxcb-present.so.0.0.0",
" 268 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb-sync.so.1 -> /run/host/usr/lib/libxcb-sync.so.1.0.0",
" 267 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxshmfence.so.1 -> /run/host/usr/lib/libxshmfence.so.1.0.0",
" 266 0 lrwxrwxrwx 1 trimoon trimoon 32 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGL.so.1 -> /run/host/usr/lib/libGL.so.1.7.0",
" 265 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLX.so.0 -> /run/host/usr/lib/libGLX.so.0.0.0",
" 264 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libX11.so.6 -> /run/host/usr/lib/libX11.so.6.3.0",
" 263 0 lrwxrwxrwx 1 trimoon trimoon 50 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLESv1_CM_nvidia.so.1 -> /run/host/usr/lib/libGLESv1_CM_nvidia.so.455.45.01",
" 262 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLESv2.so.2 -> /run/host/usr/lib/libGLESv2.so.2.1.0",
" 261 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLX_nvidia.so.0 -> /run/host/usr/lib/libGLX_nvidia.so.455.45.01",
" 260 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-tls.so.455.45.01 -> /run/host/usr/lib/libnvidia-tls.so.455.45.01",
" 259 0 lrwxrwxrwx 1 trimoon trimoon 47 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-glcore.so.455.45.01 -> /run/host/usr/lib/libnvidia-glcore.so.455.45.01",
" 258 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libXext.so.6 -> /run/host/usr/lib/libXext.so.6.4.0",
" 257 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLX_mesa.so.0 -> /run/host/usr/lib/libGLX_mesa.so.0.0.0",
" 256 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb-glx.so.0 -> /run/host/usr/lib/libxcb-glx.so.0.0.0",
" 255 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libXfixes.so.3 -> /run/host/usr/lib/libXfixes.so.3.1.0",
" 254 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libXdamage.so.1 -> /run/host/usr/lib/libXdamage.so.1.1.0",
" 253 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libXxf86vm.so.1 -> /run/host/usr/lib/libXxf86vm.so.1.0.0",
" 252 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLX_indirect.so.0 -> /run/host/usr/lib/libGLX_mesa.so.0.0.0",
" 251 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libOpenGL.so.0 -> /run/host/usr/lib/libOpenGL.so.0.0.0",
" 250 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libvulkan.so.1 -> /run/host/usr/lib/libvulkan.so.1.2.159",
" 249 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libvdpau.so.1 -> /run/host/usr/lib/libvdpau.so.1.0.0",
" 248 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libva.so.2 -> /run/host/usr/lib/libva.so.2.900.0",
" 247 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libva-drm.so.2 -> /run/host/usr/lib/libva-drm.so.2.900.0",
" 246 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libva-glx.so.2 -> /run/host/usr/lib/libva-glx.so.2.900.0",
" 245 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libva-x11.so.2 -> /run/host/usr/lib/libva-x11.so.2.900.0",
" 244 0 lrwxrwxrwx 1 trimoon trimoon 47 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libGLESv2_nvidia.so.2 -> /run/host/usr/lib/libGLESv2_nvidia.so.455.45.01",
" 243 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libcuda.so.1 -> /run/host/usr/lib/libcuda.so.455.45.01",
" 242 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-cbl.so.455.45.01 -> /run/host/usr/lib/libnvidia-cbl.so.455.45.01",
" 241 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-cfg.so.1 -> /run/host/usr/lib/libnvidia-cfg.so.455.45.01",
" 240 0 lrwxrwxrwx 1 trimoon trimoon 48 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-eglcore.so.455.45.01 -> /run/host/usr/lib/libnvidia-eglcore.so.455.45.01",
" 239 0 lrwxrwxrwx 1 trimoon trimoon 47 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-encode.so.1 -> /run/host/usr/lib/libnvidia-encode.so.455.45.01",
" 238 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvcuvid.so.1 -> /run/host/usr/lib/libnvcuvid.so.455.45.01",
" 237 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-fbc.so.1 -> /run/host/usr/lib/libnvidia-fbc.so.455.45.01",
" 236 0 lrwxrwxrwx 1 trimoon trimoon 50 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-glvkspirv.so.455.45.01 -> /run/host/usr/lib/libnvidia-glvkspirv.so.455.45.01",
" 235 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-ifr.so.1 -> /run/host/usr/lib/libnvidia-ifr.so.455.45.01",
" 234 0 lrwxrwxrwx 1 trimoon trimoon 43 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-ml.so.1 -> /run/host/usr/lib/libnvidia-ml.so.455.45.01",
" 233 0 lrwxrwxrwx 1 trimoon trimoon 52 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.1 -> /run/host/usr/lib/libnvidia-opticalflow.so.455.45.01",
" 232 0 lrwxrwxrwx 1 trimoon trimoon 55 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.1 -> /run/host/usr/lib/libnvidia-ptxjitcompiler.so.455.45.01",
" 231 0 lrwxrwxrwx 1 trimoon trimoon 47 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnvidia-rtcore.so.455.45.01 -> /run/host/usr/lib/libnvidia-rtcore.so.455.45.01",
" 230 0 lrwxrwxrwx 1 trimoon trimoon 31 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libgcc_s.so.1 -> /run/host/usr/lib/libgcc_s.so.1",
" 225 0 drwxr-xr-x 4 trimoon trimoon 80 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/vulkan",
" 228 0 drwxr-xr-x 2 trimoon trimoon 60 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/vulkan/2",
" 229 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/vulkan/2/libvulkan_intel.so -> /run/host/usr/lib/libvulkan_intel.so",
" 226 0 drwxr-xr-x 2 trimoon trimoon 60 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/vulkan/3",
" 227 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/vulkan/3/libvulkan_radeon.so -> /run/host/usr/lib/libvulkan_radeon.so",
" 224 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxcb-randr.so.0 -> /run/host/usr/lib/libxcb-randr.so.0.1.0",
" 223 0 lrwxrwxrwx 1 trimoon trimoon 32 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libz.so.1 -> /run/host/usr/lib/libz.so.1.2.11",
" 222 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libzstd.so.1 -> /run/host/usr/lib/libzstd.so.1.4.5",
" 221 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libstdc++.so.6 -> /run/host/usr/lib/libstdc++.so.6.0.28",
" 220 0 lrwxrwxrwx 1 trimoon trimoon 31 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libLLVM-11.so -> /run/host/usr/lib/libLLVM-11.so",
" 219 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libedit.so.0 -> /run/host/usr/lib/libedit.so.0.0.63",
" 218 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libncursesw.so.6 -> /run/host/usr/lib/libncursesw.so.6.2",
" 217 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libxml2.so.2 -> /run/host/usr/lib/libxml2.so.2.9.10",
" 216 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libicuuc.so.67 -> /run/host/usr/lib/libicuuc.so.67.1",
" 215 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libicudata.so.67 -> /run/host/usr/lib/libicudata.so.67.1",
" 214 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/liblzma.so.5 -> /run/host/usr/lib/liblzma.so.5.2.5",
" 213 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1 -> /run/host/usr/lib/libdrm_amdgpu.so.1.0.0",
" 212 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libelf.so.1 -> /run/host/usr/lib/libelf-0.181.so",
" 211 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libidn2.so.0 -> /run/host/usr/lib/libidn2.so.0.3.7",
" 210 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libunistring.so.2 -> /run/host/usr/lib/libunistring.so.2.1.0",
" 209 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnss_compat.so.2 -> /run/host/usr/lib/libnss_compat-2.32.so",
" 208 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnss_db.so.2 -> /run/host/usr/lib/libnss_db-2.32.so",
" 207 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnss_files.so.2 -> /run/host/usr/lib/libnss_files-2.32.so",
" 206 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libnss_dns.so.2 -> /run/host/usr/lib/libnss_dns-2.32.so",
" 205 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libdrm_intel.so.1 -> /run/host/usr/lib/libdrm_intel.so.1.0.0",
" 204 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libpciaccess.so.0 -> /run/host/usr/lib/libpciaccess.so.0.11.1",
" 203 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libdrm_radeon.so.1 -> /run/host/usr/lib/libdrm_radeon.so.1.0.1",
" 202 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libdrm_nouveau.so.2 -> /run/host/usr/lib/libdrm_nouveau.so.2.0.0",
" 201 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/x86_64-linux-gnu/libsensors.so.5 -> /run/host/usr/lib/libsensors.so.5.0.0",
" 79 0 drwxr-xr-x 4 trimoon trimoon 1920 Kas 22 14:04 overrides/lib/i386-linux-gnu",
" 177 0 drwxr-xr-x 2 trimoon trimoon 480 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri",
" 199 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/zink_dri.so -> /run/host/usr/lib/dri/zink_dri.so",
" 198 0 lrwxrwxrwx 1 trimoon trimoon 43 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/nvidia_drv_video.so -> /run/host/usr/lib32/dri/nvidia_drv_video.so",
" 197 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/s3g_drv_video.so -> /run/host/usr/lib32/dri/s3g_drv_video.so",
" 196 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/i965_drv_video.so -> /run/host/usr/lib32/dri/i965_drv_video.so",
" 195 0 lrwxrwxrwx 1 trimoon trimoon 42 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/vdpau_drv_video.so -> /run/host/usr/lib32/dri/vdpau_drv_video.so",
" 194 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/nouveau_drv_video.so -> /run/host/usr/lib32/dri/nouveau_drv_video.so",
" 193 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/r600_drv_video.so -> /run/host/usr/lib32/dri/r600_drv_video.so",
" 192 0 lrwxrwxrwx 1 trimoon trimoon 45 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/radeonsi_drv_video.so -> /run/host/usr/lib32/dri/radeonsi_drv_video.so",
" 191 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/i915_dri.so -> /run/host/usr/lib32/dri/i915_dri.so",
" 190 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/i965_dri.so -> /run/host/usr/lib32/dri/i965_dri.so",
" 189 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/iris_dri.so -> /run/host/usr/lib32/dri/iris_dri.so",
" 188 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/kms_swrast_dri.so -> /run/host/usr/lib32/dri/kms_swrast_dri.so",
" 187 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/nouveau_dri.so -> /run/host/usr/lib32/dri/nouveau_dri.so",
" 186 0 lrwxrwxrwx 1 trimoon trimoon 44 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/nouveau_vieux_dri.so -> /run/host/usr/lib32/dri/nouveau_vieux_dri.so",
" 185 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/r200_dri.so -> /run/host/usr/lib32/dri/r200_dri.so",
" 184 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/r300_dri.so -> /run/host/usr/lib32/dri/r300_dri.so",
" 183 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/r600_dri.so -> /run/host/usr/lib32/dri/r600_dri.so",
" 182 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/radeon_dri.so -> /run/host/usr/lib32/dri/radeon_dri.so",
" 181 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/radeonsi_dri.so -> /run/host/usr/lib32/dri/radeonsi_dri.so",
" 180 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/swrast_dri.so -> /run/host/usr/lib32/dri/swrast_dri.so",
" 179 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/virtio_gpu_dri.so -> /run/host/usr/lib32/dri/virtio_gpu_dri.so",
" 178 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/dri/vmwgfx_dri.so -> /run/host/usr/lib32/dri/vmwgfx_dri.so",
" 176 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libEGL.so.1 -> /run/host/usr/lib32/libEGL.so.1.1.0",
" 175 0 lrwxrwxrwx 1 trimoon trimoon 42 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGLdispatch.so.0 -> /run/host/usr/lib32/libGLdispatch.so.0.0.0",
" 174 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/i386-linux-gnu/libdl.so.2 -> /run/host/usr/lib32/libdl-2.32.so",
" 173 0 lrwxrwxrwx 1 trimoon trimoon 32 Kas 22 14:04 overrides/lib/i386-linux-gnu/libc.so.6 -> /run/host/usr/lib32/libc-2.32.so",
" 172 0 lrwxrwxrwx 1 trimoon trimoon 43 Kas 22 14:04 overrides/lib/i386-linux-gnu/libBrokenLocale.so.1 -> /run/host/usr/lib32/libBrokenLocale-2.32.so",
" 171 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/i386-linux-gnu/libanl.so.1 -> /run/host/usr/lib32/libanl-2.32.so",
" 170 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libpthread.so.0 -> /run/host/usr/lib32/libpthread-2.32.so",
" 169 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/i386-linux-gnu/libcrypt.so.1 -> /run/host/usr/lib32/libcrypt-2.32.so",
" 168 0 lrwxrwxrwx 1 trimoon trimoon 32 Kas 22 14:04 overrides/lib/i386-linux-gnu/libm.so.6 -> /run/host/usr/lib32/libm-2.32.so",
" 167 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/i386-linux-gnu/libmemusage.so -> /run/host/usr/lib32/libmemusage.so",
" 166 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnsl.so.1 -> /run/host/usr/lib32/libnsl-2.32.so",
" 165 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libpcprofile.so -> /run/host/usr/lib32/libpcprofile.so",
" 164 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/libresolv.so.2 -> /run/host/usr/lib32/libresolv-2.32.so",
" 163 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/i386-linux-gnu/librt.so.1 -> /run/host/usr/lib32/librt-2.32.so",
" 162 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/libthread_db.so.1 -> /run/host/usr/lib32/libthread_db-1.0.so",
" 161 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libutil.so.1 -> /run/host/usr/lib32/libutil-2.32.so",
" 160 0 lrwxrwxrwx 1 trimoon trimoon 46 Kas 22 14:04 overrides/lib/i386-linux-gnu/libEGL_nvidia.so.0 -> /run/host/usr/lib32/libEGL_nvidia.so.455.45.01",
" 159 0 lrwxrwxrwx 1 trimoon trimoon 47 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-glsi.so.455.45.01 -> /run/host/usr/lib32/libnvidia-glsi.so.455.45.01",
" 158 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libEGL_mesa.so.0 -> /run/host/usr/lib32/libEGL_mesa.so.0.0.0",
" 157 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libgbm.so.1 -> /run/host/usr/lib32/libgbm.so.1.0.0",
" 156 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libdrm.so.2 -> /run/host/usr/lib32/libdrm.so.2.4.0",
" 155 0 lrwxrwxrwx 1 trimoon trimoon 46 Kas 22 14:04 overrides/lib/i386-linux-gnu/libwayland-server.so.0 -> /run/host/usr/lib32/libwayland-server.so.0.1.0",
" 154 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libffi.so.7 -> /run/host/usr/lib32/libffi.so.7.1.0",
" 153 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libexpat.so.1 -> /run/host/usr/lib32/libexpat.so.1.6.12",
" 152 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/libglapi.so.0 -> /run/host/usr/lib32/libglapi.so.0.0.0",
" 151 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/libX11-xcb.so.1 -> /run/host/usr/lib32/libX11-xcb.so.1.0.0",
" 150 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb.so.1 -> /run/host/usr/lib32/libxcb.so.1.1.0",
" 149 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libXau.so.6 -> /run/host/usr/lib32/libXau.so.6.0.0",
" 148 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/libXdmcp.so.6 -> /run/host/usr/lib32/libXdmcp.so.6.0.0",
" 147 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb-dri2.so.0 -> /run/host/usr/lib32/libxcb-dri2.so.0.0.0",
" 146 0 lrwxrwxrwx 1 trimoon trimoon 42 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb-xfixes.so.0 -> /run/host/usr/lib32/libxcb-xfixes.so.0.0.0",
" 145 0 lrwxrwxrwx 1 trimoon trimoon 46 Kas 22 14:04 overrides/lib/i386-linux-gnu/libwayland-client.so.0 -> /run/host/usr/lib32/libwayland-client.so.0.3.0",
" 144 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb-dri3.so.0 -> /run/host/usr/lib32/libxcb-dri3.so.0.0.0",
" 143 0 lrwxrwxrwx 1 trimoon trimoon 43 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb-present.so.0 -> /run/host/usr/lib32/libxcb-present.so.0.0.0",
" 142 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb-sync.so.1 -> /run/host/usr/lib32/libxcb-sync.so.1.0.0",
" 141 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxshmfence.so.1 -> /run/host/usr/lib32/libxshmfence.so.1.0.0",
" 140 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGL.so.1 -> /run/host/usr/lib32/libGL.so.1.7.0",
" 139 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGLX.so.0 -> /run/host/usr/lib32/libGLX.so.0.0.0",
" 138 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libX11.so.6 -> /run/host/usr/lib32/libX11.so.6.3.0",
" 137 0 lrwxrwxrwx 1 trimoon trimoon 52 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGLESv1_CM_nvidia.so.1 -> /run/host/usr/lib32/libGLESv1_CM_nvidia.so.455.45.01",
" 136 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGLESv2.so.2 -> /run/host/usr/lib32/libGLESv2.so.2.1.0",
" 135 0 lrwxrwxrwx 1 trimoon trimoon 46 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGLX_nvidia.so.0 -> /run/host/usr/lib32/libGLX_nvidia.so.455.45.01",
" 134 0 lrwxrwxrwx 1 trimoon trimoon 46 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-tls.so.455.45.01 -> /run/host/usr/lib32/libnvidia-tls.so.455.45.01",
" 133 0 lrwxrwxrwx 1 trimoon trimoon 49 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-glcore.so.455.45.01 -> /run/host/usr/lib32/libnvidia-glcore.so.455.45.01",
" 132 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/i386-linux-gnu/libXext.so.6 -> /run/host/usr/lib32/libXext.so.6.4.0",
" 131 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGLX_mesa.so.0 -> /run/host/usr/lib32/libGLX_mesa.so.0.0.0",
" 130 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb-glx.so.0 -> /run/host/usr/lib32/libxcb-glx.so.0.0.0",
" 129 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libXfixes.so.3 -> /run/host/usr/lib32/libXfixes.so.3.1.0",
" 128 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/libXdamage.so.1 -> /run/host/usr/lib32/libXdamage.so.1.1.0",
" 127 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/libXxf86vm.so.1 -> /run/host/usr/lib32/libXxf86vm.so.1.0.0",
" 126 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libOpenGL.so.0 -> /run/host/usr/lib32/libOpenGL.so.0.0.0",
" 125 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libvulkan.so.1 -> /run/host/usr/lib32/libvulkan.so.1.2.159",
" 124 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/libvdpau.so.1 -> /run/host/usr/lib32/libvdpau.so.1.0.0",
" 123 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/i386-linux-gnu/libva.so.2 -> /run/host/usr/lib32/libva.so.2.800.0",
" 122 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libva-drm.so.2 -> /run/host/usr/lib32/libva-drm.so.2.800.0",
" 121 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libva-glx.so.2 -> /run/host/usr/lib32/libva-glx.so.2.800.0",
" 120 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libva-x11.so.2 -> /run/host/usr/lib32/libva-x11.so.2.800.0",
" 119 0 lrwxrwxrwx 1 trimoon trimoon 49 Kas 22 14:04 overrides/lib/i386-linux-gnu/libGLESv2_nvidia.so.2 -> /run/host/usr/lib32/libGLESv2_nvidia.so.455.45.01",
" 118 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libcuda.so.1 -> /run/host/usr/lib32/libcuda.so.455.45.01",
" 117 0 lrwxrwxrwx 1 trimoon trimoon 50 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-eglcore.so.455.45.01 -> /run/host/usr/lib32/libnvidia-eglcore.so.455.45.01",
" 116 0 lrwxrwxrwx 1 trimoon trimoon 49 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-encode.so.1 -> /run/host/usr/lib32/libnvidia-encode.so.455.45.01",
" 115 0 lrwxrwxrwx 1 trimoon trimoon 43 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvcuvid.so.1 -> /run/host/usr/lib32/libnvcuvid.so.455.45.01",
" 114 0 lrwxrwxrwx 1 trimoon trimoon 46 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-fbc.so.1 -> /run/host/usr/lib32/libnvidia-fbc.so.455.45.01",
" 113 0 lrwxrwxrwx 1 trimoon trimoon 52 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-glvkspirv.so.455.45.01 -> /run/host/usr/lib32/libnvidia-glvkspirv.so.455.45.01",
" 112 0 lrwxrwxrwx 1 trimoon trimoon 46 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-ifr.so.1 -> /run/host/usr/lib32/libnvidia-ifr.so.455.45.01",
" 111 0 lrwxrwxrwx 1 trimoon trimoon 45 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-ml.so.1 -> /run/host/usr/lib32/libnvidia-ml.so.455.45.01",
" 110 0 lrwxrwxrwx 1 trimoon trimoon 54 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-opticalflow.so.1 -> /run/host/usr/lib32/libnvidia-opticalflow.so.455.45.01",
" 109 0 lrwxrwxrwx 1 trimoon trimoon 57 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnvidia-ptxjitcompiler.so.1 -> /run/host/usr/lib32/libnvidia-ptxjitcompiler.so.455.45.01",
" 104 0 drwxr-xr-x 4 trimoon trimoon 80 Kas 22 14:04 overrides/lib/i386-linux-gnu/vulkan",
" 107 0 drwxr-xr-x 2 trimoon trimoon 60 Kas 22 14:04 overrides/lib/i386-linux-gnu/vulkan/0",
" 108 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/vulkan/0/libvulkan_intel.so -> /run/host/usr/lib32/libvulkan_intel.so",
" 105 0 drwxr-xr-x 2 trimoon trimoon 60 Kas 22 14:04 overrides/lib/i386-linux-gnu/vulkan/1",
" 106 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/vulkan/1/libvulkan_radeon.so -> /run/host/usr/lib32/libvulkan_radeon.so",
" 103 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxcb-randr.so.0 -> /run/host/usr/lib32/libxcb-randr.so.0.1.0",
" 102 0 lrwxrwxrwx 1 trimoon trimoon 34 Kas 22 14:04 overrides/lib/i386-linux-gnu/libz.so.1 -> /run/host/usr/lib32/libz.so.1.2.11",
" 101 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/i386-linux-gnu/libzstd.so.1 -> /run/host/usr/lib32/libzstd.so.1.4.5",
" 100 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/libstdc++.so.6 -> /run/host/usr/lib32/libstdc++.so.6.0.28",
" 99 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/i386-linux-gnu/libgcc_s.so.1 -> /run/host/usr/lib32/libgcc_s.so.1",
" 98 0 lrwxrwxrwx 1 trimoon trimoon 33 Kas 22 14:04 overrides/lib/i386-linux-gnu/libLLVM-11.so -> /run/host/usr/lib32/libLLVM-11.so",
" 97 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libncursesw.so.6 -> /run/host/usr/lib32/libncursesw.so.6.2",
" 96 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/libxml2.so.2 -> /run/host/usr/lib32/libxml2.so.2.9.10",
" 95 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/i386-linux-gnu/libicuuc.so.67 -> /run/host/usr/lib32/libicuuc.so.67.1",
" 94 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libicudata.so.67 -> /run/host/usr/lib32/libicudata.so.67.1",
" 93 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/i386-linux-gnu/liblzma.so.5 -> /run/host/usr/lib32/liblzma.so.5.2.5",
" 92 0 lrwxrwxrwx 1 trimoon trimoon 42 Kas 22 14:04 overrides/lib/i386-linux-gnu/libdrm_amdgpu.so.1 -> /run/host/usr/lib32/libdrm_amdgpu.so.1.0.0",
" 91 0 lrwxrwxrwx 1 trimoon trimoon 35 Kas 22 14:04 overrides/lib/i386-linux-gnu/libelf.so.1 -> /run/host/usr/lib32/libelf-0.181.so",
" 90 0 lrwxrwxrwx 1 trimoon trimoon 36 Kas 22 14:04 overrides/lib/i386-linux-gnu/libidn2.so.0 -> /run/host/usr/lib32/libidn2.so.0.3.7",
" 89 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/libunistring.so.2 -> /run/host/usr/lib32/libunistring.so.2.1.0",
" 88 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnss_compat.so.2 -> /run/host/usr/lib32/libnss_compat-2.32.so",
" 87 0 lrwxrwxrwx 1 trimoon trimoon 37 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnss_db.so.2 -> /run/host/usr/lib32/libnss_db-2.32.so",
" 86 0 lrwxrwxrwx 1 trimoon trimoon 40 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnss_files.so.2 -> /run/host/usr/lib32/libnss_files-2.32.so",
" 85 0 lrwxrwxrwx 1 trimoon trimoon 38 Kas 22 14:04 overrides/lib/i386-linux-gnu/libnss_dns.so.2 -> /run/host/usr/lib32/libnss_dns-2.32.so",
" 84 0 lrwxrwxrwx 1 trimoon trimoon 41 Kas 22 14:04 overrides/lib/i386-linux-gnu/libdrm_intel.so.1 -> /run/host/usr/lib32/libdrm_intel.so.1.0.0",
" 83 0 lrwxrwxrwx 1 trimoon trimoon 42 Kas 22 14:04 overrides/lib/i386-linux-gnu/libpciaccess.so.0 -> /run/host/usr/lib32/libpciaccess.so.0.11.1",
" 82 0 lrwxrwxrwx 1 trimoon trimoon 42 Kas 22 14:04 overrides/lib/i386-linux-gnu/libdrm_radeon.so.1 -> /run/host/usr/lib32/libdrm_radeon.so.1.0.1",
" 81 0 lrwxrwxrwx 1 trimoon trimoon 43 Kas 22 14:04 overrides/lib/i386-linux-gnu/libdrm_nouveau.so.2 -> /run/host/usr/lib32/libdrm_nouveau.so.2.0.0",
" 80 0 lrwxrwxrwx 1 trimoon trimoon 39 Kas 22 14:04 overrides/lib/i386-linux-gnu/libsensors.so.5 -> /run/host/usr/lib32/libsensors.so.5.0.0",
" 78 0 lrwxrwxrwx 1 trimoon trimoon 14 Kas 22 14:04 overrides/lib/i486-linux-gnu -> i386-linux-gnu",
" 77 0 lrwxrwxrwx 1 trimoon trimoon 14 Kas 22 14:04 overrides/lib/i586-linux-gnu -> i386-linux-gnu",
" 76 0 lrwxrwxrwx 1 trimoon trimoon 14 Kas 22 14:04 overrides/lib/i686-linux-gnu -> i386-linux-gnu",
" 59 0 drwxr-xr-x 4 trimoon trimoon 80 Kas 22 14:04 overrides/share",
" 64 0 drwxr-xr-x 3 trimoon trimoon 60 Kas 22 14:04 overrides/share/vulkan",
" 65 0 drwxr-xr-x 2 trimoon trimoon 140 Kas 22 14:04 overrides/share/vulkan/icd.d",
" 73 4 -rw------- 0 trimoon trimoon 166 Kas 22 14:04 overrides/share/vulkan/icd.d/0-i386-linux-gnu.json",
" 71 4 -rw------- 0 trimoon trimoon 167 Kas 22 14:04 overrides/share/vulkan/icd.d/1-i386-linux-gnu.json",
" 69 4 -rw------- 0 trimoon trimoon 168 Kas 22 14:04 overrides/share/vulkan/icd.d/2-x86_64-linux-gnu.json",
" 67 4 -rw------- 0 trimoon trimoon 169 Kas 22 14:04 overrides/share/vulkan/icd.d/3-x86_64-linux-gnu.json",
"672447 4 -rw-r--r-- 1 nobody nobody 140 Kas 17 21:27 overrides/share/vulkan/icd.d/4.json",
" 60 0 drwxr-xr-x 3 trimoon trimoon 60 Kas 22 14:04 overrides/share/glvnd",
" 61 0 drwxr-xr-x 2 trimoon trimoon 80 Kas 22 14:04 overrides/share/glvnd/egl_vendor.d",
"571107 4 -rw-r--r-- 1 nobody nobody 105 Kas 8 15:36 overrides/share/glvnd/egl_vendor.d/1.json",
"672431 4 -rw-r--r-- 1 nobody nobody 107 Kas 17 21:27 overrides/share/glvnd/egl_vendor.d/0.json"
"os-release" : {
"id" : "steamrt",
"id_like" : [
"ubuntu",
"debian"
"name" : "Steam Runtime",
"pretty_name" : "Steam Runtime 1 (scout)",
"version_id" : "1",
"version_codename" : "scout",
"build_id" : "0.20201022.1",
"variant_id" : "com.valvesoftware.steamruntime.platform-amd64_i386-scout",
"variant" : "Platform"
"container" : {
"type" : "pressure-vessel",
"host" : {
"path" : "/run/host",
"os-release" : {
"id" : "manjaro",
"id_like" : [
"arch"
"architectures" : {
"can-run" : true,
"x11/vulkan" : {
"messages" : "ERROR: [Loader Message] Code 0 : /overrides/lib/x86_64-linux-gnu/vulkan/2/libvulkan_intel.so: wrong ELF class: ELFCLASS64\nERROR: [Loader Message] Code 0 : /overrides/lib/x86_64-linux-gnu/vulkan/3/libvulkan_radeon.so: wrong ELF class: ELFCLASS64\n",
"x11/vdpau" : {
"messages" : "Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory\nvdp_device_create_x11 (display, screen, &device, &vdp_get_proc_address) failed: 1\n",
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"x11/vaapi" : {
"messages" : "libva info: VA-API version 1.8.0\nlibva info: Trying to open /usr/lib32/dri/nvidia_drv_video.so\nlibva info: va_openDriver() returns -1\nvaInitialize (va_display, &major_version, &minor_version) failed: unknown libva error (-1)\n",
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"glx/gl" : {
"egl_x11/gl" : {
"dri_drivers" : [
"library_path" : "/overrides/lib/i386-linux-gnu/dri/i915_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/i965_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/iris_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/kms_swrast_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/nouveau_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/nouveau_vieux_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/r200_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/r300_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/r600_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/radeon_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/radeonsi_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/swrast_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/virtio_gpu_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/vmwgfx_dri.so"
"library_path" : "/run/host/usr/lib32/dri/i915_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/i965_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/iris_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/kms_swrast_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/nouveau_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/nouveau_vieux_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/r200_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/r300_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/r600_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/radeon_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/radeonsi_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/swrast_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/virtio_gpu_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/vmwgfx_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/dri/i965_drv_video.so"
"library_path" : "/run/host/usr/lib32/dri/nouveau_drv_video.so"
"library_path" : "/run/host/usr/lib32/dri/nvidia_drv_video.so"
"library_path" : "/run/host/usr/lib32/dri/r600_drv_video.so"
"library_path" : "/run/host/usr/lib32/dri/radeonsi_drv_video.so"
"library_path" : "/run/host/usr/lib32/dri/s3g_drv_video.so"
"library_path" : "/run/host/usr/lib32/dri/vdpau_drv_video.so"
"library_path" : "/usr/lib/i386-linux-gnu/dri/dummy_drv_video.so"
"vdpau_drivers" : [
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_nouveau.so",
"library_link" : "libvdpau_nouveau.so.1.0.0",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_nouveau.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_nvidia.so",
"library_link" : "libvdpau_nvidia.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_nvidia.so.1",
"library_link" : "libvdpau_nvidia.so.455.45.01",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_r300.so",
"library_link" : "libvdpau_r300.so.1.0.0",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_r300.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_r600.so",
"library_link" : "libvdpau_r600.so.1.0.0",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_r600.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_radeonsi.so",
"library_link" : "libvdpau_radeonsi.so.1.0.0",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_radeonsi.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_trace.so",
"library_link" : "libvdpau_trace.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib32/vdpau/libvdpau_trace.so.1",
"library_link" : "libvdpau_trace.so.1.0.0",
"is_extra" : true
"glx_drivers" : [
"library_path" : "/run/host/usr/lib32/libGLX_mesa.so.0.0.0"
"library_path" : "/run/host/usr/lib32/libGLX_nvidia.so.455.45.01"
"can-run" : true,
"x11/vulkan" : {
"messages" : "ERROR: [Loader Message] Code 0 : /overrides/lib/i386-linux-gnu/vulkan/0/libvulkan_intel.so: wrong ELF class: ELFCLASS32\nERROR: [Loader Message] Code 0 : /overrides/lib/i386-linux-gnu/vulkan/1/libvulkan_radeon.so: wrong ELF class: ELFCLASS32\n",
"x11/vdpau" : {
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"x11/vaapi" : {
"messages" : "libva info: VA-API version 1.9.0\nlibva info: Trying to open /usr/lib/dri/nvidia_drv_video.so\nlibva info: va_openDriver() returns -1\nvaInitialize (va_display, &major_version, &minor_version) failed: unknown libva error (-1)\n",
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"glx/gl" : {
"egl_x11/gl" : {
"dri_drivers" : [
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/i915_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/i965_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/iris_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/kms_swrast_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/nouveau_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/nouveau_vieux_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/r200_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/r300_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/r600_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/radeon_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/radeonsi_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/swrast_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/virtio_gpu_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/vmwgfx_dri.so"
"library_path" : "/overrides/lib/x86_64-linux-gnu/dri/zink_dri.so"
"library_path" : "/overrides/lib/i386-linux-gnu/dri/zink_dri.so"
"library_path" : "/run/host/usr/lib/dri/i915_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/i965_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/iris_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/kms_swrast_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/nouveau_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/nouveau_vieux_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/r200_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/r300_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/r600_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/radeon_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/radeonsi_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/swrast_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/virtio_gpu_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/vmwgfx_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/zink_dri.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/dri/i965_drv_video.so"
"library_path" : "/run/host/usr/lib/dri/nouveau_drv_video.so"
"library_path" : "/run/host/usr/lib/dri/nvidia_drv_video.so"
"library_path" : "/run/host/usr/lib/dri/r600_drv_video.so"
"library_path" : "/run/host/usr/lib/dri/radeonsi_drv_video.so"
"library_path" : "/run/host/usr/lib/dri/s3g_drv_video.so"
"library_path" : "/run/host/usr/lib/dri/vdpau_drv_video.so"
"library_path" : "/usr/lib/x86_64-linux-gnu/dri/dummy_drv_video.so"
"vdpau_drivers" : [
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_nouveau.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_nouveau.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_nvidia.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_nvidia.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_r300.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_r300.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_r600.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_r600.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_radeonsi.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_radeonsi.so.1",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_trace.so",
"is_extra" : true
"library_path" : "/run/host/usr/lib/vdpau/libvdpau_trace.so.1",
"is_extra" : true
"glx_drivers" : [
"library_path" : "/run/host/usr/lib/libGLX_mesa.so.0.0.0"
"library_path" : "/run/host/usr/lib/libGLX_nvidia.so.455.45.01"
"locale-issues" : [
"c-utf8-missing",
"locales" : {
"<default>" : {
"is_utf8" : true
"C" : {
"is_utf8" : false
"C.UTF-8" : {
"error-code" : 0,
"en_US.UTF-8" : {
"is_utf8" : true
"egl" : {
"icds" : [
"json_path" : "/overrides/share/glvnd/egl_vendor.d/0.json",
"json_path" : "/overrides/share/glvnd/egl_vendor.d/1.json",
"vulkan" : {
"icds" : [
"json_path" : "/overrides/share/vulkan/icd.d/0-i386-linux-gnu.json",
"library_path" : "/overrides/lib/i386-linux-gnu/vulkan/0/libvulkan_intel.so",
"json_path" : "/overrides/share/vulkan/icd.d/1-i386-linux-gnu.json",
"library_path" : "/overrides/lib/i386-linux-gnu/vulkan/1/libvulkan_radeon.so",
"json_path" : "/overrides/share/vulkan/icd.d/2-x86_64-linux-gnu.json",
"library_path" : "/overrides/lib/x86_64-linux-gnu/vulkan/2/libvulkan_intel.so",
"json_path" : "/overrides/share/vulkan/icd.d/3-x86_64-linux-gnu.json",
"library_path" : "/overrides/lib/x86_64-linux-gnu/vulkan/3/libvulkan_radeon.so",
"json_path" : "/overrides/share/vulkan/icd.d/4.json",
"cpu-features" : {
"x86-64" : true,
"sse3" : true,
"cmpxchg16b" : true
"soldier runtime container" information:
"can-write-uinput" : true,
"steam-installation" : {
"path" : "/home/trimoon/.local/share/Steam",
"data_path" : "/home/trimoon/.local/share/Steam",
"bin32_path" : "/home/trimoon/.local/share/Steam/ubuntu12_32",
"issues" : [
"unexpected-steam-uri-handler"
"runtime" : {
"path" : "/",
"issues" : [
"overrides" : {
"list" : [
" 672447 4 -rw-r--r-- 1 nobody nobody 140 Kas 17 21:27 overrides/share/vulkan/icd.d/4.json",
" 571107 4 -rw-r--r-- 1 nobody nobody 105 Kas 8 15:36 overrides/share/glvnd/egl_vendor.d/1.json",
" 672431 4 -rw-r--r-- 1 nobody nobody 107 Kas 17 21:27 overrides/share/glvnd/egl_vendor.d/0.json"
"os-release" : {
"id" : "steamrt",
"id_like" : [
"debian"
"pretty_name" : "Steam Runtime 2 (soldier)",
"version_id" : "2",
"version_codename" : "soldier",
"variant_id" : "com.valvesoftware.steamruntime.platform-amd64_i386-soldier",
"container" : {
"host" : {
"os-release" : {
"id" : "manjaro",
"id_like" : [
"arch"
"architectures" : {
"can-run" : true,
"x11/vulkan" : {
"x11/vdpau" : {
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"x11/vaapi" : {
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"glx/gl" : {
"egl_x11/gl" : {
"dri_drivers" : [
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"vdpau_drivers" : [
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"glx_drivers" : [
"can-run" : true,
"x11/vulkan" : {
"x11/vdpau" : {
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"x11/vaapi" : {
"renderer" : null,
"version" : null,
"issues" : [
"cannot-draw"
"exit-status" : 1
"glx/gl" : {
"egl_x11/gl" : {
"dri_drivers" : [
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"vdpau_drivers" : [
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"is_extra" : true
"glx_drivers" : [
"locale-issues" : [
"c-utf8-missing",
"locales" : {
"<default>" : {
"is_utf8" : true
"C" : {
"is_utf8" : false
"C.UTF-8" : {
"error-code" : 0,
"en_US.UTF-8" : {
"is_utf8" : true
"egl" : {
"icds" : [
"vulkan" : {
"icds" : [
"cpu-features" : {
"x86-64" : true,
"sse3" : true,
"cmpxchg16b" : true
Update:
I just started Steam again, and did nothing yet besides posting the above.
The above mentioned process is listed min. 4 times (varies by the second) and they consume 100% CPU…
How to get this fixed?
