Hi,
I am running my system with btrfs and after cleaning up some big files I decided to run a scrub with btrfs assistant. During that my system crashed. I tried it again with the same result.
I run manjaro from a usb stick and got some errors from journalctl --dmesg:
Feb 21 21:10:28 manjaro kernel: Bluetooth: RFCOMM TTY layer initialized
Feb 21 21:10:28 manjaro kernel: Bluetooth: RFCOMM socket layer initialized
Feb 21 21:10:28 manjaro kernel: Bluetooth: RFCOMM ver 1.11
Feb 21 21:10:32 manjaro kernel: logitech-hidpp-device 0003:046D:406C.0008: HID++ 4.2 device connected.
Feb 21 21:11:24 manjaro kernel: BTRFS: device fsid 703ffe1a-84b0-41ba-9dab-dfc62477af24 devid 1 transid 516824 /dev/nvme1n1p2 (259:2) scanned by pool-udisksd (2553)
Feb 21 21:11:24 manjaro kernel: BTRFS info (device nvme1n1p2): first mount of filesystem 703ffe1a-84b0-41ba-9dab-dfc62477af24
Feb 21 21:11:24 manjaro kernel: BTRFS info (device nvme1n1p2): using crc32c (crc32c-intel) checksum algorithm
Feb 21 21:11:24 manjaro kernel: BTRFS info (device nvme1n1p2): disk space caching is enabled
Feb 21 21:11:24 manjaro kernel: BTRFS warning (device nvme1n1p2): space cache v1 is being deprecated and will be removed in a future release, please use -o space_cache=v2
Feb 21 21:11:39 manjaro kernel: BTRFS info (device nvme1n1p2): scrub: started on devid 1
Feb 21 21:18:51 manjaro kernel: pcieport 0000:00:1d.0: AER: Multiple Correctable error message received from 0000:00:1d.0
Feb 21 21:18:51 manjaro kernel: pcieport 0000:00:1d.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
Feb 21 21:18:51 manjaro kernel: pcieport 0000:00:1d.0: device [8086:a298] error status/mask=00002041/00002000
Feb 21 21:18:51 manjaro kernel: pcieport 0000:00:1d.0: [ 0] RxErr (First)
Feb 21 21:18:51 manjaro kernel: pcieport 0000:00:1d.0: [ 6] BadTLP
Feb 21 21:19:22 manjaro kernel: nvme nvme1: controller is down; will reset: CSTS=0xffffffff, PCI_STATUS=0x10
Feb 21 21:19:22 manjaro kernel: nvme nvme1: Does your device have a faulty power saving mode enabled?
Feb 21 21:19:22 manjaro kernel: nvme nvme1: Try "nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off" and report a bug
Feb 21 21:19:22 manjaro kernel: nvme 0000:09:00.0: enabling device (0000 -> 0002)
Feb 21 21:19:22 manjaro kernel: nvme nvme1: Disabling device after reset failure: -19
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 1, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 2, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 3, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 4, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 6, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 5, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 7, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 8, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 9, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): bdev /dev/nvme1n1p2 errs: wr 0, rd 10, flush 0, corrupt 0, gen 0
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): unable to fixup (regular) error at logical 4950066528256 on dev /dev/nvme1n1p2 physical 297511944192
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): unable to fixup (regular) error at logical 4950066724864 on dev /dev/nvme1n1p2 physical 297512140800
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): unable to fixup (regular) error at logical 4950066921472 on dev /dev/nvme1n1p2 physical 297512337408
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): unable to fixup (regular) error at logical 4950066790400 on dev /dev/nvme1n1p2 physical 297512206336
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): unable to fixup (regular) error at logical 4950066659328 on dev /dev/nvme1n1p2 physical 297512075264
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2): unable to fixup (regular) error at logical 4950066987008 on dev /dev/nvme1n1p2 physical 297512402944
Feb 21 21:19:22 manjaro kernel: BTRFS: error (device nvme1n1p2) in btrfs_commit_transaction:2523: errno=-5 IO failure (Error while writing out transaction)
Feb 21 21:19:22 manjaro kernel: BTRFS info (device nvme1n1p2 state E): forced readonly
Feb 21 21:19:22 manjaro kernel: BTRFS warning (device nvme1n1p2 state E): Skipping commit of aborted transaction.
Feb 21 21:19:22 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): Transaction aborted (error -5)
Feb 21 21:19:22 manjaro kernel: BTRFS: error (device nvme1n1p2 state EA) in cleanup_transaction:2017: errno=-5 IO failure
Feb 21 21:19:22 manjaro kernel: BTRFS info (device nvme1n1p2 state EA): scrub: not finished on devid 1 with status: -5
Feb 21 21:19:40 manjaro kernel: btrfs_dev_stat_inc_and_print: 966 callbacks suppressed
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 957, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 958, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 959, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 960, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 961, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 962, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 963, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 964, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 965, flush 0, corrupt 0, gen 0
Feb 21 21:19:40 manjaro kernel: BTRFS error (device nvme1n1p2 state EA): bdev /dev/nvme1n1p2 errs: wr 38, rd 966, flush 0, corrupt 0, gen 0
btrfs check did not find any errors.
In case it is connected: after the last manjaro update 2025-16-02 I sometimes have a problem on boot, that the desktop is not starting properly but systemctl restart sddm resolves it.
inxi:
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: MAXIMUS IX FORMULA v: Rev 1.xx
serial: <superuser required> part-nu: SKU UEFI: American Megatrends v: 1301
date: 03/14/2018
Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) status: discharging
Info: quad core model: Intel Core i7-7700K bits: 64 type: MT MCP
arch: Kaby Lake rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 800 min/max: 800/4700 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 67224
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3
pcie: speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2,
DP-3, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:747e
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung C49HG9x res: 3840x1080
hz: 120 dpi: 81 diag: 1242mm (48.9")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO) device-ID: 1002:747e
API: Vulkan v: 1.4.303 surfaces: xcb,xlib device: 0 type: discrete-gpu
driver: N/A device-ID: 1002:747e
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab30
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.7 status: off with: pipewire-media-session
status: active
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8
IF: enp0s31f6 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie:
speed: 5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8125
IF: enp6s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
IF-ID-1: br-d27b5779686b state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: ASUSTek Qualcomm Bluetooth 4.1 driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 1-11:5 chip-ID: 0b05:1825
Local Storage: total: 2.72 TiB used: 1015.56 GiB (36.5%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP510 size: 894.25 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 45.9 C
ID-2: /dev/nvme1n1 vendor: Seagate model: FireCuda 530 ZP2000GM30013
size: 1.82 TiB speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 19.9 C
ID-3: /dev/sda vendor: SanDisk model: Ultra size: 28.64 GiB type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 serial: <filter>
ID-1: / size: 893.96 GiB used: 332.73 GiB (37.2%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 568 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 893.96 GiB used: 332.73 GiB (37.2%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 893.96 GiB used: 332.73 GiB (37.2%) fs: btrfs
dev: /dev/nvme0n1p2
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
mem: 41.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.28 GiB used: 4.45 GiB (14.2%)
Processes: 353 Power: uptime: 2m wakeups: 0 Init: systemd v: 257
default: graphical
Packages: pm: pacman pkgs: 1715 Compilers: clang: 19.1.7 gcc: 14.2.1
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.37
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.12-2-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: Force MP510
Serial Number: 192182070001277136B8
Firmware Version: ECFM12.2
PCI Vendor/Subsystem ID: 0x1987
IEEE OUI Identifier: 0x6479a7
Total NVM Capacity: 960.197.124.096 [960 GB]
Unallocated NVM Capacity: 0
Controller ID: 1
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 960.197.124.096 [960 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 6479a7 1fa1034238
Local Time is: Fri Feb 21 21:42:15 2025 CET
Firmware Updates (0x12): 1 Slot, no Reset required
Optional Admin Commands (0x0007): Security Format Frmw_DL
Optional NVM Commands (0x0054): DS_Mngmt Sav/Sel_Feat Timestmp
Log Page Attributes (0x0c): Ext_Get_Lg Telmtry_Lg
Maximum Data Transfer Size: 512 Pages
Warning Comp. Temp. Threshold: 70 Celsius
Critical Comp. Temp. Threshold: 90 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 10.73W - - 0 0 0 0 0 0
1 + 7.69W - - 1 1 1 1 0 0
2 + 6.18W - - 2 2 2 2 0 0
3 - 0.0490W - - 3 3 3 3 2000 2000
4 - 0.0018W - - 4 4 4 4 25000 25000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 2
1 - 4096 0 1
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 43 Celsius
Available Spare: 100%
Available Spare Threshold: 5%
Percentage Used: 8%
Data Units Read: 184.967.564 [94,7 TB]
Data Units Written: 157.287.543 [80,5 TB]
Host Read Commands: 751.351.142
Host Write Commands: 1.143.640.682
Controller Busy Time: 4.338
Power Cycles: 2.505
Power On Hours: 8.347
Unsafe Shutdowns: 217
Media and Data Integrity Errors: 0
Error Information Log Entries: 5.646
Warning Comp. Temperature Time: 24
Critical Comp. Temperature Time: 0
Error Information (NVMe Log 0x01, 16 of 63 entries)
Num ErrCount SQId CmdId Status PELoc LBA NSID VS Message
0 5646 0 0x0010 0x4004 0x028 0 0 - Invalid Field in Command
1 5645 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
2 5644 0 0x0000 0x4004 0x028 0 0 - Invalid Field in Command
3 5643 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
4 5642 0 0x3015 0x4004 0x028 0 0 - Invalid Field in Command
5 5641 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
6 5640 0 0x0000 0x4004 0x028 0 0 - Invalid Field in Command
7 5639 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
8 5638 0 0x0000 0x4004 0x028 0 0 - Invalid Field in Command
9 5637 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
10 5636 0 0x5002 0x4004 0x028 0 0 - Invalid Field in Command
11 5635 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
12 5634 0 0x0000 0x4004 0x028 0 0 - Invalid Field in Command
13 5633 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
14 5632 0 0x000c 0x4004 0x028 0 0 - Invalid Field in Command
15 5631 0 0x0005 0x4004 - 0 0 - Invalid Field in Command
... (47 entries not read)
Self-tests not supported
Does somebody know what I can do to resolve the problem?
