Hi, Does anyone know how can I boot directly instead of using tty and typing “startx” because there was two errors at the start and one of them is “Failed to Start Display Manager”
Other thing is I want to lock my screen and use the hibernate feature. How can I do these?
Is this bspwm edition or a custom setup? Minimal or full?
Bspwm edition. There wasn’t any minimal edition and it has some pre-installed applications so I think it is full installation.
I notice something interesting today. If I suspend the machine and open it again once, my function and F key command would be activated. (Caps Lock button light too)
Yes there is. But using the full one is probably a good idea.
Try
Systemctl restart lightdm
And see what error you get.
There was no error when I execute the command: “systemctl restart lightdm” it restarted quickly and showed up the login screen.
Maybe I shouldn’t spend much time to solve minor issues
If you want autologin, disable lightdm and run the script
postinstall
It should have an option for autologin.
