Bsdtar: Option --no-read-sparse not supported for AUR packages
I check similar post where they say i have to check conda usage. My shell was not using conda base environment, but was using pyenv by default
I have tried by disabling, but i still get the same error, tried running the install / update from yay and still no luck
OK ignore
after doing which bsdtar found that it was pointing to a old miniconda binary (which was uninstalled long back)
After cleaning up the miniconda folder, it worked fine
