Hi everyone,
I’m using Manjaro KDE and a Brother MFC985-J985DW printer
#inxi -Fxz
System: Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.21.2
Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503QR_GA503QR v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA503QR v: 1.0 serial: <filter> UEFI: American Megatrends LLC. v: GA503QR.404
date: 02/08/2021
Battery: ID-1: BAT0 charge: 91.1 Wh condition: 91.1/90.0 Wh (101%) model: ASUSTeK ASUS Battery
status: Not charging
ID-2: hidpp_battery_0 charge: N/A condition: N/A model: Logitech G Pro Wireless Gaming Mouse
status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 rev: 0
L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 105453
Speed: 1286 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz): 1: 1286 2: 1621 3: 3672
4: 2816 5: 1915 6: 1915 7: 1916 8: 1681 9: 1315 10: 1913 11: 1512 12: 1606 13: 1357 14: 1915 15: 1905
16: 1818
Graphics: Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 460.56
bus ID: 01:00.0
Device-2: Advanced Micro Devices [AMD/ATI] vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 07:00.0
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia resolution: 1: 1920x1080~60Hz
2: 1920x1080
OpenGL: renderer: GeForce RTX 3070 Laptop GPU/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus ID: 07:00.1
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK
driver: N/A bus ID: 07:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 07:00.6
Device-4: Microdia NexiGo HD Webcam type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-1.2.4:12
Device-5: Kingston HyperX Cloud Flight S type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-1.3.3:13
Device-6: JMTek LLC. USB PnP Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-1.3.4:14
Sound Server: ALSA v: k5.11.2-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: d000 bus ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000 bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-4:5
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 1.84 TiB used: 76.15 GiB (4.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB temp: 54.9 C
ID-2: /dev/nvme1n1 vendor: SK Hynix model: HFM001TD3JX013N size: 953.87 GiB temp: 51.9 C
Partition: ID-1: / size: 899.02 GiB used: 76.13 GiB (8.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 25.5 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 66.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2400
GPU: device: nvidia screen: :0.0 temp: 56 C device: amdgpu temp: 63.0 C
Info: Processes: 446 Uptime: 3m Memory: 38.68 GiB used: 3.75 GiB (9.7%) Init: systemd Compilers:
gcc: 10.2.0 Packages: 1292 Shell: Zsh v: 5.8 inxi: 3.3.01
I have brother-mfc-j985dw and brscan4 installed. In simple-scan I’m getting the error message “Unable to start scan” and in skanlite I’m getting the error message “Invalid argument”. Does anyone know how I could go about fixing this?
