Please I have downloaded Manjaro 20.2 Nibia I have a printer Brother as above how do I install It ? Manjaro only says in the printer option print to PDF ? Any help Please.
Giuseppe
Hi, Have you tried adding the printer in settings, add printer?
when I done add printer that you can see the name of the printer In those two boxes address and cue ? what should I add?
I tried to load the image but itwouldn’t let me.
printer MFC-430W it says printer inactive what should I do to make it work ? thank you
I wante to up load an image of the problem but it will not let me.
Check out the printer settings.
There is a driver for your printer in the AUR. Did you try to download it?
To download the driver, first make sure that yay is installed. Open the terminal and type:
sudo pacman -S yay
Once yay is installed, download the driver for your printer as follows, open a terminal window and type:
yay -S brother-mfc-j430w
… and follow the prompts on screen. Good luck!
